Old 09-13-2005, 12:12 AM   #1 (permalink)
towing heavy with a one-ton van
I want to buy a van to tow my boat and am confused as to whether any van can legally pull my boat. My boat is a 26' Tollycraft that weighs nearly 10,000# and has a ten foot beam. I would tow it on a top guality, well set up trailer with electric over hydrolic breaks on all axles. The tounge weight would be about #800. I'm pretty sure a E-350 van with a diesel will pull this load easily and safely but will it be legal? I know I can tow this with a SRW F-350, but a van would serve our family better. I know an E-350 with a v-10 or a diesel can pull this fine, but can it do so legally? I'm wondering about insurance and liability. Is the 10,000# tow limit on E-350's a firm limit or a reccomendation? The Tolly on a good trailer is an easy tow compared to some kinds of equipment. I would have adequate hitches and load leveling hitch.
Thanks,
Jack
urbanboatbuilder is offline
Old 09-13-2005, 12:57 AM   #2 (permalink)
Super_Dave's Avatar
Re: towing heavy with a one-ton van
I don't know about the legality part.
I would certainly use the weight distibution AND dynamic sway control. I feel that vans have a funny weight bias or something. We had issues with my previous van pulling an enclosed car hauler with only weight distribution. Was heavy with a GVWR of 10k.
Super Dave
2003 Excursion Limited 4WD 7.3PSD - Prodigy brake controller, DP Tuner-60t/80e/AIC/exhaust brake, BG drive line fluids, Timbrin front & rear springs, 203* Tstat, Evans NPG+, coolant filter, Ford Transmission Cure
2007 Buell XB12R Road Racer
Super_Dave is offline
Old 09-13-2005, 07:03 AM   #3 (permalink)
My Photos: (11)
Jack,
First off WELCOME TO TDS. As far as I can tell the GCWR and tow ratings for both the 99+ 7.3L and the 6.0L at least for 2005 have the same limits and the V-10 has the same rating. For a 4.10 rear the GCWR is 20,000 and the towing rating is 10,000 with a 1,000 lb tongue wt with a WD setup. These are limits based on the hitch ratings available with the factory tow packages and the last time I checked the only hitch for a Van rated higher than 1K/10K was the 2K/20K pullrite hitch. So IMO you are go to go and perfectly legal as long as you keep the towed wt at 10,000 or under and the tongue wt less than 1,000. You'll also have to watch the GVWR of the actual tow vehicle if you load it up like a Quigley or Sportsman Conversion or get a 15 passenger Van or maybe even a 12 passenger and load it to the gills with people/cargo.
Larry
<font color="green">MY PICTURES - Look around ... lots of good stuff </font>
2001PSD(PCM:HPI2)SD E-350,Dk Emerald Grn,4.10LS, <font color="blue">Mustang dyno - 183.9/400.4 stock</font> [img]/ubbthreads/images/graemlins/smile.gif[/img], BTS w/Schaeffer's ATF[img]/ubbthreads/images/graemlins/biggrin.gif[/img] , ITP 3.5"/4" exhaust w/Magnaflow & Aeroturbine,Dieselsite 203* T-stat/Zerex G-05,F.Pwr, Ext/Int. Upgd. pkg,R. Bds,AIC,Tow Pkg, Rear & Slider windows,<font color="red">AMSOIL air, oil-bypass & rear end 75w-140 fluid ,<font color="blue">3/8" fuel sys w/10µ Dieselsite DAHL100 & fuel manifold/sight glass</font>,6 way dr. pwr. seat, Magnefine trans/P.S. filters</font>, husky mats,<font color="red">5 gauge A-pillar ISSPRO EVs w/Grn mkr illum. + air & fuel restriction gauges</font>,Dieselsite coolant filter and zinc electrode, manual GPR switch & GP LED, blinking security LED, weathertechs, a few other "Gadgets" [img]/ubbthreads/images/graemlins/smile.gif[/img], & a 1981 26' Prowler TT(26Y)
Larry M is offline
Old 09-13-2005, 08:34 AM   #4 (permalink)
My Photos: (14)
It varies from state to state, but in Florida 108" is max width for trailers without needing oversize permit.Towing and Hauling Forum may have more input on that aspect of it. If you do this with a van be sure it has a 4.10 rear.With the van full of family, coolers and gear you will likely be at or over the GCVWR(Gross combined Vehicle Weight rating).Your Tow capacity is the lesser of the Max rating or GCVWR-GVWR for the Van loaded which usually ends up being a number less than the max tow rating.
This would depend on how good your lawyer is at explaining why you thought it would be safe to exceed the manufacturers recommendations.
Towing overweight is always a potential liability. You would need to determine your risk tolerance for that.
While I love diesels, I don't need one, and unfortunately, after much deliberation its a hobby I currently cannot afford.......... Gone but not forgotten:
1999.5 F250 CC SB XLT 4WD, 7.3 PSD, First F,2nd Diesel, nice but still liked the van better.
2003 E-350 Super Duty Chateau (Club Wagon)7.3PSD, 3rd Clubwagon,First diesel, Never should have sold it....
ddog is offline
Old 09-16-2005, 01:06 AM   #5 (permalink)
carringb's Avatar
Not a problem.
To find the actual tow rating, you must look at the GCWR, which is 20,000 pounds (assuming you orer correct axle ratio). The advertised limit of 10k is due to the hitch.
Several class 5 hitches are available. Reese is one. I have Draw tight. And then , there is pullrite as mentioned but that is a good extra chunk of change.
Yes, you will be legal if you get an oversized vehicle permit due to the beam of the boat. Annual permits are available. You will have to be diligent about eh roads you drive on. Some highways will require amber strobes, and some may even require a pilot car.
2000 E350 DRW XLT extended wagon (yes! it's a dually!)
17" Ultra Goliath rims
Banks Powerpack, Diablo Predator
Buckstop front bumper, Reunel rear w/ 20,000# reciever
250,000+
carringb is online now
Old 09-16-2005, 06:37 AM   #6 (permalink)
My Photos: (11)
Yep ... after I posted I went back and looked and now there are some class V hitches available for Vans. This wasn't the case several years ago.
When my money boat docks, I might consider upgrading since I run a high tongue wt. and after 25yrs I probably should update my WD system. I'm still using a friction type sway system and have actually worn one out [img]/ubbthreads/images/graemlins/shocked.gif[/img] [img]/ubbthreads/images/graemlins/blush.gif[/img]
Larry
Larry M is offline
Old 09-17-2005, 09:06 PM   #7 (permalink)
I have pulled a 38'fifteen thousand pound camper trlr around the country
including Alaska loaded down with 12 kids and gear for four months.(with the van)
'01 F350 4x4 32,000miles Dec.06 52,000miles Dec.08
CC SRW 6'bed, tow\race chip,aerotank 55gal.
,rancho 9000's,2" edge,285-75-16's
,c-betr,cb radio,exhaustbrake,isspro gauges,AIS,walker btm,aih delete,remote start
'99 E350 15pass, chip,exhaustbrake,tranny&pyro guages,pullrite hitch, 165,000miles Dec.06,replaced waterpump Dec.07@180Kmiles, rebuilt tranny@200,000miles Jan.09
'96 F350 CC 4X4 chip,intercooler,downpipe,pyro&boost guages,transferflow tank(sold '03 @210,000miles)
puttputtwannabe is offline
Old 09-18-2005, 08:13 AM   #8 (permalink)
12 kids
This is a dynamic load, not a static load, and therefore modifies the equation . . . [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
"Nothing in life is so exhilarating as to be shot at without result." - Sir Winston Churchill
May your road stay clear & dry, may your fuel never gel, and may you never be outsmarted by your idiot lights.
2002 F-250 XLT SC LB 4x4 7.3PSD 6-Sp 3.73 L-S, Snugtop Snuglid Tonneau, 235/85 MC HTRs, <span style="color: red">DPTuner F5</span> AFE Stg II, Turbo LifeSaver, MAP BRV, Autometer Cobalts, Magnaflow 4", WW, TAG, AIH del, CCV, AirDog, In-tank, Harpoon, HPX, ITP fuel sys, LL8 del, 203*, Oilguard & SP Diesel bypass filtration, ART rotors, PFC pads, Heater Core Ctl Valve, Bilsteins, Velvet Ride Shackles, South Bend Clutch, <span style="color: green">21.27 mpg</span>
2004 <span style="color: red">E</span>-350
XLT Wagon 6.0PSD 3.55 L-S TDM EZ-Entry 11 pass., AIC, custom MBRP 4" w/dual Aeroturbines, Airdog, harpoon, Overhead Cobalts
Pictures . . . Parts Links
DarthSurplus is offline
Old 09-18-2005, 11:09 AM   #9 (permalink)
My Photos: (11)
[img]/ubbthreads/images/graemlins/shocked.gif[/img] ....
That's 38 feet divided by 12 kids = 1 kid every 38 inches not including any adults [img]/ubbthreads/images/graemlins/frown.gif[/img] ...
NOT ENOUGH ROOM PERIOD ... YOU CAN'T EVEN PHYSICALLY SEPARATE THEM [img]/ubbthreads/images/graemlins/tongue.gif[/img]
Larry
Larry M is offline
Old 09-18-2005, 04:26 PM   #10 (permalink)
I'm sure that there are clearly demarcated demilitarized zones and neutral corners.
