Old 08-03-2002, 10:58 AM   #1 (permalink)
Tranny cooler for our vans
I'am thinking of installing a heavy duty tranny cooler on the van.
However,I do not want to spend a lot of time trying to make this cooler fit.
What type of tranny cooler do you all recommend that would bolt right in to our vans. I want to reduce my tranny temps by at least 20 degrees.
I would like to install a cooler in series with my existing tranny cooler or install a larger cooler by itself.
The following website shows the Tru-Cool tranny cooler on sale for $76.53 at: www.bulkparts.com
The Tru-cool tranny cooler (#4590) is the same as the (#41312) which sells for $121.83 from other dealers for a $45.30 savings.
Anybody using this tranny cooler?
2000 E-350 Van,<font color="blue">BTS Tranny</font>,<font color="red">Custom Dana 80 Axle w/ ARB & 3:55 Gears</font>,TS 50/75/125/140 Chip,TS Billet Intakes,W/Wheel,PS2000,Magnaflow 4" Exhaust,ITP Van Specific Fuel Regulator/Tank Mods,Baldwin Pre Pump Filter Assy,TTM,CTI Idle Controller,Amsoil Fluids,Evans,203 Thermostat,Coolant Filter,Lighted Logos,Nerf Bars,J&J S.S. Grill,Art Rotors,Custom Flame Job,Road Armor Bumper,Warn M15000 Winch,Bushwacker Flares,Bilstein Shocks,Centerlines,Maghytec Covers. <font color="blue">PHOTOS</font><font color="red">[b] FUTURE MODS[b]</font>: Custom Ladder Bars,Psycho HPOP,Injectors,Water Injection.
04 Rubicon
RE 5.5" LA Lift,1"body/eng.lift,Banks Header/Stinger Exh.,35" MTRS,Mickey Thomson Classic 2 beadlocks,Road Armor Bumpers,Warn 9500ti winch,Alloy Usa axleshafts,CTM u-joints,Nth degree oil pan skid,Currie LCA skids. Future Mods88 Gears,37's,custom roll cage.
Aceman is offline
Old 08-04-2002, 07:09 PM   #2 (permalink)
Re: Tranny cooler for our vans
Aceman ,
I use this cooler on all three of my vehicles (F550 , F350 , TJ Sahara) .
They work great !
Countrycruizer
F550-Fontaine-Lariat-CC-PSD-Reyco Granning Air Ride-
Transfer Flow Fuel Tank-Alcoa 19.5 Wheels-Mag Hytec
Trans Pan-Diablo Sport Tow Chip-IAT & EBPV Upgrades-
Hidden Hitch Front Receiver-Reese Class IV -Aluminum
Deck-Tru Cool 4590 Trans Cooler-Excursion Grill & Fogs-
TYMAR Air & HX-adjustments by dieseloutlet ...................
CountryCruizer is offline
Old 08-04-2002, 07:38 PM   #3 (permalink)
CountryCruizer,thanks for the reply.
I'll probably order one and see if it fits on the van w/o a lot of modifications. [img]/ubbthreads/images/icons/smile.gif[/img]
I wonder if the other vanners are using a tranny cooler and if so,what type. [img]/ubbthreads/images/icons/wink.gif[/img]
04 Rubicon
Aceman is offline
Old 08-04-2002, 07:48 PM   #4 (permalink)
My Photos: (11)
Aceman,
No extra cooler yet, but watching those tranny temps [img]/ubbthreads/images/icons/wink.gif[/img] [img]/ubbthreads/images/icons/tongue.gif[/img] - so far so good, towing around 150 to 170 max to date over the Cumberland mtns. on I-68 185 for a short time until the factory fan came on and then back down to the 170 range.
Larry
<font color="green">MY PICTURES - Look around ... lots of good stuff </font>
2001PSD(PCM:HPI2)SD E-350,Dk Emerald Grn,4.10LS, <font color="blue">Mustang dyno - 183.9/400.4 stock</font> [img]/ubbthreads/images/graemlins/smile.gif[/img], BTS w/Schaeffer's ATF[img]/ubbthreads/images/graemlins/biggrin.gif[/img] , ITP 3.5"/4" exhaust w/Magnaflow & Aeroturbine,Dieselsite 203* T-stat/Zerex G-05,F.Pwr, Ext/Int. Upgd. pkg,R. Bds,AIC,Tow Pkg, Rear & Slider windows,<font color="red">AMSOIL air, oil-bypass & rear end 75w-140 fluid ,<font color="blue">3/8" fuel sys w/10µ Dieselsite DAHL100 & fuel manifold/sight glass</font>,6 way dr. pwr. seat, Magnefine trans/P.S. filters</font>, husky mats,<font color="red">5 gauge A-pillar ISSPRO EVs w/Grn mkr illum. + air & fuel restriction gauges</font>,Dieselsite coolant filter and zinc electrode, manual GPR switch & GP LED, blinking security LED, weathertechs, a few other "Gadgets" [img]/ubbthreads/images/graemlins/smile.gif[/img], & a 1981 26' Prowler TT(26Y)
Larry M is offline
Old 08-04-2002, 08:51 PM   #5 (permalink)
Larry,those are good temps your running.
I'am seeing about 180 degrees max even when towing.
I just want to bring the temps down into the 150 to 160 degree range to help extend the life of my future BTS tranny. [img]/ubbthreads/images/icons/cool.gif[/img]
04 Rubicon
Aceman is offline
Old 08-05-2002, 08:22 AM   #6 (permalink)
sixiron's Avatar
My Photos: (11)
Tom, posts from the truck site have temps reduced by just adding the extra capacity(3 qts) trans pan....also has drain plug to boot....but on the other hand if you're going to install the BTS trans probably a new cooler would be better...my .02 bill
2002 E-350 ext. cargo..4" DP+exhaust/gauges/ CCV mod/ AIH delete/TT mirrors wC-btr's/Amsoil Dual by-pass/Racor 45P prepump/ITP regulated return w/fuel bowl delete/tank mods/203*/timbrens/bilstein/Hella/ DP tuned/BTS trans/ alum baja wheels/cryo rotors...dyno 335 hp...164,062 miles
98 E-350 PSD...575K
04 VW TDI/PD Jetta wagon
cat 2 mic f/filter,CCV/muffler/fuel filler mods,Evo skidplate/ RC1+
sixiron is offline
Old 08-05-2002, 01:50 PM   #7 (permalink)
Bill,thanks.
I already installed the MagHytec tranny pan about 1.5 years ago and saw a 20 degree reduction due to the extra 8 quart capacity.
Also,aded the Maghytec rear diff.cover about the same time too.
04 Rubicon
Aceman is offline
