Old 03-05-2005, 08:05 PM   #1 (permalink)
MikeL46's Avatar
Trans out for 04B24 recall
Took it in Tuesday last week for the recall. Asked for my loaner car, and was told they didn't give them for work like this. I replied: 'That's strange, this letter from Ford says I can get a car. Lo and behold, I was given a loaner.
A week later I called to get the staus of my van. They said they found other problems when they got the tranny apart. Oh and by the way, they would like the loaner car back - Ford won't pay them for their loaner cars, but they can give me a Hertz car that Ford will pay for. So, I went down and swapped cars with them. And I got to talk to the tech working on my van.
He showed me the damaged shaft and support. Said he has the parts, but not the special Ford tool to install the inards into the TQ housing. The tool is on order. I asked how they installed the parts back into the housing in Dec when they replaced the housing because it was porous and leaking. The tech said another tech did the work and probably that was what damaged the parts he is now replacing.
Boy, this van loves to spend time in the shop.
- 1 week for a Check Engine light (EGR valve)
- 5 days in Northern Canada for 2 bad injectors
- 3 weeks to diagnose and replace transmission case
- 3 weeks for 4wd conversion
- 2 weeks and holding for 04B24 recall
Anybody else beat 9 weeks in the shop in the first 9 months? Admittedly, I've skewed the results with the voluntary 4wd conversion, but it has been in the shop alot!
Mike
125W solar panel. Sportsmobile off-road trailer.
54,311 miles. 16.47 mpg average
From Cal to Alaska and Key West and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires. 46 Gal tank - harpooned pump vent tube.
Scangauge
162 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, Turbo hose fitting, Block Heater, Door lock - all under warranty. AC hose, not under warranty.
MikeL46 is offline
Old 03-06-2005, 06:57 AM   #2 (permalink)
Re: Trans out for 04B24 recall
i think u win the most time spent on the rack....
no problems here with mine, other than recalls/service notices for front springs and tranny... i m afraid to bring in to fix for same reasons what s happened to you... figure if tranny blows up, will get new tranny..
i ll have to mention to dealer if i do bring in, make sure u got all the tools for the replacement. i m sure they ll love that..
hope you get back on the road soon.
who did your 4wd conversion ???
'06 navigator,4x4, ultimate, black/grey interior.
'99 e-300 turbo diesel benz, silver, wife s ride
'77 450SL benz in the family since new.
'06 gmc 3500 dmax/allison, cc, slt. black/dark pewter int.
'91 350sdl turbo diesel benz
'06 mazda 6, daughter s ride.
'89 560sl benz, it s official, i m outta room in the driveway.
hapaschold is offline
Old 03-06-2005, 07:46 AM   #3 (permalink)
diesel97's Avatar
Started mine up last week to bring to the dealer to see if they can fix my 2nd to 3rd gear clunk(which they cant)and low and behold as soon as it started the check engine light was on .Ended out being a bad fuel sending unit in the tank.
2005 E-350 SRW CUTAWAY,6.0 DIESEL AUTO,ALLOYS 10FT KNAPHIEDE KUV BODY.SILVER POWER EVERYTHING.
97 F-350 XLT 4X4 7.3 PSD,99K AUTO ,REG CAB,GREEN,NOT STOCK
96 F-250 XLT 4X4 7.3 PSD 220K AUTO REG CAB,BLACK,BONE STOCK EXCEPT FOR A NEW CAR SCENT AIR FRESHENER.
http://community.webshots.com/user/Dzlpwr
#28
diesel97 is offline
Old 03-06-2005, 08:57 AM   #4 (permalink)
Sorry to hear about your extended shop visits
Uprated front springs = 1/2 day in the shop (including mounting up new shocks all round)
add another 1/2 day for the three different times i had castor,camber and toe checked
tranny recall= 1/2 day in the shop.
My service manager hooked me up and opened a service ticket then i took the truck in when the parts arrived-If we had done the recall by the letter it would have been down 3.5 weeks just waiting on the parts.
no leaks, codes or other problems so far [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Frank
2004 6.0L PSD E-350 Superduty Ext. cargo.
http://www.imagestation.com/album/?id=4286001359
racerman_27410 is offline
Old 03-06-2005, 07:22 PM   #5 (permalink)
MikeL46's Avatar
Salem Kroger - See my signature
Mike
Scangauge
MikeL46 is offline
Old 03-06-2005, 07:25 PM   #6 (permalink)
MikeL46's Avatar
Yeah, I had the parts ordered. After they came in, I took the van in and when it was apart they found other parts to replace. After those parts came in, the tech discovered they didn't have the tools to reassemble the trans.
I forgot about the 2 days to replace the front springs. I had them re-align it after the replacement.
Mike
Scangauge
MikeL46 is offline
Old 03-07-2005, 04:51 PM   #7 (permalink)
I'm dropping mine off tomorrow for 1st oil change (5500 miles) and tranny recall check. I absolutely need it back for 2500 mile trip by March 17. Maybe I should reconsider [img]/ubbthreads/images/graemlins/smile.gif[/img] Or ask for a loaner equivalent to mine! hahaha
Pat
2004 E-350 PSD, 4.10 LS , Sportsmobile 4x4 (ProRock 60 axle, Atlas II T/C), Eagles & LT295's
ponart is offline
Old 03-08-2005, 09:16 PM   #8 (permalink)
pon
Tony at Kearny Mesa Ford here in San Diego says they have done quite a few of these already so no parts or tool problems expected. I had thought it was a check and a possible repair but now find out its an immediate reverse planetary replacement. Other than the speedo recal this is the first service visit, also first oil change. $75 oil + filter with maintenance checks, battery, belts, air filters and brakes. Seems reasonable. I declined the tire rotate which also was included. They say 2 days. BTW - Diesel at $2.49 at one of my stations.
Pat
2004 E-350 RB PSD Sportsmobile 4x4, 4.10 LS w/
8" Eagle Alloy w/ BFG LT295/75R16 All Terrain, 13 MPG @ 32K (highest diesel paid - $5.29/gal 07/2008)
1991 Jeep Comanche Long bed, 2200# Bigton package, Dana 44, 3.73, PowrLock LS, 4" lift, National Springs in rear, Tomken front, Callen Camper shell, 31x15 BFG KO Mud Terrains. (my kayak hauler)
2001 330i BMW (the wif's)
1998 Honda Civic (my commuter)
pon is offline
Old 03-08-2005, 11:40 PM   #9 (permalink)
you'll get better tire life if you rotate every 5000-7000 miles otherwise these vans will eat your tires up fast - DAMHIK
Frank
Old 03-09-2005, 12:17 AM   #10 (permalink)
pon
I agree, I just rotated them myself in December with 3000 miles on them. I don't want the air wrenches on my lugnuts and studs.
Pat
Frank
pon is offline
Old 03-11-2005, 03:06 AM   #11 (permalink)
Anyone know if the recall applied to V-10 vans too?
serpexc is offline
Old 03-11-2005, 08:07 PM   #12 (permalink)
pon
I think the recall period was only for 2004 (pickups and vans) for a several month range starting around March. Now it could have been expanded later. So when did V-10's get the 5 speed? 2005?
OK - my van is DONE, 3 days in the shop, will pick up tomorrow. Tony apologized as he forgot I had that extra work involved (Atlas II transfer case). SO, will do some test driving this weekend. (Note that I also log in as PONEIL due to a password snafu between my work and home PC's, cookies make you lazy [img]/ubbthreads/images/graemlins/smile.gif[/img] )
pon is offline
Old 03-11-2005, 11:53 PM   #13 (permalink)
MikeL46's Avatar
Just got off the phone with the dealer. Tech says he has everything he needs and the van will be back on the road Tuesday! That will be exactly 3 weeks after I dropped it off.
I sure hope so!
Mike
Scangauge
MikeL46 is offline
Old 03-12-2005, 07:06 PM   #14 (permalink)
I admire your patience.
However, it sounds like your dealer is less than honest.
It should never take that much time to get parts, tools, etc.
I suspect they are, as often is the case, a poorly managed, smoke blowing, dealership.
The weakest link in the F**d corporate chain are the repair facilities that we consumers are forced to use while our vehicles are still in warranty.
It's really sad.
Yardbrew. [img]/ubbthreads/images/graemlins/mad.gif[/img] [img]/ubbthreads/images/graemlins/mad.gif[/img]
America....love it or leave it
02 E350 PSD Cargo with windows/power/CC/3.55 LS/Prodigy/Reese WD & Dual Cam/....from Cochise
Van Color:Gray--Bumper Color:Gray--Wheel Color:Gray--Hubcaps:metallic--Tire Color:black--Grill Color:gray plastic
I pull a 1987 Wells Cargo Express Wagon (20 ft)
Yardbrew is offline
Old 03-12-2005, 10:23 PM   #15 (permalink)
XRACER's Avatar
If they were right guys, they would add three weeks / 750 miles on to your warranty.
Yeah right.... [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
2005 E350 Standard Cargo Van, 6.0 PSD, 4.10 L.S., Quigley 4X4 New on 11-18-05
(seems to manufacture oil....1 Qt per 4000 miles)
Warranty Turbo 7-07 22,000 miles
Warranty A/C compressor 10-07 25000 miles
2003 E350 Extended Cargo Van, 7.3 PSD, 3.55, Quigley 4X4 New on 2-1-04
Some Pix
Transfer Flow 46 Gal.***Delaminated***Replaced 8-29-06 UNDER WARRANTEE
XM Radio, Alpine GPS Nav. System
7.5' Western Snow Plow
Quad Captain's chairs and Espar Furnace
OX cable locker on front
ARB locker on rear
BTS Tranny 9-29-07 @55,000 miles
Aluminess Bumpers
Mile Marker 12,000 pound hydraulic winch
2000 F250 ...... just cuz people are dumping them for the fuel bill. Got mine on ebay for $8749 with 116K on the clock. Go-fast mods to follow.....
XRACER is offline
Googl
