When mine did that it was the VSS . It threw some codes then it went away . . . I have been checking for codes lately and nothing , so soon I will get under it and either replace the VSS ( 58 bucks ) or put some dielectric grease inside the connector. I have heard the rear ABS thing I have on mine can cause the OD light to flicker as well . It only did it a few times than it went away. . . Pull codes and see whats what . . .
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , HD cooler , Cat sleeps with the fishes , 3:55 D70FF, Michelin LTX " E " ,Not installed yet DP flashed PCM (60 Tow )Autometer Triple Pillar Guage pod , New Injector O-rings /IPR /lift pump / filterbowl @ 235K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
Reason: spelling
