Where's the easiest place to put a sender? I've got a '04 E350 with the 5.4. I read somewhere that there's a "test port" near the trans that you can screw a sender into. I'd rather not have to drill a hole in the pan and braze in an adapter if I can avoid it.
'04 E350 XLT SuperDuty "Crew Van"-3 rear benches removed,
equipment shelving installed.
Specs: 5.4 V8, 3.55 open rear, K & N with modded snorkel, Black Magic Extreme 16" electric puller fan, In-Dash Auto-Meter Phantom electric coolant and ATF temp gauges, Derale Deep Transmission pan cooler, TransGo Shift Kit, Gabriel Hi-Jackers rear air shocks, polished aluminum billet grill, Euro-clear corner lenses with 18 LED amber bulbs, Euro-clear headlights with Sylvania Silverstar Ultra bulbs, Lund bugshield, 55 watt driving lights, stainless trim rings with chrome deep lug nuts, Valley Class 4 Receiver Hitch
Purchased 5/2006 w/44k, 69k as of 3/2008
What kind of sender are you installing? Make sure that you don't have a sensor probe that is too long for the test port. If that happens, it will bottom out and you will strip the threads. Make sure you have teflon on the threads......but don't block the electrical contact. When you take out the plug, don't be alarmed that you aren't getting a stream of transmission fluid coming at you. As I recall, only a few drops.
Yardbrew
America....love it or leave it
02 E350 PSD Cargo with windows/power/CC/3.55 LS/Prodigy/Reese WD & Dual Cam/....from Cochise
Van Color:Gray--Bumper Color:Gray--Wheel Color:Gray--Hubcaps:metallic--Tire Color:black--Grill Color:gray plastic
I pull a 1987 Wells Cargo Express Wagon (20 ft)
Yea, I will be installing the Autometer Phantom gauge too, I don't have it yet so I can't check the length of the sensor probe. Is there an adapter that's needed or does it come with?
Yardbrew
