transferflow tank for a 95 e350 7.3 - Diesel Forum - TheDieselStop.com
Old 04-07-2009, 01:30 AM   #1 (permalink)
Is there any reason why the replacement transferflow tank will not work in a 95 e350 7.3 ? Their website lists 97-up. When I called them they had no answer for me. Are the fuel systems any different on a 97?
Mike
95 F350 crew cab,4x4,auto,4.10s,roll-a-long,162k,285s on alcoas,tymar intake&HPX,4" AFE,beans stage1s,CROSS ENTERPRISES Bumper&Swing Away Tire&Fuel Carrier
00 excursion limited,7.3,CROSS ENTERPRISES Bumper & Swing Away Tire & Fuel Carrier
82 vw diesel rabbit truck
85 bronco 5.0efi
87 jeep yj 5.0 efi,nv4500,atlas,dynatrac hp60 & 44,arb's
http://photos.thedieselstop.com/show...t=1&thecat=998
crossent is offline
Old 04-07-2009, 01:38 AM   #2 (permalink)
van_350sd's Avatar
My Photos: (80)
They stopped making the aft axle 27 Gallon Aux. Tank, on or about 2002.
I bought one for my 2000 E350 van and it was one of the last ones.
They still make tanks for the original fuel tank location for wheelchair vans etc.
The 97 van should be like a 2000 or later van?
Do you want to mount it in the stock tank location? Or do you want to add a second tank for the Aux.?
Man, I'M so happy I bought my van when I did, I got the 7.3L Extended van with the extra fuel tank.
The TF tank I have only works on the extended vans, back then.
You can buy other tanks and even a fuel cell tank in the rear, if you have the extended van.
2000 E350-Super Duty-ExplorerExt. Mobile LivingRoom-7.3LPSD-3:55LS-Dual AmsoilEaA Air Filters-AutoMeter Phantom Guages-Pyro(Pre)-Boost-Tranny+Hobbs Hour Meter-C2 Pyro(Post) WaterTemp - 4"SS MagnaFlow Wrapped w/ Thermo-Tec 2" Header Tape-SonnaxValve+Tricumulator Shift Springs-Mag-Hytec Tranny+Rear End Cover-1 UpFront Spring Option-Bilstein's-Centramatic's-35 Gallon MainTank+TraxII TransferFlow 27 Gallon Aft.Aux.Tank=62 Gallon Range-ACPM/AIC-DualBattery+Alt-450 FilterMAGx2-Fumoto-ALL Amsoil-Bob's 203*&Billet Housing-Alcoa Classics-Explorer Conversion Installed DynaMat Complete Interior - 4 Leather Captain Chairs/BackSeat/Bed-Hellwig Sway Front/Rear-48"Hi-Lift-C02PowerTank5#SnapOn1/2"ImpactMG725-H3RCleanAgentHalotron2.5#
van_350sd is offline
Old 04-07-2009, 03:06 AM   #3 (permalink)
Just thinking of replacing orig side tank. I know the fuel system change on the trucks in 99. I wouldn't think the vans changed much from 95 to 97. Just trying to figure out the differences between the two.
Mike
85 bronco 5.0efi
crossent is offline
Old 04-07-2009, 05:22 PM   #4 (permalink)
carringb's Avatar
Fuel pump flange I think has a different bolt pattern I think. THe actual tank I'm pretty sure is the same.
2000 E350 DRW XLT extended wagon (yes! it's a dually!)
17" Ultra Goliath rims
Banks Powerpack, Diablo Predator
Buckstop front bumper, Reunel rear w/ 20,000# reciever
250,000+
carringb is offline
Old 04-07-2009, 07:54 PM   #5 (permalink)
Ujoint's Avatar
Pretty sure this is correct. The vans either have a bolt in sending unit or a lock in (ring) style. Originally, the T/F tanks were made specifically for the Quigley vans. Quigley moved the front fuel tank support crossmember, and the T/F tank was made for that.
Do it nice or do it twice!!
Ujoint is offline
Old 04-08-2009, 01:19 PM   #6 (permalink)
MikeL46's Avatar
My Photos: (14)
So, you may have to convert to the later style fuel pump and add a front crossmember to support the T-F tank.
You might try visiting a local wrecking yard. They have cross reference books that can tell you what parts from what years exchange. Find out if the pumps or tanks interchange in the 95 and 97 models. If not, you may have to buy the later pump from them anyway - and maybe they will take your pump in trade - never hurts to ask.
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
96,258 miles. 16.63 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
176 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, another Alternator, Turbo hose fitting, Block Heater, Door lock, Front axle seals - all under warranty. AC hose, 1 injector, Batteries not under warranty.
MikeL46 is offline
Old 05-13-2009, 07:41 PM   #7 (permalink)
I called transfer flow to order their 46 gallon mid-ship tank, and they tell me that it is obsolete.
Some of the 4x4 conversion guys get them (they special order them in lots of 10 or more), but as one more middle man and being the only game in town, they charge accordingly.
2003 E-350 14-passenger, 3.73 axle, Quadvan 4x4, AIC, TransferFlow 46 gallon tank, DP tuner, DieHard Platinums, PIAA driving lights, 17" Hakkapelliitas snow tires, 18" Continental ContiTrac summer tires, front receiver hitch
beaker is offline
Old 05-14-2009, 10:33 AM   #8 (permalink)
My Photos: (9)
Boy, they don't make anything for our vans anymore.
2001 E350 PSD, Deep Emerald Green, 3.55 LS, Premium package, dual alts, rear A/C. Quigley 4x4, Transfer Flow rear tank (27+26), handicap mods, custom interior, Reunel tire carrier w/ Hi-Lift, Sportsmobile nerf bars (black), Amsoil lubes and Dual-Gard bypass oil filter, Amsoil air filters, Eclipse/JL Audio sound system w/ Sirius & 120GB Neo Car Jukebox (MP3 player), J&J stainless grill, Reunel Stainless bumper, 12000# Warn winch, PIAA lights, Bilstein shocks, Ultra Magnum wheels, Michelin tires (265/75-16), Correctrack rear wheel spacers, Bushwhacker flares (painted), Velvet-Ride spring shackles, p/s filter, external tranny and coolant filters, Autometer gauges(5), Optima Yellow Tops, Airdog.
msnunes is offline
