Transmission drain tube? - Diesel Forum - TheDieselStop.com
Old 02-28-2007, 04:24 PM   #1 (permalink)
my 91 e350 7.3idi/ 4eod has what appears to be some kind of drain tube sticking out from the torque converter cover. It's about 1/2" diameter, 4 inches long, and points to the rear of the vehicle.
What does it do?
It looks like it's dripping a little bit of ATF while the van is just sitting around lately.
I am trying to track down a terrible engine/powertrain noise at idle )(that goes away with a bit of revving) and am trying to figure out what all these mystery bits are in the process....
thanks.
1991 E350 Vambulance
http://bentmettle.com
bentmettle is offline
Old 02-28-2007, 11:29 PM   #2 (permalink)
Re: Transmission drain tube?
That drain just gives a place for leaking fluids to come out. My guess is your front pump seal is starting to leak.
Dump in a can or two of Trans-X which may slow the leak down and buy you some time.
For your mystery noise, take off the flywheel cover and make sure your torque converter bolts are tight.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 04-08-2007, 12:00 PM   #3 (permalink)
I finally was able to get under the van recently- the flexplate/TC nuts were indeed darn loose in a few cases, and one was backed off 3/8".
I snugged those up and my noise is gone. Now on to the leaks and hard starting....
Old 04-08-2007, 12:09 PM   #4 (permalink)
Go to the dealer and buy new nuts!
They are one time use nuts, they are meant to be replaced at each removal.
Old 04-09-2007, 09:43 PM   #5 (permalink)
I would have never thought of that, thanks.
I suppose they did have some serrations?
I was just pleased it was something so simple, many of the other workshops adventures on the van have been far more difficult to access.
Old 04-09-2007, 11:24 PM   #6 (permalink)
The nuts are actually "crushed" on 2 sides to hold tighter.
Yours probably came loose because they had been re-used.
