Transmission Install - Diesel Forum - TheDieselStop.com
post #1 of 12 (permalink) Old 06-02-2011, 08:57 AM Thread Starter
I posted this under 7.3 Engine and Drive Train but no one has answered and I almost always get more response from my fellow van owners so I am re posting this here.
Any advice and tips would greatly be appreciated here. For the 1st time ever I have dropped the E4OD transmission out of my van. I have a guy rebuilding it and it is supposed to be done tomorrow. I am in need of the following information or the location where I can get it:
1. Torque specs for the six bolts from flywheel to torque converter
2. Torque specs for the bell housing to diesel engine
3. Torque specs for the transmission support brace frame bolts
4. Torque specs for the transmission support brace transmission bolts (bolts bracket to support brace)
5. Torque specs for the transmission support bracket bolts (bolts bracket to transmission)
6. Torque specs for bolts for drive shaft to differential
7. Torque specs for starter mount bolts
8. Torque specs for torque converter inspection plate (in inch or foot lbs.)
9. Torque specs for transmission pan bolts
Other information:
1. What transmission fluid should I used?
2. How much transmission fluid will approximately be needed?
3. Should I pre fill the torque converter before installation? (If so, what is the Torque spec for the fill bolt on the torque converter?)
4. Any suggestions/helpful hints in putting this back together?
5. Lastly, I saw a video on a Chevy transmission flush where after the transmission oil went back in they would start the vehicle, run through Park (wait 5 seconds), Reverse (wait 5 seconds), Neutral (wait 5 seconds), Drive (wait 5 seconds), 2 (wait 5 seconds), 1 (wait 5 seconds), and then back up waiting five seconds between each again frequently checking transmission fluid level while running. Is this the same series for the E4OD?
Thank you all ahead of time for the help….
Dan
1997 E-350 7.3 Diesel high top conversion van. DP Tuner chip with stock, tow 60, economy 80, and HP 100 tunes. IssPro A pillar gauge cluster with tranny, EGT (pre turbo) , and boost. 4 inch exhaust, AIC, IssPro Turbo Temp Monitor auto shut off [like a turbo timer but based off of EGT (post turbo)]. Gear Vendors overdrive in front of a Dana with 4.10 gears.
dcostello is offline
post #2 of 12 (permalink) Old 06-02-2011, 09:56 AM
Mark Kovalsky's Avatar
My Photos: (6)
Use any fluid with a MERCON V rating. Your choice on synthetic or non-synthetic.
18-19 quarts.
No, you should not. The torque converter is probably going to be seated when you get the trans. Removing it is just asking for problems that could get very expen$ive.
After the trans is bolted in place pour 8 quarts of fluid down the dipstick tube. Let the engine run for one minute then shut it off. Add six more quarts, then restart and let it idle to warm up. You have several quarts left to top off. It will need several of them.
Here is how to flush this transmission. You don't need to do it now, everything is new. Changing ATF: 7.3L PowerStroke Engine and 4R100 Automatic Transmission.
Mark
Former
Automatic Transmission Engineer 1988-2007
Mark Kovalsky is online now
post #3 of 12 (permalink) Old 06-02-2011, 12:32 PM
blageurt's Avatar
My Photos: (9)
All numbers are lbs.-ft.
1. 25-34
2. 39-53
3. 50-71
4. 59-81
5. no idea ....I would use 65 and some good thread locker
6. 15-24
7. 20-34
8. 12-17
9. 10-14
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , Twin HD coolers , Cat sleeps with the fishes , 3:55 D60FF, EBPV Delete , DP flashed 60 Tow , 140 V idm , Autometer Triple pod , Bridgestone /Hankook
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 , MSD IGN , Custom C-6 Trans , Dual Exhausts , Bridgestone
blageurt is offline
post #4 of 12 (permalink) Old 06-02-2011, 03:16 PM Thread Starter
Mark, the torque converter was purchased separately from ford. So it is ready to get mounted. I am wondering if it is easier to mount it to the transmission first or the flywheel first.
Blageurt, thanks for the torque specs but those seem like pretty wide ranges. Is there something more specific? Or do I max them because we are talking about the highest torque engine that ford offers in 1997?
Thank you all again for the help....
Dan
post #5 of 12 (permalink) Old 06-02-2011, 05:21 PM
My Photos: (6)
It's nearly impossible to mount it to the flywheel and then install the transmission. I don't think that can be done and have a functioning unit.
Mark
Former
post #6 of 12 (permalink) Old 06-02-2011, 05:46 PM
blageurt's Avatar
My Photos: (9)
That is what my Ford CD says.... I always go for the middle number plus 1 or 2 lbs-ft. You can go max if you want as long as you are in that area it should be OK ...
blageurt is offline
post #7 of 12 (permalink) Old 06-06-2011, 08:06 AM Thread Starter
Well, the transmission is in. It was a lot more work than what I thought but we will see how it goes when I completely get it running. I forgot to order a gasket for my Gear Vendors adapter so I am overnighting that today. All I have left is to mount and connect the gear vendors OD and the drive shaft, start it and top off the transmission fluid.
One question on connecting/adjusting the shift cable and electronic module that slides on over the shift lever. What are you looking for to adjust these? Just make sure that it hits every gear when shifting on the column? I saw somewhere that you adjust the electronic module where in reverse the reverse lights come on, then tighten the adjustment bolts.
Any thoughts or suggestions on this would greatly be appreciated.
Thanks again everyone!!!
Dan
post #8 of 12 (permalink) Old 06-06-2011, 08:21 AM
drinkypoo's Avatar
My Photos: (25)
the shift cable is adjusted by disconnecting it at the trans end, putting a 5lb weight on the shift lever, adjusting the selector to the proper position, then reattaching the cable. or one less step in your case.
1997 Audi A8 Quattro 225k Warm/Cold packages
drinkypoo is offline
post #9 of 12 (permalink) Old 06-07-2011, 11:04 AM Thread Starter
So I am going to be making the shifter adjustments tonight. So are you saying while I have a 5 lb. weight on the shift lever I will have my wife in the driver’s seat holding the column shifter in the middle of park and slide/snap the yellow adjuster on the shift cable into place? Is this correct?
And then am I correct on the electronic module adjustment using the reverse lights as an indicator of where to set the module?
Dan
post #10 of 12 (permalink) Old 06-07-2011, 11:41 AM
drinkypoo's Avatar
My Photos: (25)
no, you just weight the lever so it's held all the way over. getting the needle lined up is a separate adjustment.
not sure about the module, I would have to look that one up.
IIRC the lever is all the way into the "1" position when you adjust it. You also need to put the trans in that position before making your connection and adjustment.
You should scour eBay for factory service manuals, they are often available at a reasonable price.
post #11 of 12 (permalink) Old 06-08-2011, 10:04 AM Thread Starter
Well, all is in and I am driving around town with nice smooth shifts. It took 4 gallons of Mercon and seems to be doing well. One question I had was: Is the torque on the pinion flange to the drive shaft only 15-24 ft lbs. ? That just seems a little light.
Thank you all for all your help here!!! It is great!!!
Dan
post #12 of 12 (permalink) Old 06-23-2011, 02:10 PM Thread Starter
Just wanted to say that I have been driving around for a few weeks and things seem to be much better.
Thanks to all of you for the help!!!
I love this site!
Dan
  Diesel Forum - TheDieselStop.com > Ford Diesels > E-Series Vans
