Old 11-18-2003, 11:03 AM   #1 (permalink)
My Photos: (9)
Trouble with installing shocks???
Having shocks put on today (along with a Warn bumper and winch [img]/ubbthreads/images/graemlins/cool.gif[/img] but that's another story...)
They're having a hell of a time with the left rear shock -- can't get to the top nut. Said that it must have been put on before the body (?), that usually there is an access hole in the body but mine doesn't have one (?). For that matter, the left front shock took them forever as well.
I can't imagine that everyone had had this trouble changing shocks... ?
2001 E350 PSD, Deep Emerald Green, 3.55 LS, Premium package, dual alts, rear A/C. Quigley 4x4, Transfer Flow rear tank (27+26), handicap mods, custom interior, Reunel tire carrier w/ Hi-Lift, Sportsmobile nerf bars (black), Amsoil lubes and Dual-Gard bypass oil filter, Amsoil air filters, Eclipse/JL Audio sound system w/ Sirius & 120GB Neo Car Jukebox (MP3 player), J&J stainless grill, Reunel Stainless bumper, 12000# Warn winch, PIAA lights, Bilstein shocks, Ultra Magnum wheels, Michelin tires (265/75-16), Correctrack rear wheel spacers, Bushwhacker flares (painted), Velvet-Ride spring shackles, p/s filter, external tranny and coolant filters, Wicked Wheel, Autometer gauges(5), 203 thermo, BRV+, removed air intake heater, Optima Yellow Tops, "Harpoon" mod, DP-Tuner, 4" exhaust w/ Aeroturbine, Airdog, HX-mod.
Next on the List: a blown tranny!
msnunes is offline
Old 11-18-2003, 11:09 AM   #2 (permalink)
sixiron's Avatar
My Photos: (11)
Re: Trouble with installing shocks???
I've had same trouble changing out the rear shocks...you have to elevate the body to get to the upper shock nut...its a pia...I also removed a metal shield on the exhaust side to allow more room to get to the upper nut...lol bd
2002 E-350 ext. cargo..4" DP+exhaust/gauges/ CCV mod/ AIH delete/TT mirrors wC-btr's/Amsoil Dual by-pass/Racor 45P prepump/ITP regulated return w/fuel bowl delete/tank mods/203*/timbrens/bilstein/Hella/ DP tuned/BTS trans/ alum baja wheels/cryo rotors...dyno 335 hp...164,062 miles
98 E-350 PSD...575K
04 VW TDI/PD Jetta wagon
cat 2 mic f/filter,CCV/muffler/fuel filler mods,Evo skidplate/ RC1+
sixiron is offline
Old 11-18-2003, 11:49 AM   #3 (permalink)
My Photos: (17)
Do you have to use nut and bolt on those shocks? Could a shouldered pin and cotter pin be used as a replacement?
[img]/ubbthreads/images/graemlins/cool.gif[/img]2001 E-350 SuperDuty<font color="green"> 2wd Sportsmobile, <font color="green">BTS Trans, <font color="green">ITP VAN SPECIFIC fuel system mods,3.5" DP with 4"exhaust, 3 pos "Bill's" chip, Autometer Phantom gauges, Baldwin pre pump filter assembly, <font color="green">Reunel bumpers, Warn 9k winch, PIAA lights, Goodyear Wrangler AT/s tires (265/75 R16), Firestone airbags, <font color="green">Con-Ferr roof rack, Bushwacker Fender flares, <font color="green">Correctrack rear wheel spacers, Rancho 2" lift, </font><font color="orange">PHOTOS</font>
youngster is offline
Old 11-19-2003, 12:43 AM   #4 (permalink)
All four of the top nuts are miserable. On the 97 left rear, I removed the small fuel(gas) tank shield and was able to get a box wrench on the nut and then used a wrench on the hex part at the top of the metal dust cover. Wedge the top wrench in place and turn the bottom wrench. On the right rear, after an hour and a half of struggling, I used a nut splitter with some long socket extensions from the wheel well. Then gently put some vice grips on the nut and turned things from below. If there are two people, reaching in from the wheel well to place and hold a box wrench should be easy. If I had diesel in my tank rather than gas, I would've taken out the cutting torch. I probably should not have, but I put plenty of never sieze on the post of the bilsteins and I used washers and spacers so that the post will not extend up through so high as to make getting a wrench on the top next time so difficult. And there is less than 1/2" of thread above the nut. I check them visually to make sure that they are not loosening.
1994 E-350 RB 5.8gas 4X4Quigley cargo 4.09 arb-locker f/r 35x12.5-16.5 or 285/75-16.,,, 1997 E-350 EB 5.4gas 4X4Quigley Sportsmobile camper 4.10 arb front, L/S rear 285/75-16/front 33X12.5-16.5/rear ><>J
toalpi is offline
Old 11-19-2003, 12:55 AM   #5 (permalink)
I don't recall the rear shocks being much of a problem, but that front left one, my god.. it was ridiculous. I did discover tho that there is an access hole from under the hood to get to it, which should make it easy to get to. We are talking about the drivers side front shock i suppose.. hell.. both were hard to do, but the drivers side one was the hardest.
Eric
Ford 1992 E-350, 6,900 lbs.
Dodge 1997 Ram 3500
Ford 2005 F-350
yaric008 is offline
Old 11-19-2003, 02:00 AM   #6 (permalink)
Eric, could you look at that hole more closely, What are the chances that somebody made that hole? On my 94 I recall using a hammer and a pipe/drift to make some more room in the left front. You guy's without salt and rust have it easy, the 94 was only three years old when I changed shocks the first time, and the right front shock post broke after one very difficult revolution of the nut. When I took off the Rancho's this summer, one front and one rear post broke, but they are a smaller diameter post then the stock shocks or the Bilsteins.
toalpi is offline
Old 11-19-2003, 02:03 AM   #7 (permalink)
I don't think anyone made the whole as we've had the van since new and the hole looks pretty well.. machined, as if it were made that way. I'll see about getting some pictures though.
Eric
Dodge 1997 Ram 3500
Ford 2005 F-350
yaric008 is offline
Old 11-19-2003, 10:39 AM   #8 (permalink)
My Photos: (9)
Well, they got it done. The right side shocks were easy, the left front was a half turn at a time on the nut, and the left rear took two people. I have no access holes anywhere on the truck. They questioned the guy who designed this arrangement...
Thanks.
msnunes is offline
