I just did this. There might be some performance benefits, but the big gain is that it removes one of the big leaking spots on the engine. You need to get a non-ebpv pedestal from dieselsite for about $110 then remove the butterfly valve and plug up the holes with 3/4 inch freeze/expansion plug. So far I see no performance gain or loss, but for the first time since I bought the van I don't drip oil.
2000 E350 Chateau, 7.3 PSD, Ujointclothing DIY 4x4 conversion, Amsoil dual bi-pass oil filter, Amsoil Blue Air Filter, Reunel rear bumper, Bushwacker Fender Flares, and leaf spring front brackets
Thanks, Clark. Ddog gave me some info in another post and I was attempting to delete this one as you were posting. But while we're communicating, mine has never dripped oil, so I'm guessing, that I don't need to worry about it. Just in case I do remove it, ddog suggested knocking out the butterfly and welding the holes closed. Simple job, and he didn't mention anything about buying a new pedestal. Is the new pedestal necessary?
No , but sometimes the shaft that connects to the EBPV leaks oil from the solenoid. I have a spare turbo where the guy just removed the shaft and the solenoid and welded them closed. I like my EBPV it warms the truck up faster in the winter. If it was leaking though It would be a different story. . .
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , HD cooler , Cat sleeps with the fishes , 3:55 D70FF, Michelin LTX " E " ,Not installed yet DP flashed PCM (60 Tow )Autometer Triple Pillar Guage pod , New Injector O-rings /IPR /lift pump / filterbowl @ 235K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
