Decided that the turbo pedestal O-rings had leaked long enough and today was the day to change them out. Got the Vitron (?) (yellow) O-rings from the dealer and had the turbo off and reinstalled in about an hour! That's about 2 hours quicker than I thought it'd take me! Now if only the stock fuel filter wasn't such a hassle to change....
youngster
Well they had to make SOMETHING easy to do on the vans... I guess you found it! [img]/ubbthreads/images/graemlins/smirk.gif[/img] [img]/ubbthreads/images/graemlins/ooo.gif[/img]
youngster
Where did you notice the leak?
I have something leaking down the back of my oil pan... but not a lot.
2001 E350 PSD, Deep Emerald Green, 3.55 LS, Premium package, dual alts, rear A/C. Quigley 4x4, Transfer Flow rear tank (27+26), handicap mods, custom interior, Reunel tire carrier w/ Hi-Lift, Sportsmobile nerf bars (black), Amsoil lubes and Dual-Gard bypass oil filter, Amsoil air filters, Eclipse/JL Audio sound system w/ Sirius & 120GB Neo Car Jukebox (MP3 player), J&J stainless grill, Reunel Stainless bumper, 12000# Warn winch, PIAA lights, Bilstein shocks, Ultra Magnum wheels, Michelin tires (265/75-16), Correctrack rear wheel spacers, Bushwhacker flares (painted), Velvet-Ride spring shackles, p/s filter, external tranny and coolant filters, Wicked Wheel, Autometer gauges(5), 203 thermo, BRV+, removed air intake heater, Optima Yellow Tops, "Harpoon" mod, DP-Tuner, 4" exhaust w/ Aeroturbine, Airdog, HX-mod.
Next on the List: a blown tranny!
I noticed a lot of oil accumulating in the valley. The leak was between the pedestal and the valley so I replaced both upper and lower o rings. I too have the leak coming down the back of the oil pan but I think that leak is from the transmission. I took some pictures with the turbo off if you'd like to see.
youngster
youngster
I wouldn't mind seeing some pictures. No hurry though, just whenever ya get some time, post em up.
I had some oil leakage around the valley. I noticed it dripping from the rear of the motor behind the starter. When I pulled the doghouse it looked like the head gasket was leaking. The turbo pedestal also looked suspicious.
Anyway, it turned out to be the intake manifold hoses. Since the crankcase is vented through the intake (pre-turbo) oil finds its way here and seeps through any loose fittings. A similar, bigger problem exists on the trucks because of all the intercooler plumbing.
I will get some pictures posted by this Saturday. I am also looking at getting some of the "constant torque" clamps for the turbo outlet piping. Have them on my work rig and no leaks. The ones on the van are sure messy and I think changing them out would greatly help on cleanliness.
youngster
