Turbos Gone - What Should I Replace While I'm At It
For the past couple weeks my van has been giving me sporadic SES lights. The light would turn on for a couple minutes and the van would run horribly, and then the light would go out and things would be fine. I was thinking the wiring harness in the valve cover, but I decided to take it to the dealer to get the codes read and... I shouldn't have been surprised because I had to replace the LPOP recently, but the turbo is on the way out and the ICP sensor is misbehaving. While I'm at it I thought that I gut the pedestal and go with a Non-EBV pedestal, replace the up pipes (probably with the bellowed pipes) since I haven't been able to stop the exhaust leak, and remove and clean the fuel bowl since the drain valve doesn't work and I need to replace the fuel line O-rings (according to the dealer) which will hopefully put an end to the small drops of oil I find in my driveway. I have a mild tune, but with today's diesel prices I find most of my driving is in the SLOW lane. I would like to keep my mpg's at a max. Any ideas?
2000 E350 Chateau, 7.3 PSD, Ujointclothing DIY 4x4 conversion, Amsoil dual bi-pass oil filter, Amsoil Blue Air Filter, Reunel rear bumper, Bushwacker Fender Flares, and leaf spring front brackets
Do it nice or do it twice!! Van sponsors: Mickey Thompson, Warn, RBP, Bilstein, Detroit Locker, Atlas Spring, Tuffy Security, Line-X // 06 E350 6.0, Sterling 10.5" rear axle w/Detroit locker, Dynatrac Pro60 front axle w/F550 knuckles & brakes, Knoll Racing front Powerlock, ORU/Lee hydraulic ram assist, Bilstein 5150 series shocks & Nitrogen bump stops, custom dual shock hoops, rear overload airbags, custom front bumper, Warn 16.5 winch,1350CV's front & rear, 1410 yokes, long travel front shaft, RBP 4" stainless exhaust, Atlas custom leaf springs, synthetic winchline, Line-X interior, M/T 38/15.50/20 MTZ's on M/T 20x10 Classic Locks. Thats all I can think of right now!
The Turbonetics ball bearing drop-in replacement has been a huge improvement over stock; I noticed a substantial difference after installing it on my wagon. And for the vans, it's almost a drop in replacement. I had to have only one surface of the new turbo machined and it bolted right up. The machining was easy work too, a twelve year old could have figured out what needed to be done. If you're interested let me know, I'll be glad to explain in further detail.
2001 E-350 ext 15 passenger. 7.3L psd, DP-Tuner 20, 60, 80, 80E, 120race, Overboost Annihilator, Turbonetics BB, 4" DiamondEye turbo-back exhaust, custom fabricated 4" intake, Gold Line rebuilt powder coated calipers, braided stainless soft lines, Precision torque converter, TransGo shift kit, ATS Deep Sump trans pan, AutoMeter Ultralite Boost, Trans temp, EGT and in a three pod pillar and fuel pressure, DP-selector and oil temp in an over head console.
