Re: upgrading brakes
Thanks ddog for the parking brake tip. The back brakes were wayyyy out of adjustment, so much as I almost had a couple of wrecks. After turning the drums and adjusting them, they are great !!!! I thought when you backed up the brakes adjusted ?? Could be an old wives tale. I very rarely use a parking brake in an automatic. Will do the flush when replacing the rotors.
1998.5 E350 7.3 extended cargo with Late model doors ,po.wer windows, locks and mirrors.Isspro gauges from DPPI, Power Slot Cryo rotors from DPPI, Hawk LTS from DPPI,NAPA DOT 4 brake fluid,NAPA calipers,Evans coolant,Dieselsite ac control valve,Dieselsite 203* thermostat,BTS valve body, Amsoil tranny fluid,4WD deep tranny pan from Dieselsite, DieselSite transmission bypass filter,Amsoil dual oil filter, Amsoil 15-40 wt oil,4 inch Warpspeed Performance exhaust,Thermo-Tec Exhaust Insulating Wrap, Bilstein shocks,Line-X 2-06-2009 103,400 miles following added Beans stage II single shot injectors, Air Dog, Beans regulated fuel return with fuel bowl delete, glow plugs and Stancor gp relay, Beans modified IDM, Stealth HPOP stage I, Dominator 66 turbo, DpTuner reflashed factory pcm that was split shot injectors to the single shots, 9 tunes from DP Tuner including decel tune,tuflocs on all doors, Snow water-methanol injection stage 3 installed by Beans Diesel, BTS tranny
