Vacuum pump on 6.0??? - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 02-09-2010, 07:01 PM Thread Starter
Ujoint's Avatar
Has anyone swapped one of these out? Mine took a dump today, and it's not covered under the engine warranty. I'll be swapping it out myself, just looking for any tips. Thanks----Chris
02 E350 7.3 - V4
11 E350 5.4 - V5
ujointoffroad.com
Ujoint is offline
post #2 of 7 (permalink) Old 02-09-2010, 07:06 PM
Mine failed two weeks ago. B/C of the impending storm (we got +2ft of snow) I had the dealer do it for me as I had no time b4 the storm.
My buddy printed out the procedure from a shop he works at.
Basically....
remove or loosen the belt.
Remove 3 bolts that hold the pump on
Swap over the pulley...you'll need a puller and then a press.
Bolt it back up and put the belt back on.
Sent you a PM....
Oogs
2004 6.0 E350 Quigley 4x4 w/ Sportsmobile Conversion.
285/75R16 BFG AT/KO. 3.73 Gears.
Dieselsite Coolant Filter.
Aluminess Front/Rear Bumpers.
125W Solar Panel.
Sportsmobile Trailer on 285/75R16 BFG AT/KO tires w/ dual deep cycle marine batteries, water pump, 10 gal water storage, air compressor, storage box & 15W Solar Panel.
SnowMan Mod / Door Seal Mod
"Blue Spring" Upgrade
ridintall is offline
post #3 of 7 (permalink) Old 02-17-2010, 11:24 PM Thread Starter
Ujoint's Avatar
Swapped it out today, not too bad. I took it out from the top, took about 3.5 hours. Now I have brakes!!!!! Always nice....
02 E350 7.3 - V4
11 E350 5.4 - V5
ujointoffroad.com
Ujoint is offline
post #4 of 7 (permalink) Old 02-24-2010, 09:42 PM
Nice. How much stuff had to come out of the way in order for you to get down there?
125W Solar Panel.
post #5 of 7 (permalink) Old 02-25-2010, 10:24 AM Thread Starter
Ujoint's Avatar
Not too much. The air intake, intercooler line, and I loosened the P/S res. The most difficult part was the lower bolt on the pump. Swapping out the pulley was a real time eater.
02 E350 7.3 - V4
11 E350 5.4 - V5
ujointoffroad.com
Ujoint is offline
post #6 of 7 (permalink) Old 02-25-2010, 11:08 AM
van_350sd's Avatar
My Photos: (80)
Great job,
I could never do a job like that, feels good to do it
yourself and know it's done right.
2000 E350-Super Duty Ext. Mobile LivingRoom-7.3LPSD
van_350sd is offline
post #7 of 7 (permalink) Old 02-25-2010, 06:55 PM Thread Starter
Ujoint's Avatar
Originally Posted by van_350sd View Post
Great job,
Yea, the dealer wanted too much, and I figured I better learn my way around the engine anyway!! I saved a ton of $$ too thanks to Ridintall hooking me up with a good dealer in MI.
02 E350 7.3 - V4
11 E350 5.4 - V5
ujointoffroad.com
Ujoint is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > E-Series Vans
