valve body
I did a search in vans and couldn't find this mentioned. In the truck section it seems if you tow a lot with the stock transmission, replacing the valve body is a common modification. What about vans? BTS seems to be a popular brand. If I am putting in Amsoil tranny fluid it seems like a good time to install a new valve body.
1998.5 E350 7.3 extended cargo with Late model doors ,po.wer windows, locks and mirrors.Isspro gauges from DPPI, Power Slot Cryo rotors from DPPI, Hawk LTS from DPPI,NAPA DOT 4 brake fluid,NAPA calipers,Evans coolant,Dieselsite ac control valve,Dieselsite 203* thermostat,BTS valve body, Amsoil tranny fluid,4WD deep tranny pan from Dieselsite, DieselSite transmission bypass filter,Amsoil dual oil filter, Amsoil 15-40 wt oil,4 inch Warpspeed Performance exhaust,Thermo-Tec Exhaust Insulating Wrap, Bilstein shocks,Line-X 2-06-2009 103,400 miles following added Beans stage II single shot injectors, Air Dog, Beans regulated fuel return with fuel bowl delete, glow plugs and Stancor gp relay, Beans modified IDM, Stealth HPOP stage I, Dominator 66 turbo, DpTuner reflashed factory pcm that was split shot injectors to the single shots, 9 tunes from DP Tuner including decel tune,tuflocs on all doors, Snow water-methanol injection stage 3 installed by Beans Diesel, BTS tranny
