Hey everyone,
I have a 2002 e350 psd. Yesterday, all fine. went 200 miles all good.
today, went to go to work and when it first started up it sounded like glow plugs didn't have a chance to heat up? it started a little slower and chunkier than normal.
i got about 4 blocks away from my house and it died. I was able to restart eventually, and limp it home. i let it idle for awhile and drove it again around the block. it seemed all OK until i floored it then it sputtered and i barely made it home. no light, so im guessing no codes?
I changed the cps just for kicks, but no avail.
any help would be appreciated, thanks.
2002 E-350 ext. Fire survivor!! POWERSTROKE cargo w/divider...new blue paint, all panels dynamated, 220K
Rockin stereo Alpine, xtant, Boston Acoustics, JL Audio.
Hey thanks for the reply...man, i feel dumb.
yes, i was like 6 quarts low!!! and what is most concerning is i just changed my oil 1000 miles ago. the only change is i switched to synthetic at that time.
any idea why i am losing so much oil?
now with oil in it, it runs, but not very well.
Yes, filter is black...
a am seeing some light colored smoke, when i never saw any before.
can there be codes stored when there is no ses light present? or can it tell me if it is injector or turbo??
van seems to be running about 90% with a slightly rougher idle than before.
You need to monitor the consumption and drive normally. If the consumption is constant and the filter gets black right away it's the o-rings. I drove my truck until it failed ( never started again ) before I replaced the o-rings. Big difference in oil consumption and starting with new o-rings. If you accellerate hard and you see blue smoke it could be the Turbo or a combination of both. How many miles on the ***** ?
I just read your sig and if the o-rings are original then you need to replace them at 220 k for sure. Get them from International. They are cheaper than Ford. Make sure to buy end rail plugs too . . .
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , Twin HD coolers , Cat sleeps with the fishes , 3:55 D70FF, Michelin LTX " E " , DP flashed 60 Tow , 140 V idm , Autometer Triple Pillar Guage pod , New Injector O-rings /IPR /lift pump / filterbowl @ 235K , Timbrens SES kit , replaced lift pump /ICP/ IDM @ 256 K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
