Old 08-28-2003, 09:11 PM   #1 (permalink)
My Photos: (13)
Vannies it can be done!!!
YES!!! [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img]
A F-350 Instrument cluster can be installed in a van!!!
Just installed a 00 cluster in my 97.
Now i have a oem tach, and some additional idot lamps--4x4high,4x4low,low on fuel,cruise control set,ect.
Physical install easy. [img]/ubbthreads/images/graemlins/smile.gif[/img]
Wiring - Scale 1 to 10 its a 9. [img]/ubbthreads/images/graemlins/bleh.gif[/img]
16hrs labor. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Have to get some picts. It looks as if it was born this way.
BILL----MADVAN
97 E-350 Quigley Van Picts
Supporter/User of THE CURE E4OD/4R100 Transmission Control
WWW.FORDTRANSMISSIONCURE.COM
TO RENT THIS SPACE SEE YOUR ADMINISTRATOR
ads@thedieselstop.com.
MADVAN is offline
Old 08-28-2003, 10:27 PM   #2 (permalink)
Re: Vannies it can be done!!!
Awesome!! [img]/ubbthreads/images/graemlins/cool.gif[/img]
Get some pics up as soon as you can. [img]/ubbthreads/images/graemlins/wink.gif[/img]
2000 E-350 Van,<font color="blue">BTS Tranny</font>,<font color="red">Custom Dana 80 Axle w/ ARB & 3:55 Gears</font>,TS 50/75/125/140 Chip,TS Billet Intakes,W/Wheel,PS2000,Magnaflow 4" Exhaust,ITP Van Specific Fuel Regulator/Tank Mods,Baldwin Pre Pump Filter Assy,TTM,CTI Idle Controller,Amsoil Fluids,Evans,203 Thermostat,Coolant Filter,Lighted Logos,Nerf Bars,J&J S.S. Grill,Art Rotors,Custom Flame Job,Road Armor Bumper,Warn M15000 Winch,Bushwacker Flares,Bilstein Shocks,Centerlines,Maghytec Covers. <font color="blue">PHOTOS</font><font color="red">[b] FUTURE MODS[b]</font>: Custom Ladder Bars,Psycho HPOP,Injectors,Water Injection.
04 Rubicon
RE 5.5" LA Lift,1"body/eng.lift,Banks Header/Stinger Exh.,35" MTRS,Mickey Thomson Classic 2 beadlocks,Road Armor Bumpers,Warn 9500ti winch,Alloy Usa axleshafts,CTM u-joints,Nth degree oil pan skid,Currie LCA skids. Future Mods88 Gears,37's,custom roll cage.
Aceman is offline
Old 08-28-2003, 11:54 PM   #3 (permalink)
Wooohooo! Do share the details my friend... perhaps we should name this after you... Madvaning your van perhaps?
Eric
Ford 1992 E-350, 6,900 lbs.
Dodge 1997 Ram 3500
Ford 2005 F-350
yaric008 is offline
Old 08-29-2003, 02:10 PM   #4 (permalink)
Really!!,
How about my 96? I pulled my cluster to clean it and thought it looked similar to the one in a 99 at work. Everytime I drive the van I am looking for the tach, really do miss it like the one in my 95 F model.
1999 F-350 crewcab 4x4 SRW (former 4x2)
2000 F-350 reg cab 4x4 dually
DieselDeaf is online now
Old 08-29-2003, 09:03 PM   #5 (permalink)
My Photos: (13)
Last night i found a flaw in the cluster conversion. [img]/ubbthreads/images/graemlins/frown.gif[/img]
Something i never thought about till i drove at night. [img]/ubbthreads/images/graemlins/frown.gif[/img]
In 97 the cluster lights up blue. The f-cluster lights up green.
Now cluster is green and the radio/center dash is blue.
Looks ok but not perfection. Might changeover to the indyglo face.
BTW--does anyone's van dash light up green. Maybe there is a change over year to green. [img]/ubbthreads/images/graemlins/eek.gif[/img]
Chime in your year and color.
BILL
MADVAN is offline
Old 08-29-2003, 09:26 PM   #6 (permalink)
1992, green for me..
www.samantha.cc/Truck/truck3.html
From 92-96 it's green like mine, i wonder if the wiring up and what not would be the same as what you did on the earlier vans like mine..
Eric
Dodge 1997 Ram 3500
Ford 2005 F-350
yaric008 is offline
Old 08-29-2003, 10:19 PM   #7 (permalink)
What makes the color? Maybe you can change the bulbs. But then again the plastic may be tinted diffusing the light in it's color. Maybe the bulbs have tinted covers on them? You are talking Superduty cluster, right? Now that I think about it I doubt if they would fit in my 96, SD's didn't even exist when mine was built. You aren't talking about the HD 97 and back clusters, are ya? I'm getting confused, didn't they change to a mechanical odometer on the SD's?
Old 08-29-2003, 11:33 PM   #8 (permalink)
the lighting is because of the tinted color duffusing stuff. The bulbs are just little 12 volt lights and have no tinting. I believe the super duty ones are green sorta like mine but the dials are orange, mine and/or ours is white dials, which i like however it would be nice to have a factory tach.
His wasn't built when super duties were around either, however they use this great stuff that's called interchangable parts, [img]/ubbthreads/images/graemlins/grin.gif[/img]. So basically they are built to fit in the same space. Apparently the super duty clusters are the same size as at least the 97 van clusters. Dunno about the 92-96 yet. I know in 99 and 00 they used mechanical odo's, i believe the brand new trucks are digital odo's. but uh.. i dunno.
Eric
Dodge 1997 Ram 3500
Ford 2005 F-350
yaric008 is offline
Old 08-30-2003, 06:27 PM   #9 (permalink)
My Photos: (13)
I used a 2000 cluster. From 99 to 01 f-series the connectors to the cluster are the same as the 97 van, you just need a few more connector pins. You have to change the pinouts and some of the switching circuits from neg to positive/ pos to neg. The 99/01 cluster has the same odmeter as my van. The 02 and later f-cluster is digi readout and is completly different than the 97 cluster and pcm. Now the 97 van was the changeover year to the new dashboard that is still the same as of 03.
Now Iam wondering if there is a change in the color of the lighting from 97 to 03 in a van from blue to green. If its true i need to replace the fan/ac/heat control to a green one along with a radio to have a 100% match.
BTW--I have found the pinouts in the wiring dig for the e/f trucks are wrong seems to be a print error. Some connectors are reversed. This is in the clusters. pin1=pin16, pin2=pin15 ect.
BILL--MADVAN
MADVAN is offline
Old 09-02-2003, 07:07 AM   #10 (permalink)
Way to go Bill!!! [img]/ubbthreads/images/graemlins/smile.gif[/img] Really makes me wonder why they don't just install those from the factory--cost cutting, I guess. Sounds like a big project, maybe someday...(I'll add it to the growing list [img]/ubbthreads/images/graemlins/wink.gif[/img])
Vince,
2001 E-350 Chateau Quigley--SOLD!!! 7.3 liter PSD, Oxford White Clearcoat/Medium Parchment Cloth, 3.55 limited slip axles, dual alternators, AIC, factory running boards, privacy glass, power driver seat. UPGRADES: Alcoa wheels, Lund Moonvisor, 4 passenger Medium Parchment Cloth rear bench seat (11 passenger Chateau now), Cobra 2000 watt inverter, 46 gal TransferFlow tank, Velvet Ride shackles, CorrecTrack Rear Wheel Spacers, Rancho 9000 shocks. Great family truckster for me, the wife, & 5 kids.
dadof5arrows is offline
Old 09-02-2003, 11:35 AM   #11 (permalink)
Well, the factory does have a little sense at least. The '04 clusters have a tach finally.
2000 E350 DRW XLT wagon
carringb is offline
Old 09-20-2003, 01:28 PM   #12 (permalink)
My Photos: (15)
in the change over of the insterment group, what about the tach, if the f group has the tach, was there a wire or wires for you to hook on to for the tach that came with the f insterment panel?
been thinking of adding a tach to my van, and was wondering if there was already wireing there for the tach to just hook in to, or if the senor kit that comes with some tachs was what I am going to need to add.
The van is back..........(song of elton john... the B.... is back....)
But boy does it need that program.......
"FAILURE IS NOT AN OPTION" 2000 E350 7.3PSD, Hellwig Stablizer bar, Headlight Harness upgrade from: http://www.suvlights.com/ 265/75/16E, 140 Lightforce w/blue, yellow, clear covers. My Photos http://photos.thedieselstop.com/showgall...&stype=&ppuser=
Alaskapsdvan is offline
Old 09-20-2003, 05:27 PM   #13 (permalink)
My Photos: (13)
Alaskapsdvan
Your question is what started this whole cluster install. Their are no aftermarket tachs available that will work useing the factory wireing. Aftermarket tachs work on a pulse and the factory works on HZ. You could just install and AIC and be done. The aftermarket tachs are wired to the alt or the damper of the motor. I wanted an OEM tach just like the F-series. In the van the PCM has the pinout for the tach and is dropped off in the harness. All i had to do was splice into the wire to operate the tach.
BTW- In 2000 the vans cluster is green. I have a buddy of mine donate his heat/ac control so now my dash is all green, but of course i like the blue better.
BILL
MADVAN is offline
Old 09-24-2003, 12:58 PM   #14 (permalink)
7up
Bill,
I Leave You Alone For A Little While And Look What You Go And Do!!!
You Were Telling Me The Last Time I Saw You About Your Idea But Holy Conolies Your Just To Fast For Me.Talk About Determination Bill.I Definetly Got To See This. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Tony
Ordered 9/12/02 Bld.12/6/02 Deliv.12/23/02 Quigley Conv.12/27/02*2/03/03 FINALLY!2/8/03
03 E350 Chateau*P.S.D/138"WB/3.55LS*Estate Grn.W/Mineral Grey*Med.Pebble Leather Seats/6 way Pwr*Digital Research 15"+3/7" Vid.Mon.*PS2*Quigley 4X4*SSB Midland Mobile(Booted)/Cophased Whips/6 Boston 2Way 6"/2-12"McCaully Drivers/Head Unit/Nav Powered By Alpine
MY WEBSITE www.MAJESTICSOUNDSDJ.COM
7up is offline
Old 05-22-2004, 04:32 PM   #15 (permalink)
My Photos: (10)
do you remember more specifics about what pin or wire color to tap into?
2000 E350 "Big Sexy" 7.3 4x4 spicer 24 tranfercase has 2wheel low 265/75/16 3.73 ratio
Top Of the Rockies
<font color="blue">Van Pic</font>
<font color="blue">1965 22' SilverStreak Saber</font>
htvans is offline
Not a member ye
