VANNIES YOUR EGT'S
Compare EGT'S
Test - Ambient temp 40deg, 65 mph, flat road, 3miles,400lb load in van.
My data: gauge post, mounted 1in from EPR. Driven at 60 on CC due to speedo error, 60mph on speedo = 64.5mph. O.D. on. Propane was leaned out as much as possible, running just enough to kick off fuel.
Test: A- 3lbs boost, 425deg ex, 240deg oil temp
B- + 10X MOD- 3.5lbs boost, 425deg ex, 240 oil
C- 10X + Propane- 4lbs boost, 400deg ex, 240 oil. Propane tank iced up again during test.
What are your numbers?
BILL-MADVAN- [img]/ubbthreads/images/graemlins/smokin.gif[/img]
97 E-350 Quigley Van Picts
Supporter/User of THE CURE E4OD/4R100 Transmission Control
WWW.FORDTRANSMISSIONCURE.COM
TO RENT THIS SPACE SEE YOUR ADMINISTRATOR
ads@thedieselstop.com.
