Old 11-29-2007, 09:42 AM   #1 (permalink)
VSS
HELP - i am at wits end! my computer looses touch with the differential mounted VSS almost every time i drive my 1995 E350 7.3L. most times it will re-establish comm but maybe not. i have tarced the pair of wires ( twisted pair - yellow and green i believe) leading away from the VSS, cycling any connectors, lookin for faults or corosion and as far as where they go through the firewall to a point behind the dash, i assume to the speedo module, to no avail. i feel like the running path of the wires is clean and the connectors are solid. any ideas? oh i have replaced the sensor - twice. once with an after market part and again with a ford part. thanks for any advice - R
edit: does the VSS give the speedo it's info? if so the problem could be between the speedo and the CPU. the simpdoms of the info lose are eratic auto-tranny shifts and wrong gear choices.
1995 E350 PSD cargo - No Mods to date - likes to go camping with the black lab and wife - pulls the boat real good!
gunksvan is offline
Old 11-29-2007, 10:06 AM   #2 (permalink)
Re: VSS
Mine was the same symptom...
Broken wire, inside the insulation,, had to feel for the break, couldn't see it...
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer"....
Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
fordtransmissioncure.com
Special thanks to RacerX
racerxautomotive.com
action4478 is offline
Old 11-29-2007, 11:16 AM   #3 (permalink)
My Photos: (13)
Re: VSS
Check for sensor and wiring on tail of trans.
Bill
97 E-350 Quigley Van Picts
Supporter/User of THE CURE E4OD/4R100 Transmission Control
WWW.FORDTRANSMISSIONCURE.COM
TO RENT THIS SPACE SEE YOUR ADMINISTRATOR
ads@thedieselstop.com.
MADVAN is offline
Old 11-29-2007, 11:46 AM   #4 (permalink)
Re: VSS
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: MADVAN</div><div class="ubbcode-body">Check for sensor and wiring on tail of trans.
Bill </div></div>I missed the E part ,,
Imagine that....
Rick.....
Old 11-29-2007, 12:07 PM   #5 (permalink)
Re: VSS
how did you eventually find that? - where was the break? - what was your correction? thanks - R
gunksvan is offline
Old 11-29-2007, 12:09 PM   #6 (permalink)
Re: VSS
thanks bill, but not sure i understand what i'm lookin for there.
gunksvan is offline
Old 11-29-2007, 12:11 PM   #7 (permalink)
Re: VSS
not hard to imagine - not many E type PSD's - thanks
gunksvan is offline
Old 11-29-2007, 12:24 PM   #8 (permalink)
Re: VSS
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: gunksvan</div><div class="ubbcode-body">how did you eventually find that? - where was the break? - what was your correction? thanks - R </div></div>
Having the wire in your hands ,bending it , you will feel the break , or pulling on it every few inches,, mine was between the frame & the rear axle sensor,might have gotten caught on something,, soldered it , shrink tube for repair,, the break inside the wire ,was making contact most of the time, I finally noticed it most when I hit a bump in the road...
Rick.....
Old 11-29-2007, 12:40 PM   #9 (permalink)
Re: VSS
good - think i'll run a new (temp) pair for conformation - see if that's my problem. that's a tuff one - wonder how they (it) became broken? thanks
gunksvan is offline
Old 11-29-2007, 01:03 PM   #10 (permalink)
My Photos: (13)
Re: VSS
E-series (some years). The sensor on the rear is for ABS and VSS will be on drivers side of trans by the output shaft.
Bill
MADVAN is offline
Old 11-29-2007, 11:18 PM   #11 (permalink)
Re: VSS
also use some di electric grease on the connections old connection sometimes lose continuity ,wade
2002 E350 EXT. Cargo 7.3PSD , silver metallic , bought new presently 178K , dual alts. , auxiliary idle control , rear a/c heat , premium group , michellin LTX M/S on AMERICAN RACING WHEELS outlaw II's , centramatic balancers , optima yellow tops not worth the extra money imo weak at best replaced with wal-mart everstart maxx more snap 1/3 the price , ITP in tank mods van specific , ITP prepump filter,ITP regulated return system van specific , DP-TUNER F5, stock,40 tow,80 econo,120 extreme , NON-EBPV turbo pedistel DIESELSITE viton o-rings ,K&N filters tempararelly till i devise a better set up , more modds on way
FULLAUTO is offline
Old 11-30-2007, 09:12 AM   #12 (permalink)
Re: VSS
I second what MADVAN is saying. On my van the sensor on the rear axle is for ABS, the sensor on the tail cone of the transmission is for the speedometer. Are you chasing the wrong wire??
2001 E350 7.3ltr PSD SportsMobile with 4x4 Conversion. 4" lift, Coils front, blocks and leaf back, Super Duty Dana 60 axles, 3.73 gears, Air locker rear, NV271 transfer case, 46 gallon fuel tank, Viar air compressor, Custom rear bumper, Tire rack, Baja box, Mickey Thompson Classic II 17x9 wheels, BFG all terrains 285/70-17 (32.8"), 300+ watt solar system, bumpin stereo, and some other cool stuff.
panion is offline
Old 12-03-2007, 03:48 PM   #13 (permalink)
Re: VSS
thanks bill - i'll chk there.
gunksvan is offline
