Re: What engines fit in 84 E350?
The 7.3 NA is the same block, bolts right in. I'm assuming in a van you have an automatic, I recommend finding an auto 7.3 with the flex plate out of another van, as some of the fuel injector lines and the fuel filter location are different on the pickup. Glow plugs, controller, and wiring harness may or may not be different, depending on the year.
The vans used the same body/chassis from 74-91, so an engine up to 91 would go in the easiest. The later engines might have some different brackets, etc for the different body/chassis.
*ASE Master Certified, Medium & Heavy Trucks*
