What is up with my intake? - Diesel Forum - TheDieselStop.com
Old 07-29-2007, 01:42 PM   #1 (permalink)
Hi guys, I have an 03 E350 7.3 PSD. I was wondering if any of you know what is the box that is in between the air box and turbo? The intake tube tee's off and goes to this box which is mounted right behind the fuel bowl. I cannot see anything that goes to this box. Have any of you replaced the factory intake tube with a tube that runs from the air box straight to the turbo? Thanks, Nick
NSF250 is offline
Old 07-29-2007, 02:34 PM   #2 (permalink)
Re: What is up with my intake?
I've been wondering the same thing!!
2003 E-350 7.3, 38R, DIY intake, 4" turbo back, Swamps Tunes, forged rods, exhaust ported heads, comp 910's, h-11's, stealth twin pumps, 300cc hybrids, racerx trans and tc, water injection
rpm1 is offline
Old 07-29-2007, 05:08 PM   #3 (permalink)
it is a resonater box , you can remove but most guys report an anoyying drone noise when they remove,Wade
2002 E350 EXT. Cargo 7.3PSD , silver metallic , bought new presently 240K , dual alts. , auxiliary idle control , rear a/c heat , premium group , michellin LTX M/S on AMERICAN RACING WHEELS outlaw II's , centramatic balancers , wal-mart everstart maxx , AIH delete , Evans coolant conversion , 203 degree thermostat , ITP in tank mods van specific , ITP prepump filter,ITP regulated return system van specific , ITP valley line kit ,Beans stage one single shots , DP-TUNER F5 custom tunes for singles , stock,drive through,40 tow,80 econo,120 extreme,tables raised so i don't set codes overboost etc. , NON-EBPV turbo pedistel DIESELSITE viton o-rings ,paper filters temperarily until i devise a better set up , 4'' exhaust on way
FULLAUTO is offline
Old 07-29-2007, 06:29 PM   #4 (permalink)
Some resonate......some don't.
Mine doesn't do it at any speed.
I pulled mine after the first couple of times trying to work around it (like it's not tight enough without it [img]/ubbthreads/images/graemlins/smile.gif[/img] ).
The second time I pulled it out.......just decided to cap it off and see if it resonated. Never did.....so it just stayed off. It does make it a bit easier to move around in there.
99 7.3L PS E-350XLSD with Ambulatory roof.
(((XM))) Satellite Radio
4" turbo back Diamond Eye exhaust (portadiesel)
Pair of K&N High flow filters
HPX Hose from D.I. (blew out.....pulled it and plugged now)
In-tank and prepump mods (homemade version)
203* thermostat (dieselsite)
Tru-Cool 4739 MAX Transmission cooler (dieselsite)
Boost Relief Valve (dieselsite)
Pillar mount Di-Pricol gauge set
Sonax/tricumulator (Black Cloud)
Jody flashed econo tune PCM (DP-Tuner)
Van specific regulated fuel return (ITP)
70k miles driven annually...mostly pulling 8 1/2 foot tall 7x14 enclosed trailer
Cruise on at 61mph and 1736rpm's I don't stop 'till she needs more go juice!
stroked_van is offline
Old 07-29-2007, 06:44 PM   #5 (permalink)
I wish I could leave mine off!
1999 E350 7.3psd , XLT , 15 pass/ext , purchased 6/6/05 w/255k on odo, 8/05 added BTM/straight pipe,5/06 BTS,1"shimmed front coil springs,Michelin XPS 235/85 16 R.,FredGroeske2"rear wheel spacers,1-1/2" rear sway bar,AIC,3 A-pillar guages, Tekonsha envoy,coolant filter,4 pos dp-tuner,In-tank mod & harpooned,dahl-100 prepumpfilter,Scan-guage,Bilstein shocks.
bork is online now
Old 07-29-2007, 06:53 PM   #6 (permalink)
My Photos: (10)
Seems if you have the newer style turbo wheel its not to bad.
Change over was 98 or 99 don't remember.
Mine is old style (97)(WW). Makes alot of intake noise.
I would love to toss it.(resonator)
Bill
MADVAN is offline
Old 07-31-2007, 12:31 AM   #7 (permalink)
blageurt's Avatar
I also will cap mine with 2" abs pipe when I upgrade my Turbo intake tube with the hard Black rubber deal I found on Ebay , instead of the orange soft rubber crap. I don't understand why they put such retarded stuff in the vans in the first place. I also installed the WW . When the gatto takes a permanent vacation and I get my PCM flashed it will be a big improvement . I don't care about noise since My Ladders make lots of it. Whoever designed that stupid box should be crucified worse than Jesus.
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , Twin HD coolers , Cat sleeps with the fishes , 3:55 D70FF, Michelin LTX " E " , DP flashed 60 Tow , 140 V idm , Autometer Triple Pillar Guage pod , New Injector O-rings /IPR /lift pump / filterbowl @ 235K , Timbrens SES kit , replaced lift pump /ICP/ IDM @ 256 K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
blageurt is offline
Old 07-31-2007, 10:30 AM   #8 (permalink)
My Photos: (10)
Blageurt
Why did you upgrade to the WW?
Bill
MADVAN is offline
Old 07-31-2007, 11:07 AM   #9 (permalink)
That orange tube must be on the older vans, I have the black tube in there. Couldn't you just get a piece of hose to run right from the airbox to the turbo bypassing that stupid resonator box?
NSF250 is offline
Old 07-31-2007, 02:24 PM   #10 (permalink)
blageurt's Avatar
MadVan
The reason I upgraded was my compressor wheel was really nicked and Jeremy @ LIPD made me a deal I could not refuse for the upgrade so I did it . . . the price was right. [img]/ubbthreads/images/graemlins/grin.gif[/img]
1990 KX500
blageurt is offline
Old 07-31-2007, 02:31 PM   #11 (permalink)
My Photos: (10)
I wondered if the old was damaged.
The OEM and WW are the same wheel in your year van.
Bill
MADVAN is offline
