what year extended van has biggest cargo space? - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 06-30-2006, 10:05 AM Thread Starter
My Photos: (9)
Anyone know the answer? I am looking for interior width and height. Also, what is the first year a diesel was available in the E series?
88 E350 7.3 C6 154k
done: Remanufactured Inj pump, New Stanadyne injectors, Michelin M/S tires, ShellZone AF & Fleetrite SCA, replaced and relocated fuel filter assembly, elec fuel pump, no flying saucer, return lines/ o-ring kit, new heater core, 8 Beru glow plugs, oil & filter, stabilator on sliding door (plastic slider cracked in half)
Hot compression readings:
2. 500 1. 500
4. 460 3. 420
6. 540 5. 465
8. 480 7. 540
to do: transmission fluid, fix rust spots, WVO conversion.........
nubiecanobie is offline
post #2 of 4 (permalink) Old 06-30-2006, 11:12 AM
Re: what year extended van has biggest cargo space?
Well since 92 all the cargo spaces are probably almost exactly the same size. The first year for a diesel van i think was 83 or so. Don't know if those were bigger or not, but i'm thinking they weren't.
Eric
, 6,900 lbs.
Dodge 1997 Ram 3500
yaric008 is offline
post #3 of 4 (permalink) Old 06-30-2006, 12:06 PM
Well you only have 2 generations of "modern" Econolines. 75 - 91 and 92 up. I doubt that there is an appreciable difference in the interior room between the two.
The only way you are going to get more height is to get a high top like my ambulance. Even that isn't a whole lot more room.
Your other option is to get a box van. They are plentiful and sell cheap. The drawback is you give up being able to fit into parking spots.
1997 Ford F350 SRW 7.3L PSD
1985 Ford Ranger 2.3L 5 speed
1966 Mustang 200 I6, auto, 4 wheel disk, power brake retrofit, Corvette master.
Former vehicles, 1994 E350 7.3L IDI, 1985 International 1654 rollback, 6.9L IDI, (2) 1994 Ford E350 7.3L IDI, 1985 Ford F350 DRW 6.9L IDI, 1985 Ford F350 wrecker 6.9L IDI.
*dual ASE Master Certified, Automotive, Medium & Heavy trucks*
Owner / operator, Patriot Automotive, N Ridgeville OH
Mr_Roboto is offline
post #4 of 4 (permalink) Old 07-04-2006, 10:36 AM
Super_Dave's Avatar
Shuttle bus...
I can still fit into parking spots. The duals only just fit, but the front is normal...so, you have room on either side.
And the Power Stroke wasn't available until 1995 in the van. Depending upon your usage, that might be a better diesel.
Super Dave
2006 E350 6.0PSD, 2002 Jetta TDI, 1998 Jetta TDI
2003 Excursion Limited 4WD 7.3PSD - Sold, 1996 E350 Super Duty bus 7.3PSD - Sold
Super_Dave is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > E-Series Vans
