Old 07-15-2008, 07:10 PM   #1 (permalink)
What's a good exhaust system to add MPG and performance
Hey everybody,
What's a good exhaust system to add MPG and performance to a 2000 E350 15 Passenger 7.3 van I just pick up? It's got high miles but runs good. I'm looking at a 4" complete system with down tube...?
2007 Ford F150 Supercrew
2005 E350 6.0 Cargo
2000 E350 15 Pass van
Amsoil oil & filters for all
Last edited by racefan7903 : 07-15-2008 at 07:17 PM. Reason: adding and miss spellings
racefan7903 is offline
Old 07-15-2008, 11:04 PM   #2 (permalink)
blageurt's Avatar
Warpspeedperformance.com
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , HD cooler , 3:55 D70FF, Michelin LTX " E "
Not installed yet DP flashed PCM (60 Tow )Autometer Triple Pillar Guage pod ,New Injector O-rings /IPR /lift pump /filterbowl @ 235K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
blageurt is offline
Old 07-16-2008, 07:15 AM   #3 (permalink)
anash13's Avatar
Morning:
I would suggest you contact Dennis at ITP he has a nice 4" system that will do just what you are asking.
Mine works GREAT.
2003, E-350, XLT, Chateau, 7-Pass. Club Wagan, 7.3L PSD, 3:55 LS Rear, SuperChip, AMSOIL TS-126 Air Filter, Fleetguard LF-9027 Bypass Oil filter, Sirius Satellite Radio, Garmin GPS, SuperCrewzer, AutoMeter (Pyro. Trans. Boost)Gauges, 4" Diamond Eye Turbo Back Exhaust, Sonnax valve & Tricululator springs, PML Alum. Tran's Oil Pan, Tru-Cool 4739 Tran's Cooler, ScanGuage Monitor, DAHL 100 Fuel Filter, "Last of the 7.3's".
USMC-(Ret).
You Don't Always Get What You Want, But If You Try Your Mind, You Just Might Find, YOU GET WHAT YOU NEED.
anash13 is offline
Old 07-16-2008, 07:49 AM   #4 (permalink)
fddriver2's Avatar
I like my stainless steel Magnaflow's. Got one on my Expedition & F-250 powerstroke... Not to loud and last forever.. My $.02.
2002 F-250 XLT CC SB\HPX\ITP prepump mod\Harpoon\DI 65psi fuel shim\4" SS turbo back Magnaflow\Fumoto\FTVB\203* T-stat\Edge Evolution2\Zoodad
fddriver2 is offline
Old 07-16-2008, 08:38 PM   #5 (permalink)
sixiron's Avatar
My Photos: (11)
best bang for the buck
2002 E-350 ext. cargo..4" DP+exhaust/gauges/ CCV mod/ AIH delete/TT mirrors wC-btr's/Amsoil Dual by-pass/Racor 45P prepump/ITP regulated return w/fuel bowl delete/tank mods/203*/timbrens/bilstein/Hella/ DP tuned/BTS trans/ alum baja wheels/cryo rotors...dyno 335 hp...164,062 miles
98 E-350 PSD...575K
04 VW TDI/PD Jetta wagon
cat 2 mic f/filter,CCV/muffler/fuel filler mods,Evo skidplate/ RC1+
sixiron is offline
Old 07-17-2008, 02:43 AM   #6 (permalink)
yep, warpspeed is it.
2001 E-350 ext 15 passenger. 7.3L psd, DP-Tuner 20, 60, 80, 80E, 120race, Overboost Annihilator, Turbonetics BB, 4" DiamondEye turbo-back exhaust, custom fabricated 4" intake, Gold Line rebuilt powder coated calipers, braided stainless soft lines, Precision torque converter, TransGo shift kit, ATS Deep Sump trans pan, AutoMeter Ultralite Boost, Trans temp, EGT and in a three pod pillar and fuel pressure, DP-selector and oil temp in an over head console.
New motor in progress.
deltadrummer1 is offline
Old 07-31-2008, 01:05 PM   #7 (permalink)
clev's Avatar
My Photos: (14)
Along the same lines, I assume the 'turbo back' exhaust is everything 'back' from the turbo. So, what is a 'Cat Back' exhaust? Also, why can't you just take the vehicle to the local Midas shop and have the work done for about half the price and no trouble? Do diesels require a special kind of metal tubeing that Midas or other muffler shops may not have? And one final thing; what dictates whether you install a 4 inch or a 5 inch system? Thanks for any replies.
'85 E-150 351w, factory order rcvd Oct. '84: Balanced/blue-printed, HYPEREUTECTIC pistons, matching edelbrock performer pkg: cam, lifters, intake, carb, & elec fuel pump. MSD pkg: MSD 6, billet distributor, timing control, & 8.8 wires; AirLift air bags, Deraler tubed trannie pan, FloMaster Exhaust w/duramax ceramic headers, new paint.
'99 E-350 HiTop Companion Van Conversion SD 7.3, factory order rcvd Dec. '98: SuperChip, twin K&N air filters, 203* mod, Deraler tubed trannie pan, B&M trannie cooler, AirLift air bags, Bilsteins, 4" DiamondEye turbo back exhaust.
clev is offline
Old 07-31-2008, 01:26 PM   #8 (permalink)
Originally Posted by clev View Post
Along the same lines, I assume the 'turbo back' exhaust is everything 'back' from the turbo. So, what is a 'Cat Back' exhaust? Also, why can't you just take the vehicle to the local Midas shop and have the work done for about half the price and no trouble? Do diesels require a special kind of metal tubeing that Midas or other muffler shops may not have? Thanks for any replies.
Cat Back is from the Catalytic convertor back.
Most Midas shops don't have the equipment to do Mandrel bends, so they make 'crush' bends which reduce the diameter of the tubes - not good.
Also, it would be a rare Midas shop that can handle 4" tubing, let alone make a mandrel bend on one.
Mike
125W solar panel. Sportsmobile off-road trailer.
54,311 miles. 16.47 mpg average
From Cal to Alaska and Key West and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires. 46 Gal tank - harpooned pump vent tube.
Scangauge
162 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, Turbo hose fitting, Block Heater, Door lock - all under warranty. AC hose, not under warranty.
MikeL46 is offline
Old 07-31-2008, 01:41 PM   #9 (permalink)
clev's Avatar
My Photos: (14)
Thanks Mike, for the quick, informative reply. How about the 4 inch vs 5 inch?
clev is offline
Old 07-31-2008, 07:50 PM   #10 (permalink)
The 5" exhaust is used for gents who race and PuLL with the Rigs.
The 4" is plenty for the van. I have the 4" Magnaflow and it works great.
The 2000 year vans did not come with a Cat Converter, mine didn't anyway.
I was driving on the Freeway the other day and I went about 95 MPH and the Boost Gauge was reading 30 #'s, and the van had way more pedal to go.
The Magnaflow exhaust has the straight-through pipe and the van breaths very well with this system.
I wrapped my entire exhaust with the Thermo-Tec header Tape 2" Wrap, including the muffler. It stoops the drone sound inside the van and made it very quiet inside. Best 125.00 I ever spent.
You can doctor the Magnaflow truck exhaust to work in the van. The pipe that wraps over the rear axle is the only issue. We used those band clamps on the joints to adjust the system the way we needed it to bend and fit.
2000, E-350, SuperDuty, Explorer Extended LivingRoom, 7.3L PSD. 3:55 LS Rear, SuperChips 1705, Dual K&N's, FleetGuard WF-2077 Coolant Filter, AutoMeter Phantom Guages - Pyro, Boost, Tranny & Hobbs Hour Meter, 4" SS MagnaFlow Turbo Back Completely Wrapped with Thermo-Tec 2" Header Tape, Sonnax Valve & Tricumulator Shift Springs, Mag-Hytec Tranny & Dana 60 Cover, One-Up Front Spring Option, Bilstein's, Centramatic's, 35 Gallon Main Fuel Tank & Trax II TransferFlow 27 Gallon Aft. Aux. Fuel Tank = 62 Gallon Range, ACPM/AIC, Dual Battery & Dual Alt, FilterMAG, Fumoto, Amsoil Tranny & Rear End, Alcoa's, 4 Leather Captain Chairs w/ Back Bench Seat/Bed, Inflatable Aerobed, 20" LCD TV Overhead, DVD, VCR, KVH TrackVision, SAT/NAV, Walnut Cabinets & Trim, 3000 Watt Sine Wave Power Inverter, BioVault 2.0 Gun Safe, 2xDIN Pioneer DVD Head w/Backup & Side Cameras, 5 Channel Surround Sound System, PowerTank, 12 Volt Refrigerator, RainX Wiper Blades, 3M Rubberized Undercoating, Bob's AC Valve, H3R
van_350sd is offline
Old 08-02-2008, 08:03 PM   #11 (permalink)
clev's Avatar
My Photos: (14)
At 13 mpg empty and 7 towing, I've decided to upgrade the exhaust to 4 inch. I checked WarpSpeed and they have an 'aluminized' turbo back system for $289 plus shipping and that sounds pretty good. But, the 'aluminized' makes me a little apprehensive so I've been looking for stainless steel; can't find any. Does anyone know of any company that has them for <$500.00?
clev is offline
Old 08-04-2008, 04:15 AM   #12 (permalink)
Assuming you live a dry climate Aluminized should be more than ample. I have same exact kit on my van and as far as the quality goes I love it, especially for the price I paid. WarpSpeed sells it but Diamond Eye manufactures it, they're available trough many diesel stores WarpSpeed just advertises it on the website.
Try Black Widow Diesel 319-849-1191 they're extremely friendly, I always purchase through them.
