Old 05-25-2007, 08:57 PM   #1 (permalink)
wheels?
will 99 f350 wheels fit a 96 van
Csmck is offline
Old 05-25-2007, 09:02 PM   #2 (permalink)
carrfamilynj's Avatar
My Photos: (6)
Re: wheels?
didn't 1 ton trucks go metric to 8 X 170mm in '99? 1 ton Vans were and still are 8 X 6.5.
'04 E350 XLT SuperDuty "Crew Van"-3 rear benches removed,
equipment shelving installed.
Specs: 5.4 V8, 3.55 open rear, K & N with modded snorkel, Black Magic Extreme 16" electric puller fan, In-Dash Auto-Meter Phantom electric coolant and ATF temp gauges, Derale Deep Transmission pan cooler, TransGo Shift Kit, Gabriel Hi-Jackers rear air shocks, polished aluminum billet grill, Euro-clear corner lenses with 18 LED amber bulbs, Euro-clear headlights with Sylvania Silverstar Ultra bulbs, Lund bugshield, 55 watt driving lights, stainless trim rings with chrome deep lug nuts, Valley Class 4 Receiver Hitch
Purchased 5/2006 w/44k, 69k as of 3/2008
carrfamilynj is offline
Old 05-25-2007, 09:30 PM   #3 (permalink)
My Photos: (13)
Re: wheels?
Also f-series is hub center.
E-series is lug center.
Bill
97 E-350 Quigley Van Picts
Supporter/User of THE CURE E4OD/4R100 Transmission Control
WWW.FORDTRANSMISSIONCURE.COM
TO RENT THIS SPACE SEE YOUR ADMINISTRATOR
ads@thedieselstop.com.
MADVAN is offline
Old 05-25-2007, 10:21 PM   #4 (permalink)
Re: wheels?
so they wont fit?
Csmck is offline
Old 05-25-2007, 10:27 PM   #5 (permalink)
My Photos: (6)
Re: wheels?
no
Old 05-25-2007, 10:32 PM   #6 (permalink)
Re: wheels?
http://www.southwestwheel.com/alcoawheels.htm
I got a set from southwest, and they have a special set for the E van, the stainless steel valve stems are great they use, and the center hub covers are aluminum.
I also installed the centermatic wheel balancers and they work super.
2000 E350SD PSD Extended ConversionVan, Deep Emerald Green, 3.55 LS, Premium package, Dual Alts, rear A/C. Transfer Flow rear tank (27+35=62 Gallon Range), Custom Leather Interior, LimoLights, Amsoil lubes Tranny & Rear End, Mag-HyTec Tranny and rear End Covers, K&N air filters, Alcoa 16" Rims & Michelin tires (245/75-16), CenterMatic Wheel Balancers, Autometer gauges(4), 4" MagnaFlow SS Exhaust Wrapped with Thermo-Tec Header Tape has cut the noise in 1/2, no Drone Now! , SuperChips, Bilstein Shocks, Sonnax Valve, ACPM / AIC Ford, FingerPrint Gun Safe, 20" TV Rear, DVD/VCR, 10# PowerTank (C02 AirTank), H3R Halon Fire Extinguisher 3#er. Thanks To All Members for Your Help.
AL_Fishing is offline
Old 05-25-2007, 11:27 PM   #7 (permalink)
Re: wheels?
Bill
[/ QUOTE ] The E van and the F trucks have used the hub to center the stock wheels for over 20 years on most models. I always had to pound on the back side of my front wheels to remove them on my 87 van because of the tight hub/wheel fit. The fact that they use tapered lug nuts doesn't change anything. Note also the hub and wheel borehole size has not changed on the 99-up F trucks.
1994 E-350 RB 5.8gas 4X4Quigley cargo 4.09 arb-locker f/r 35x12.5-16.5 or 285/75-16.,,, 1997 E-350 EB 5.4gas 4X4Quigley Sportsmobile camper 4.10 arb front, L/S rear 285/75-16/front 33X12.5-16.5/rear ><>J
toalpi is offline
Old 05-26-2007, 12:58 AM   #8 (permalink)
Re: wheels?
Hub vs. lug centered had to do with the type of lug nuts. If you put flat lugnuts on your van, they are now hub centered. How well depends on how well the pilot fits to the hub.
Many aftermarket wheels for the 99+ pickups use cone lugnuts. They are then lug centered.
According to the specifications I have, the pilot holes are NOT the same between the 2 generations of trucks. Up to 1997 is 4.88" (123.952mm) 99+ is 125.10mm. That is certainly not a large difference but it is not insignificant.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
