is there anywhere that i can buy the telescopic mirrors other than ford?? i need tow mirrors but i have not found a set that work with my van yet...so i thought the easiest way would be to install the telescopic mirrors that were special order from ford.
just looking to save a little money.
2000 E-350, all stock except for a edge programer.
over 1,300,000 kms
located north of toronto, ontario
They have em all the time on eBay. Not cheap. If you have an older van, you have to have to drill one additional hole to mount them, but they are a direct bolt on.
Like he said check e-bay...the manual set is around 125 bucks ...you have to drill an extra hole but they are a bolt on...have a set on my 98 excellent for towing and also get the C-btr add on mirrors (ad on site) they are a god send and worth the money...bill
I got mine on eBay also. But, beware of the aftermarket mirrors. You can find genuine Ford mirrors for the same money. The ones I bought came from an ambulance conversion.
Mike
125W solar panel. Sportsmobile off-road trailer.
54,311 miles. 16.47 mpg average
From Cal to Alaska and Key West and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires. 46 Gal tank - harpooned pump vent tube.
Scangauge
162 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, Turbo hose fitting, Block Heater, Door lock - all under warranty. AC hose, not under warranty.
If you have an old van like they said you'll have to do drilling. In my instance i had to drill a few holes and make the existing ones bigger. The studs on the new mirrors are alot bigger. I like them alot though, wish i could have gotten the power mirrors though. I also want to find a way to get the mirrors from a 6L F-series on the van, the one with the LEDs on the side. Would just need to figure out how to change out the mounting pedestal part on them.
I just bought dual post towing mirrors off of ebay and want to install them on my 2000 E350. My first glance showed a little more than just drilling one hole. My factory mirrors bold to the exterior metal of the car while the tow mirrors bold to the interior metal. I hope that made sense. Also i don't believe the two middel bolts line up to any of the existing holes.
Here are some cheap electric mirrors.... ebay item
2005 E350 Standard Cargo Van, 6.0 PSD, 4.10 L.S., Quigley 4X4 New on 11-18-05
(seems to manufacture oil....1 Qt per 4000 miles)
Warranty Turbo 7-07 22,000 miles
Warranty A/C compressor 10-07 25000 miles
2003 E350 Extended Cargo Van, 7.3 PSD, 3.55, Quigley 4X4 New on 2-1-04 Some Pix
Transfer Flow 46 Gal.***Delaminated***Replaced 8-29-06 UNDER WARRANTEE
XM Radio, Alpine GPS Nav. System 7.5' Western Snow Plow
Quad Captain's chairs and Espar Furnace
OX cable locker on front
ARB locker on rear
BTS Tranny 9-29-07 @55,000 miles
Aluminess Bumpers
Mile Marker 12,000 pound hydraulic winch
2000 F250 ...... just cuz people are dumping them for the fuel bill. Got mine on ebay for $8749 with 116K on the clock. Go-fast mods to follow.....
Try a search, there are some good instructions for the install from a guy in Maryland (can't remember his handle). Also, check out this thread kinda old but good info.
I did the mirror job a year or so ago, I love them. I got power mirrors for an E-450 from fordpartsonline.com, about $300 but that was before they started showing up on ebay.
Vince,
2001 E-350 Chateau Quigley--SOLD!!! 7.3 liter PSD, Oxford White Clearcoat/Medium Parchment Cloth, 3.55 limited slip axles, dual alternators, AIC, factory running boards, privacy glass, power driver seat. UPGRADES: Alcoa wheels, Lund Moonvisor, 4 passenger Medium Parchment Cloth rear bench seat (11 passenger Chateau now), Cobra 2000 watt inverter, 46 gal TransferFlow tank, Velvet Ride shackles, CorrecTrack Rear Wheel Spacers, Rancho 9000 shocks. Great family truckster for me, the wife, & 5 kids.
