where is the GP relay on an '04 6.0 E-Series van? - Diesel Forum - TheDieselStop.com
Old 11-13-2009, 04:29 PM   #1 (permalink)
I have looked but I don't know if thes are different than the older ones. It is the six liter and a 2004 model.
Dont drive faster than your Angel can fly....
I like what I do, and I do what I like... fortunatly I can make a decent living at it as long as I keep doing it.
1995 F-250 XLT PSD Ext-cab 4X4 4:10 gears, straight pipe, 3" downpipe, shimmed FPR, Tony Wildman 4pos.chip, dash mounted triple gauge, deleted EBPV, baldwin PA2818 open element intake, MileMarker SS manual hubs, tru-cool "max" tranny cooler. 200,000mi service included injector job, lift pump & hoses, IPR valve, CPS,MAP,EBP,BARO,ICP sensors, new poly bushings w/extended front spring shackles & F-350 springs in the rear. new carrier bearings in the rear diff. only used to pull the Dive boat or Polaris toy trailer. GVW when ready to go, 17,000lbs. with 4 sets of dive gear on the boat.
'94 volvo service truck... with all the tools and other fun stuff.
centerline is offline
Old 11-13-2009, 10:16 PM   #2 (permalink)
MikeL46's Avatar
My Photos: (14)
The Glow Plug Control Module is on top of the driver's side rocker cover, right in the middle.
Before you think I know alot, I have an 04 E-Series electrical manual I picked up on eBay.
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
96,258 miles. 16.63 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
176 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, another Alternator, Turbo hose fitting, Block Heater, Door lock, Front axle seals - all under warranty. AC hose, 1 injector, Batteries not under warranty.
MikeL46 is offline
