Old 05-21-2007, 07:52 AM   #1 (permalink)
sixiron's Avatar
My Photos: (11)
Who's running a DP tuner 120 program?
and how do you like it...I have an appt with Jody tomorrow and I was thinking of adding the higher hp program into hi-idle/safe tow/80 econo programs I ran on the 98...
My conservative side says: you don't really need this concentrate of fuel milage and long life
My other side says: go ahead its only a few bucks extra and it will be fun smoking the ricers at the stop lights [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
[img]/ubbthreads/images/graemlins/rolleyes.gif[/img] [img]/ubbthreads/images/graemlins/confused.gif[/img]
2002 E-350 ext. cargo..4" DP+exhaust/gauges/ CCV mod/ AIH delete/TT mirrors wC-btr's/Amsoil Dual by-pass/Racor 45P prepump/ITP regulated return w/fuel bowl delete/tank mods/203*/timbrens/bilstein/Hella/ DP tuned/BTS trans/ alum baja wheels/cryo rotors...dyno 335 hp...164,062 miles
98 E-350 PSD...575K
04 VW TDI/PD Jetta wagon
cat 2 mic f/filter,CCV/muffler/fuel filler mods,Evo skidplate/ RC1+
sixiron is offline
Old 05-21-2007, 10:02 AM   #2 (permalink)
My Photos: (13)
Re: Who's running a DP tuner 120 program?
Bill
For a short burst its ok.
I cannot run anything more than an 80 tune.
Wish i had an intercooler.
Bill
97 E-350 Quigley Van Picts
Supporter/User of THE CURE E4OD/4R100 Transmission Control
WWW.FORDTRANSMISSIONCURE.COM
TO RENT THIS SPACE SEE YOUR ADMINISTRATOR
ads@thedieselstop.com.
MADVAN is offline
Old 05-21-2007, 10:03 AM   #3 (permalink)
I don't have it yet, but let me know how you like it. That is my same thoughts also. The extra little bit of money for that big of a thrill is too good to pass up.
BZ
1998 E350 Club Wagon SD
DPTuner 40T, 80E, 100
4" turbo back exhaust
bzirk is offline
Old 05-21-2007, 11:09 AM   #4 (permalink)
My Photos: (9)
Bill
Bill
Ditto this... I have the 100 tune and I never use it, though it's not much different than the 80 econo, except for the shifting. As it is, I can't even use all of the 80 due to heat. I thought about getting the 120, but figured I would need more engine mods to use it, so I went with the 100. I might switch them one day if I get a chance, but it doesn't really matter.
2001 E350 PSD, Deep Emerald Green, 3.55 LS, Premium package, dual alts, rear A/C. Quigley 4x4, Transfer Flow rear tank (27+26), handicap mods, custom interior, Reunel tire carrier w/ Hi-Lift, Sportsmobile nerf bars (black), Amsoil lubes and Dual-Gard bypass oil filter, Amsoil air filters, Eclipse/JL Audio sound system w/ Sirius & 120GB Neo Car Jukebox (MP3 player), J&J stainless grill, Reunel Stainless bumper, 12000# Warn winch, PIAA lights, Bilstein shocks, Ultra Magnum wheels, Michelin tires (265/75-16), Correctrack rear wheel spacers, Bushwhacker flares (painted), Velvet-Ride spring shackles, p/s filter, external tranny and coolant filters, Wicked Wheel, Autometer gauges(5), 203 thermo, BRV+, removed air intake heater, Optima Yellow Tops, "Harpoon" mod, DP-Tuner, 4" exhaust w/ Aeroturbine, Airdog, HX-mod.
Next on the List: a blown tranny!
msnunes is offline
Old 05-21-2007, 11:15 AM   #5 (permalink)
hey ,SIX i got the 120 program i have only used for about 30 or 45 second burts but it is KILLER i need to install some guages so i can moniter the EGT's but the van really moves when you hit the 120 my brother who own a ERA cobra with a 428 stroker was dumbfounded when he was put back in his seat in a van that weighs about 3 1/2 times his kitcar but i do agree with Bill i think it is best to use in short burts , my van has had a bad rear from day one noisey bearings from factory i am afraid if i push it it will let go , i did not take it back under warrranty because in past experience dealers only tend to cause more damage than good and very seldom in my experiernce fix the problem , but i plan to replace the bearings and install an arb air locker or an eaton electic locker soon. i would get it,Wade
2002 E350 EXT. Cargo 7.3PSD , silver metallic , bought new presently 178K , dual alts. , auxiliary idle control , rear a/c heat , premium group , michellin LTX M/S on AMERICAN RACING WHEELS outlaw II's , centramatic balancers , optima yellow tops not worth the extra money imo weak at best replaced with wal-mart everstart maxx more snap 1/3 the price , ITP in tank mods van specific , ITP prepump filter,ITP regulated return system van specific , DP-TUNER F5, stock,40 tow,80 econo,120 extreme , NON-EBPV turbo pedistel DIESELSITE viton o-rings ,K&N filters tempararelly till i devise a better set up , more modds on way
FULLAUTO is offline
Old 05-21-2007, 02:54 PM   #6 (permalink)
Have it and love it. Also got a 140hp file, but not enough suporting mods to get fully use of it. Dynoed 251,4Kw in the 120hp setting vs 208Kw [img]/ubbthreads/images/graemlins/blush.gif[/img] in the 140hp setting....
And as stated before: just for a short burst. (Don't need a tach, I can just look at the pyrometer [img]/ubbthreads/images/graemlins/tongue.gif[/img])
98 E350 PSD Cargo "Under construction"
F5 DP Tuner (10 pos)(mounted on a-pillar) w/pane files -PS 2000 -SC 1705 (code reader) - Snow stg 2 - 3xUltraLites in a-pillar - 3x UltraLites on dash -4"Magnaflow (15970)turbo/back -4" DIY AFE intake -ITP overboost kit. Detroit locker.
And the hottest mod so far: Tranny built by RATS, BIG thanks to Ole Ringstad
TC lock-up switch, Jingle bells killed, Excursion gauge cluster (tack).
Waiting to be mounted: roll cage, Two garret gt3782bb - real twins.
Working on: brackets to relocate alternator, sidepipes. AC and vacuum pump delete (for space)
Headers, and a second HPOP
437/1116Tq Dyno
PICS: http://community.webshots.com/album/346517884jXrDba
70' Mustang FB 408 stroker... Is it possible to sqeeze a PSD into this one? Hmmm
oystein is offline
Old 05-21-2007, 04:52 PM   #7 (permalink)
Norway,
Which 140 file do you have? I see that Jody has a 140 aggressive and a 140 extreme.
BZ
bzirk is offline
Old 05-21-2007, 04:54 PM   #8 (permalink)
140 extreme.
437/1116Tq Dyno
oystein is offline
Old 05-21-2007, 09:08 PM   #9 (permalink)
NorwayE350,
Do you have part numbers for that intake? Did you relocate the battery to the frame rail?
BZ
bzirk is offline
Old 05-21-2007, 11:15 PM   #10 (permalink)
My tow 40 is quicker than the econo 80.(& it'll leave a thunder-cloud)My kids think it's real funny to smoke out people. Gotta have Jody tweek the 80 when in his neiborhood. He said anything higher would need more modding for enough fuel delivery.
1999 E350 7.3psd , XLT , 15 pass/ext , purchased 6/6/05 w/255k on odo, 8/05 added BTM/straight pipe,5/06 BTS,1"shimmed front coil springs,Michelin XPS 235/85 16 R.,FredGroeske2"rear wheel spacers,1-1/2" rear sway bar,AIC,3 A-pillar guages, Tekonsha envoy,coolant filter,4 pos dp-tuner,In-tank mod & harpooned,dahl-100 prepumpfilter,Scan-guage,Bilstein shocks.
bork is offline
Old 05-22-2007, 07:02 AM   #11 (permalink)
sixiron's Avatar
My Photos: (11)
NorwayE350,
BZ
Yeah what he said....(hijacking my own thread here)....did you relocate the battery to the frame rail?
[img]/ubbthreads/images/graemlins/cool.gif[/img]
98 E-350 PSD...575K
sixiron is offline
Old 05-22-2007, 08:39 AM   #12 (permalink)
My Photos: (14)
Looks like it. See pics at webshots in his sig. Nice set up. Looks like you would have room for the Tymar style filter.
While I love diesels, I don't need one, and unfortunately, after much deliberation its a hobby I currently cannot afford.......... Gone but not forgotten:
1999.5 F250 CC SB XLT 4WD, 7.3 PSD, First F,2nd Diesel, nice but still liked the van better.
2003 E-350 Super Duty Chateau (Club Wagon)7.3PSD, 3rd Clubwagon,First diesel, Never should have sold it....
ddog is offline
Old 05-22-2007, 09:01 AM   #13 (permalink)
Sorry about the hijack Sixiron, Just the joys of Adult ADD (Look a bird) Is your Appt with Jody today or yesterday? Fill me in on the outcome. I am on the same track only 20 or so hours from him, so I am on my own.
BZ
bzirk is offline
Old 05-22-2007, 10:07 AM   #14 (permalink)
My Photos: (13)
Econo = stock shiftpoints.
Tow = Higher shiftpoints.
Race = ?
Extr = ?
Shift should be 1,2,3,lock tc,4. Non PWM.
Don't know when PWM is at full lock?
I use the 60 Tow pane and lock TC manually after/during 2 gear shift.
1/2 a jack Bill
Norway
Where is your AIT sensor. Have you tested temps, (traffic/Hwy ect) compared to ambient? Is your dyno runs with the intake? I tryied one like yours and it hurt the power.
Bill
MADVAN is offline
Old 05-22-2007, 03:11 PM   #15 (permalink)
NorwayE350,
BZ
Sorry, old pics. That intake was home made and WAY too small. Made of ricer parts [img]/ubbthreads/images/graemlins/blush.gif[/img] [img]/ubbthreads/images/graemlins/blush.gif[/img] [img]/ubbthreads/images/graemlins/blush.gif[/img]
I now have a DIY 4" intake with AFE filter. I'll try to post some updated pics soon.
And yes, all my batteries are mounted on the frame rail.
437/1116Tq Dyno
oystein is offline
