Old 05-15-2003, 02:14 PM   #1 (permalink)
Why do Ford Diesel Vans come with automatic transmisssions only and not manual/clutch versions?
Can anyone tell me why the diesel ford vans come only as automatics?
Why aren't manual/clutch transmissions used?
If you had the choice between an automatic vs a manual/clutch transmission in a diesel van, which would you choose and why?
Thankyou for your opinions.
BravestDog
Flubber powered turbo diesel spaceship.
BravestDog is offline
Old 05-15-2003, 06:30 PM   #2 (permalink)
Re: Why do Ford Diesel Vans come with automatic transmisssions only and not manual/clutch versions?
I never really looked it up but i figured you could get a manual in a van. I would guess there is space issues or the shifting lever would be like.. 5 feet long.
Eric
Ford 1992 E-350, 6,900 lbs.
Dodge 1997 Ram 3500
Ford 2005 F-350
yaric008 is offline
Old 05-15-2003, 06:36 PM   #3 (permalink)
I have a VW Caravelle with the engine in the back and manuell tranny. It has about 15 ft shifting lever ... It works perfect.
Torstein
E350 '93 7,3 Diesel IDI/NA E4OD RABS II Oslo Norway
200 000 km and counting
SAAB 900 '91 160.000 km
SAAB 900 '83 300.000 km sold
VW Caravelle TD '88 40mpg fully loaded(sold)
Citroen BX 16 (crashed (not by me))
Misc American leftover: Diamond ('46), GMC('49), Dodge ('49)
Torstein is offline
Old 05-15-2003, 06:47 PM   #4 (permalink)
My Photos: (11)
Really don't know but the Vans are mainly people haulers ... what else can haul 12 or 15 passengers as a POV or commercial use vehicles and the Auto is a better choice for these uses. Just look at how many commercial vans are Fords and would you want/trust every employee to be able to handle a hand shaker and why would it be better in these two main uses than the Auto. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Auto, don't need or want the manual or hassle of it with how I use my Van ... I chose one gear (D) and can go 5, 10, 100, 1000 miles and never move anything unless I stop and turn the engine off.
Larry
<font color="green">MY PICTURES - Look around ... lots of good stuff </font>
2001PSD(PCM:HPI2)SD E-350,Dk Emerald Grn,4.10LS, <font color="blue">Mustang dyno - 183.9/400.4 stock</font> [img]/ubbthreads/images/graemlins/smile.gif[/img], BTS w/Schaeffer's ATF[img]/ubbthreads/images/graemlins/biggrin.gif[/img] , ITP 3.5"/4" exhaust w/Magnaflow & Aeroturbine,Dieselsite 203* T-stat/Zerex G-05,F.Pwr, Ext/Int. Upgd. pkg,R. Bds,AIC,Tow Pkg, Rear & Slider windows,<font color="red">AMSOIL air, oil-bypass & rear end 75w-140 fluid ,<font color="blue">3/8" fuel sys w/10µ Dieselsite DAHL100 & fuel manifold/sight glass</font>,6 way dr. pwr. seat, Magnefine trans/P.S. filters</font>, husky mats,<font color="red">5 gauge A-pillar ISSPRO EVs w/Grn mkr illum. + air & fuel restriction gauges</font>,Dieselsite coolant filter and zinc electrode, manual GPR switch & GP LED, blinking security LED, weathertechs, a few other "Gadgets" [img]/ubbthreads/images/graemlins/smile.gif[/img], & a 1981 26' Prowler TT(26Y)
Larry M is offline
Old 05-15-2003, 08:49 PM   #5 (permalink)
Another advantage to the auto is you never have to worry about killing yourself on boat ramps. Pulling out of boat ramps with a manual can be tricky sometimes, specially if the person driving doesn't drive that vehicle much.
Eric
Dodge 1997 Ram 3500
Ford 2005 F-350
yaric008 is offline
Old 05-15-2003, 09:31 PM   #6 (permalink)
My first van (in 1983) was a 1978 E100, straight six with three on the tree. Larger than stock rear tires and off roading was tough on the clutch(es). After the third clutch I put in a three speed with over drive and the floor shift. From 75 to 86 the manual transmission was only available with the 6 cylinder. I'm guessing that the introduction of the AOD transmission is why the manual option disappeared. It was pretty tight with 4 pedals in there too. An auto is better in the snow also, since most vans don't carry alot of weight in the back most of the time. Tony
1994 E-350 RB 5.8gas 4X4Quigley cargo 4.09 arb-locker f/r 35x12.5-16.5 or 285/75-16.,,, 1997 E-350 EB 5.4gas 4X4Quigley Sportsmobile camper 4.10 arb front, L/S rear 285/75-16/front 33X12.5-16.5/rear ><>J
toalpi is offline
Old 05-15-2003, 09:47 PM   #7 (permalink)
Most people are either too lazy to be bothered, or simply have no clue how to operate a clutch. Every time I drive the Econoline-chassis shuttles at work I wish I had a 6-speed. Slushpumps are for grandmothers &amp; people with one leg. Give me a manual transmission. Every time. No exceptions.
Cadillac finished!
1992 F-350 4x4 Custom: 7.3 IDI-turbo, ZF 5-speed with Luk SMF & HD clutch, 4WD, 356K, no power gizmos, Reading utility box
MANUAL GEARBOXES FOREVER!
GO SOX!
Johnny96 is offline
Old 05-22-2003, 04:18 AM   #8 (permalink)
hey guys,
I'm new on the Forum because I never knew it existed here until a few days ago.
I'd just like to add that I know Ford made straight drive vans until around 88-89. I think they were four speeds, but I've never seen one myself. I'm just posting here to let you know that I've been looking to switch the body on my 86 Quigley 351W C-6 Dana 44 and try to swap it over to a Dana 60 diesel 6-spd straight drive while the body's off (the last owner abused it and I mainly bought it for the chassis anyway).
Less desirable would be build the 351 or go 460, but I'd prefer a diesel. If anyone has ANY info, I'd REALLY appreciate it. I can't find anything about straight drives anywhere.
Thanks for all the great posts.
J
PS - I can't get on www.fordcummins.com to find out about the swap. Anybody know anything about them?
jbhall is offline
Old 05-23-2003, 10:15 AM   #9 (permalink)
My Photos: (20)
Send a message via ICQ to GraemeDiesel
I agree completely.
2003 F350 SRW Crew Cab 6 liter PSD, Torqushift Transmission, 4x4, 606,000 kms
1996 F250 XL, Powerstroke, Swamp's Baby injectors and TS 3 position chip, Tymar intake and downpipe, 4 inch straightpipe, amsoil engine oil bypass filter, coolant bypass filter, 203 thermostat, chevron synthetic oils front to back, 4x4, 5 Speed, Luk single mass flywheel
382,000 kms
GraemeDiesel is offline
Old 05-23-2003, 04:22 PM   #10 (permalink)
Well you shold try to combine an automatic and a manual.
I drive my wifes SAAB occasionally, and you should hear the sound of me putting it in reverse [img]/ubbthreads/images/graemlins/phoney.gif[/img] [img]/ubbthreads/images/graemlins/phoney.gif[/img] [img]/ubbthreads/images/graemlins/phoney.gif[/img] [img]/ubbthreads/images/graemlins/phoney.gif[/img] [img]/ubbthreads/images/graemlins/phoney.gif[/img]
Torstein
(It is a miracle that it is still possible ...)
Torstein is offline
Old 05-23-2003, 08:57 PM   #11 (permalink)
I have both. And I only tried to "push the clutch &amp; shift" once in Liz's K-Blazer.
However, I've waited for glow plugs in her Cherokee &amp; my Cadillac a few times.
Cadillac finished!
GO SOX!
Johnny96 is offline
Old 05-23-2003, 09:32 PM   #12 (permalink)
Every time I get into one of those silly chevy vans at work, I turn the key &amp; can't find the light...usually takes me a minute or two to remember they're gas (under)powered. Makes the boss mad when I tell her the glowplug system is dead in one of her chevys...
Beware the FMOC!
Defective is offline
