Bent a push rod - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Supporting Vendors > Tousley Ford
Tousley Ford Tousley Ford
Old 02-24-2013, 12:44 PM   #1 (permalink)
Bent a push rod
Hi, I'm looking for a few part numbers for my 2006 F-250 SD 6.0L diesel vin# 1FTSW21P16ED68925.
I require the following items;
Pushrod,
Exhaust Rocker,
Clip that hold the rocker to the fulcrum plate,
Vacuum solenoid for the 4X4, I think it may be P/N 7C3Z9H465A
Tom
2006 F-250 SD Lariat,
ARP Studs,
Scan gage II,
Dieselsite coolant filter,
EGR delete,
Scangage2,
one piece STC fitting,
Updated standpipes and dummy plugs,
'03 metal CAC tube,
OEM finned diff cover,
tom135 is offline   Reply With Quote
Old 02-25-2013, 05:52 AM   #2 (permalink)
huj
broken parts
if you have broken rocker and bent push tube most likely valve is bent and you have lifter- cam problem sorry for the bad news
huj is offline   Reply With Quote
Old 02-25-2013, 03:22 PM   #3 (permalink)
Maybe, from what I have read/ been told about other members past experiences, I may be lucky. Boroscoped top of lifter, piston, all look good. Compression check is good, so bent valve unlikely.
I would certainly rather drop in a push rod and new arm, considering the price. Verses pulling the engine out of the truck for speculation of cam damage.
I think I will take the troubleshooting route one step at a time.
Thanks for your theories though, I will take it with consideration.
Now if I could get the answer to my original question, I would appreciate it very much.
Thanks,
Tom
ARP Studs,
Scan gage II,
EGR delete,
Scangage2,
'03 metal CAC tube,
Old 02-26-2013, 12:16 PM   #4 (permalink)
Hi,
I place an order through your website.
Tom
ARP Studs,
Scan gage II,
EGR delete,
Scangage2,
'03 metal CAC tube,
Old 02-27-2013, 04:16 PM   #5 (permalink)
TousleyParts's Avatar
Thanks for the order, and I apologize I did not get here sooner.
Mike R
We are Autonation Ford of White Bear Lake selling all OEM Ford parts 10% over dealer cost (formally Tousley)
Please PM me for any price requests
Call us at 1-800-328-9552 OR check out our website www.tousleyfordparts.com Be sure to mention this website for the good discount.
TousleyParts is offline   Reply With Quote
« Tousley Ford | help »
