2-Stroke Oil as Fuel Additive? - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 10-20-2011, 04:48 PM Thread Starter
Balla6.7's Avatar
Would a 6.7L have any ill effects with running 2-Stroke Oil at a 200:1 Ratio? Any other fuel additives that increase lubrication?
'11-F350-6.7L-KingRanch-FX4-SRW
Balla6.7 is offline
post #2 of 13 (permalink) Old 10-20-2011, 05:48 PM
fulltimer50's Avatar
My Photos: (18)
The oil may not go well with the SCR system and filter. I used it all the time in my 7.3 but with the new one I am concerned about the added soot for the filter.
George
2011 F350 PSD Lariate, CC, 4x4, LB, DRW.
2013 Lifestyle LS37RESL 5th Wheel
fulltimer50 is offline
post #3 of 13 (permalink) Old 10-20-2011, 07:44 PM
Dak
I don't officially know, but I bet even the newer low ash, no smoke, 2-stroke is still a no-no in the ones with a DPF... Find someone with a Edge CTS and start slow, monitoring soot build-up to see if it is a problem. Obviously, you would need some time with the monitor to develop/figure out a baseline.
Also, Is 2-stroke all that much cheaper than buying a good diesel additive in bulk?
2011 F350 SRW 4x4, Lariat, LWB, Diesel, Nav., 5th Wheel and Camper Pkg.
Dak is offline
post #4 of 13 (permalink) Old 10-21-2011, 12:07 AM
I wouldn't, I would use PM-22. It will lubricate and increase cetane.
Kevooo is offline
post #5 of 13 (permalink) Old 10-21-2011, 01:17 PM
Painted Horse's Avatar
Why try to use a product that was not designed for your use? There are so many option now in diesel fuel additives, that have been engineered from their initial concept as a solution. Why substitute a generic maybe solution?
A two cycle oil MAY offer suitable lubricating qualities, but it doesn't address increasing Cetane, removing water, reducing the Gelling, or a biocide to stop algee growth. Most of the good diesel additives address multiple if not all of these concerns.
15 F350 CC Lariat SRW LWB Ruby Red, Ultra Predator Wheels with Toyo 295/65R20, BAKflip Fibermax tonneau, Diesel Products LED lights in the rear bumper and 20" light bar in the front bumper, Firestone Airbags and Airllift Wireless compressor.
11 F350 CC Lariat SRW LWB Tuxedo Black Sold at 145,000 milesl
Painted Horse is offline
post #6 of 13 (permalink) Old 10-21-2011, 03:45 PM
If, for some reason your engine decides to go south after using that, and Ford can detect that there was something in the fuel that shouldn't have been, you just cost yourself an $18,000 engine.......not counting labor to do the change over. Do you feel lucky? Me.........not so much!!!
xrated is offline
post #7 of 13 (permalink) Old 10-21-2011, 04:45 PM
kper05's Avatar
Add in another $10,000 for the fuel system if something goes wrong there.
Stick to the Motorcraft PM-22-A cetane boost additive.
4 oz per 25 gal.
2011 F-250 XLT SC SB 4x4 3.31 ELD 6.7L PSD
kper05 is offline
post #8 of 13 (permalink) Old 10-21-2011, 08:10 PM
Hdslider's Avatar
I agree with Painted horse. many good proven addatives available.
2011 F-350 Superduty 6.7. CC,LB, SRW 3.31 ELD.Vermillion Red.Bakflip HD,Spray in bedliner. Tint all windows.Edge Insite CTS. DDM Tuning,Hi/Low HID'S (H13,55W.Bull Bar. red grill lettering/stainless tailgate letters.AMI chrome locking fuel door.Plazma light bar.
2011 F-350 Superduty 6.7. CC.LB SRW Oxford white. (FORD BUY BACK)!!!
2009 F-250 Superduty 6.4. CC.LB SRW Trade in.
2010 Ford Focus. All the bells and whistles. Red Wifey's econo box
1994 F-150.XLT.5.8 litre 351. E4ODE.Extended cab LB. 198,000 miles.Don't use a drop of oil.
Hdslider is offline
post #9 of 13 (permalink) Old 10-21-2011, 09:32 PM
My Photos: (18)
This may help:
THE RESULTS:
These results are listed in the order of performance in the HFRR test. The baseline fuel used in every test started at an HFRR score of 636. The score shown is the tested HFRR score of the baseline fuel/additive blend.
Also included is the wear scar improvement provided by the additive as well as other claimed benefits of the additive. Each additive is also categorized as a Multi-purpose additive, Multi-purpose + anti-gel, Lubricity only, non-conventional, or as an additive capable of treating both gasoline and diesel fuel.
As a convenience to the reader there is also information on price per treated tank of diesel fuel (using a 26 gallon tank), and dosage per 26 gallon tank provided as “ounces of additive per 26 gallon tank”.
In Order Of Performance:
1) 2% REG SoyPower biodiesel
HFRR 221, 415 micron improvement.
50:1 ratio of baseline fuel to 100% biodiesel
66.56 oz. of 100% biodiesel per 26 gallons of diesel fuel
Price: market value
2)Opti-Lube XPD
cetane improver, demulsifier
HFRR 317, 319 micron improvement.
256:1 ratio
13 oz/tank
$4.35/tank
3)FPPF RV, Bus, SUV Diesel/Gas fuel treatment
Gas and Diesel
cetane improver, emulsifier
HFRR 439, 197 micron improvement
640:1 ratio
5.2 oz/tank
$2.60/tank
4)Opti-Lube Summer Blend
Multi-purpose
demulsifier
HFRR 447, 189 micron improvement
3000:1 ratio
1.11 oz/tank
$0.68/tank
5)Opti-Lube Winter Blend
Muti-purpose + anti-gel
cetane improver
HFRR 461, 175 micron improvement
512:1 ratio
6.5 oz/tank
$3.65/tank
6)Schaeffer Diesel Treat 2000
cetane improver, emulsifier, bio-diesel compatible
HFRR 470, 166 micron improvement
1000:1 ratio
3.32 oz/tank
$1.87/tank
7)Super Tech Outboard 2-cycle TC-W3 engine oil
Unconventional (Not ULSD compliant, may damage 2007 or newer systems)
HFRR 474, 162 micron improvement
200:1 ratio
16.64 oz/tank
$1.09/tank
8)Stanadyne Lubricity Formula
Lubricity Only
demulsifier, 5% bio-diesel compatible, alcohol free
HFRR 479, 157 micron improvement
1000:1 ratio
3.32 oz/tank
$1.00/tank
9)Amsoil Diesel Concentrate
Multi-purpose
demulsifier, bio-diesel compatible, alcohol free
HFRR 488, 148 micron improvement
640:1 ratio
5.2 oz/tank
$2.16/tank
10)Power Service Diesel Kleen + Cetane Boost
Multi-purpose
Cetane improver, bio-diesel compatible, alcohol free
HFRR 575, 61 micron improvement
400:1 ratio
8.32 oz/tank
$1.58/tank
11)Howe’s Meaner Power Kleaner
Multi-purpose
Alcohol free
HFRR 586, 50 micron improvement
1000:1 ratio
3.32 oz/tank
$1.36/tank
12)Stanadyne Performance Formula
cetane improver, demulsifier, 5% bio-diesel compatible, alcohol free
HFRR 603, 33 micron improvement
480:1 ratio
6.9 oz/tank
$4.35/tank
13)Used Motor Oil, Shell Rotella T 15w40, 5,000 miles used.
Unconventional (Not ULSD compliant, may damage systems)
HFRR 634, 2 micron improvement
200:1 ratio
16.64 oz/tank
price: market value
14)Lucas Upper Cylinder Lubricant
Gas or diesel
HFRR 641, 5 microns worse than baseline (statistically insignificant change)
427:1 ratio
7.8 oz/tank
$2.65/tank
15)B1000 Diesel Fuel Conditioner by Milligan Biotech
Multi-purpose, canola oil based additive
HFRR 644, 8 microns worse than baseline (statistically insignificant change)
1000:1 ratio
3.32 oz/tank
$2.67/tank
16)FPPF Lubricity Plus Fuel Power
Emulsifier, alcohol free
HFRR 675, 39 microns worse than baseline fuel
1000:1 ratio
3.32 oz/tank
$1.12/tank
17)Marvel Mystery Oil
Gas, oil and Diesel fuel additive (NOT ULSD compliant, may damage 2007 and newer systems)
HFRR 678, 42 microns worse than baseline fuel.
320:1 ratio
10.4 oz/tank
$3.22/tank
18)ValvTect Diesel Guard Heavy Duty/Marine Diesel Fuel Additive
Multi-purpose
Cetane improver, emulsifier, alcohol free
HFRR 696, 60 microns worse than baseline fuel
1000:1 ratio
3.32 oz/tank
$2.38/tank
19)Primrose Power Blend 2003
Multi-purpose
Cetane boost, bio-diesel compatible, emulsifier
HFRR 711, 75 microns worse than baseline
1066:1 ratio
3.12 oz/tank
$1.39/tank
CONCLUSIONS:
Products 1 through 4 were able to improve the unadditized fuel to an HFRR score of 460 or better. This meets the most strict requirements requested by the Engine Manufacturers Association.
Products 1 through 9 were able to improve the unadditized fuel to an HFRR score of 520 or better, meeting the U.S. diesel fuel requirements for maximum wear scar in a commercially available diesel fuel.
Products 16 through 19 were found to cause the fuel/additive blend to perform worse than the baseline fuel. The cause for this is speculative. This is not unprecedented in HFRR testing and can be caused by alcohol or other components in the additives. Further investigation into the possibilities behind these poor results will investigated.
Any additive testing within +/- 20 microns of the baseline fuel could be considered to have no significant change. The repeatability of this test allows for a +/- 20 micron variability to be considered insignificant.
George
post #10 of 13 (permalink) Old 10-22-2011, 10:20 AM
Hdslider's Avatar
Fulltimer50. Do you know of a source that ran this same test using the motorcract PM-22-A or the PM 23 A. it being made by someone,one would think iit was tested.Thanks
Hdslider is offline
post #11 of 13 (permalink) Old 10-22-2011, 10:47 AM Thread Starter
Balla6.7's Avatar
Thanks for the wealth of information guys...I think I thought I STILL owned a 7.3L still LOL.
Balla6.7 is offline
post #12 of 13 (permalink) Old 10-22-2011, 05:45 PM
My Photos: (18)
I suspect that when these tests were made that there was no PM-22 or 23
George
post #13 of 13 (permalink) Old 10-23-2011, 09:11 AM
Dak
I remember reading the entire article that came from awhile ago- and you are probably right that the FM stuff wasn't around or being widely used then.
Time for someone to do another test with what is out in the Market today and have them add the new 2-Stroke Oil to the test just to see... (I still wouldn't use it even if it was #1 in the test)
Dak is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > 6.7L Power Stroke Engine and Drivetrain
