2011 engine failure will a complete 2015 swap - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 09-27-2015, 12:07 PM Thread Starter
I just bought a 2011 f250 that had valve issue and trashed the motor. I have located a totaled 2015 f350 with 10k miles. Will the 2015 be a direct swap or what will need to be changed out. Thanks in advance
bamadiesel is offline
post #2 of 10 (permalink) Old 09-27-2015, 01:00 PM
Besides the motor/trans/transfer I would think the exhaust and the wiring harness along with the computers.
The 15 is a different engine and there are probably different values assigned to the exhaust sensors not to mention the exhaust brake.
ricohman is offline
post #3 of 10 (permalink) Old 09-27-2015, 03:47 PM
you would need to have the 2015 injectors programmed into your 2011 computer. Each injector has a code number on them that identifies the characteristics....there are some swapping the 2015 turbo onto the earlier engines....might do a search for that swap....so, except for the turbo and injectors, i think the engine would otherwise be a one for one swap.
Larry
larrgh is offline
post #4 of 10 (permalink) Old 09-30-2015, 05:45 AM
Does your 2011 have the 4th EGT (exhaust gas temp) sensor at the far end of the exhaust system? Near the axle hump? If not you need that pipe or a bong welded on also would need the wiring harness and I suspect computer.
If you pull heavy the 15's exhaust brake would be a great addition if you can get what is needed for it to function.
You need a real tech to weigh on on this one...
JohnD333
2015 350 dually (miss that wide front axle)
2011 450 (retired)
2008 450 (gone great truck if it wasn't in the shop)
2008 250 (retired)
JohnD333 is offline
post #5 of 10 (permalink) Old 09-30-2015, 09:04 AM
direct bolt in yes. get it running no. the h/p fuel sys is different per ford. pump out put and inj flow rates are different. the pcm may not be capable of controlling the inj duty cycle or the pcv,vcv on the 15. or just swap your 11 pump and inj and roll on. or try it and let us know. lots of differences in the intake turbo and exhaust areas. accessories should bolt up.
fomocotech is offline
post #6 of 10 (permalink) Old 10-05-2015, 09:56 AM
allcool's Avatar
Are you going to be running a DPF on this swap...?
If deleted, that will solve 98% of your install/running problems.
Many tuning companies have great tunes for the 11-14 running the 2015 turbo and HPFP.
Connecting the 2015 exhaust brake might be a problem.
Not sure how that would be done without a external switch. And how to wire up that switch in the 2011 wire harness is probably complicated at best. But maybe a custom tune writing company could set up a on/off option in the software..? Maybe 2 tow tunes, 1 with/1without ex brake on..? Just a thought.
jmo
2014 Platinum ingot silver F350 srw ccsb, Bilstein 5100, Bedrug, ReTrax One hard roll up cover, KC HiLiTES 70w HID spot beam driving lites, 55w Morimoto Mini D2S 3.0 x lens HID projectors with led DRL & led amber turn signal inside shroud halo, Husky Liner X-act Contour floor mats, HUSKY rear wheel well liners, NuShield NU380A.
allcool is offline
post #7 of 10 (permalink) Old 02-17-2017, 11:11 AM
I have a 2011 6.7 the body is smashed but engine still good what kinda problems do you guys think I ok run into when swapping into a 2015 gas job? Both one tons
Travis Sutherland is offline
post #8 of 10 (permalink) Old 02-17-2017, 12:02 PM
Not saying it can't be done, but would be a lot of changes. Engine, transmission, radiators (diesel has two cooling systems),fuel tank, fuel lines, wiring harness, ECM etc. This would best be accomplished with the cab removed form both trucks.
Larry
larrgh is offline
post #9 of 10 (permalink) Old 02-22-2017, 07:16 AM
Yea... the old simple days of exchanging are done... I'd stay away from it not worth it all. just the way I see it.
2016 F350 Lariat Copperfire Bronze,Black Leather Crew Cab,Short Box SRW. Supplemental Heater,3.55 ELD, Remote Starter. Used for hauling 16ft x 8.5ft. Work Trailer , 8ft. Fisher Plow, Lance 820 truck camper for those days I can get away.
Captcaper is offline
post #10 of 10 (permalink) Old 02-22-2017, 07:36 AM
Phil G.'s Avatar
If they are the same configuration cab/box, what about setting the gas body onto the 2011 diesel frame / running gear? Or was the frame damaged as well as the body?
It would be easiest to move all of the wiring over including cluster from the 2011. It should be plug & play then.
2007 F350 SRW 6.0L Auto, 3.73LS, 172"WB 4x4. Viper Alarm/RS, WD pillar Guages,AutoEnginuity, 100gal polished alum fuel tank.
All Sold: 99.5, early03 , 2004 - all were 172" wb 4x4 lariat's.
My Worklog:
Phil G. is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > 6.7L Power Stroke Engine and Drivetrain
