I have 1 2011 F-350 with the 6.7L Diesel that usually wont start when its cold. Has lots of battery power but the engine wont crank. if you flick the key on and off after a while it might start and it might not. Brough it to the dealership and they couldnt figgure it out and tryed to tell me it was the starter. But sometimes when it wont start if i hook the booster cables up to it, it'll start right away. Is there any kind of sensor that would short out that could cause this? Or what do you think might be the problem here?
This seems like one of those weird electrical "gremlins" that are hard to find. More often than not, it has to do with there being a poor connection somewhere, chaffed wire etc.
First thing to do is look at your battery cables. Are they clean? Nice and tight connection everywhere? Everything look grounded properly?
Secondly, I would agree with Viper...get the batteries load tested INDEPENDENTLY of one another. How old are they?
One thing I definitely learned over the years with dual battery setups-their condition does affect each other, especially when you need them both to crank that oil burner over. Check them independently. If you have a problem, we have had excellent service from Interstate batteries. Just had a gremlin come up on mine, dealer found the battery cable loose at the starter. Don't ignore the basics.
iv had both batterys load tested and they both came out good. and they are 2 new batterys that i bought in October. checked all the termals for corresion and to see if they were tight and it was all good.
Related Threads
The Diesel Stop
2.6M posts
210.8K members
Since 1999
