2012 Turbo Oil Line Leak after 1.500 miles - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 05-19-2012, 10:18 AM Thread Starter
I noticed an oil leak on an new 2012 after 1.500 miles. It was dripping off the RH side of the front cover. I took it in to the dealer and after using a dye marker, they replaced the gasket on the front cover. They were not satisfied that was the source of the leak and pulled the air intake to get to the turbo. Sure enough the valley was full of oil and the turbo oil line appeared to be leaking from the lower fitting. I looked at the fitting and could not believe it was not a flared steel fitting. The upper and lower fittings thread into the turbo on the top and the pillar on the bottom. The steel oil line inserts into the fittings with an internal o-ring providing the seal. A clip holds the steel line from popping out of the fitting. There is a cast groove in the valley to channel oil out to the front cover.
Why in the world is this not a flared steel fitting? I have seen this type of fitting on shovel head Harley engines. They always leak after about a year. I was talking to my brother, who is an A&P mechanic (airplane), and he thought it should be a flared steel fitting as well. According to the mechanic, there was trouble with the earlier 6.7's in 2011 with leaking turbo oil lines. Supposedly they have been improved. It doesn't look like it to me. Not happy and after 5 days the truck is still at the dealership with a new oil line and fittings on order.
doane00 is offline
post #2 of 6 (permalink) Old 05-19-2012, 10:31 AM
RFB
That is not a harbinger for optimism.
I am awaiting delivery (it is off the line and awaiting transit) as we speak.
How because of the casting you mentioned, it seems like it would be difficult to retro a flared fitting into it.
RFB is offline
post #3 of 6 (permalink) Old 05-19-2012, 02:04 PM Thread Starter
A new oil line with flared fittings could be made, but since it is under warranty and being repaired under warranty, I will continue with the factory oil line. At least now I will know what to look for in the event another leak occurs. It is very difficult to determine the source of a leak from the front of the 6.7. There are numerous parts, hoses etc. blocking any view. All I could tell was oil was running down the front RH side just above the oil pan. I could not see any further up the front cover while viewing above or below. Nor could I see down into the valley without removing the air intake.
On the bright side, the 6.7 is a pulling machine. I am very impressed and hope that the oil leak is permanently cured.
doane00 is offline
post #4 of 6 (permalink) Old 05-19-2012, 07:43 PM
Yea, the time sitting at the dealer waiting is ridiculous. I get stuff faster off feebay than they get it from Furd.
FYI: according to my dealer they can NOT install ANY aftermarket items when doing warranty work. You aren't getting any aftermarket lines installed by your dealer.
2012 F350, 6.7L Diesel, 4x4, SRW, Quad Cab, Short Box, Loaded, Ingot Silver
TrickTruck is offline
post #5 of 6 (permalink) Old 05-19-2012, 11:04 PM
lincster's Avatar
My Photos: (29)
Of course they won't install aftermarket items when doing warranty work. Lift your hood and look at the little sticker..........
2012 F350 4X4 Dually, FX4, Crew Cab, Ultimate Lariat Package, Oxford White, Black Leather towing a 2006 LE3905 Weekend Warrior
2002 F250 CC, 4X4 - Sold
2004 F350 CC, FX4, loaded - Sold
2006 F350 CC, DRW, FX4 - Sold
lincster is offline
post #6 of 6 (permalink) Old 05-20-2012, 07:01 AM Thread Starter
I never said I was contemplating having the dealer install an aftermarket oil line. I was simply stating my disgust with a poorly designed fitting or at the least a poorly manufactured fitting.
doane00 is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > 6.7L Power Stroke Engine and Drivetrain
