14k miles, all maintainence up to date, Stanadyne used every fueling, got low fuel pressure message .. then "Reduced Engine Power"
Drove one mile right to Local Ford Dealer...could be bad fuel ( no warranty coverage ? ) fuel filter, HP Fuel Pump ( covered) or Sensor? Glad it didn't happen when I was towing my 5er.
Receptionist called back, said tech couldn't reproduce the message, I could come pick it up. Called Head Tech at Dealership where I bought the truck , left message. Called Owner of dealership, he said I could call ahead and drop it off anytime...tech would check it out. He had other customer who had same problem, it was a tab from fuel additives that fell in to tank and intermittently blocked the fuel line. Had to drop the tank $(400, not warranted) I will get the truck and drive it 130 miles to dealership where I bought it ; if problem reoccurs, I will have it towed from wherever I am back to the dealership where I bought it.
Will keep y'all posted on what happens. Have any of you heard of the Low Fuel Pressure message (P008a ) just coming up once then mysteriously disappearing?
Later... had original dealer replace both fuel filters and have driven @ 300 miles since with no problems.
