Hello,
I have a 2015 Ford F-450 with 83k. Its my work truck i haul cars with it so i put it to work every day. Went back to work after the weekend. starting driving and notice my RPM was at 2k and it was dropping like if it was missing firing. pulled over open the hood to check the belts or if anything looked bad. nothing was wrong. Got back in my truck and my oil temperature was a 300 degrees and ENGINE OVER TEMP came on. so i turn off and on the truck and everything went back to normal. I decided to take the truck to the dealer. it was still doing the misfiring feeling the whole way to the dealer
Truck was at the dealer for 2 days. They couldn't find anything wrong with the truck. Dear told me the truck is not acting up on them. i went to pick it up and it did the same thing on me. went back told them the problem is still there. they said there's no check engine light on so they don't know what the problem is. i told them its a brand new truck how can i be having issues already. so i told them to change the fluids on the motor and Transmission and Differential. pick up the truck from the dealer and its still doing the same thing. dealer says they don't know what the problem is. ANY BODY HAS THIS PROBLEM TOO???
Truck only does it when i accelerate. in every speed low and high.
Doesn't do it when Idling only on acceleration and when I'm using cruise control
Truck History:
1.Water pump has been changed twice.
2.taken to the dealer numerous times because check engine light turns on (dealer doesn't know why check engine light is on)
3. AC PROBLEMS.
Really Thinking of Hiring a LEMON LAW LAWYER.....
Truck History:
3. AC PROBLEMS.
