6.7L Power Stroke Engine and DrivetrainDiscussion of the 6.7L Power Stroke diesel engine and drivetrain in the 2011-Up Super Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.7L Power Stroke engine.
Hi, been reading the forum a bit, and I see lots abot 250 vs 350 SRW, however, I can't seem to find info about SRW vs DRW.
What are the real world numbers for these two after wife, kids, dogs, fuel, etc? We have a 5er so those are the types of numbers I am looking for. Current trailer is irrelevant since its a light-weight and any SD will handle it, just thinking about the future...
I got 11.3 MPG this summer towing a 12,000 pound 5th wheel to Alaska and back. Speed was around 60. I can get 18 empty on the highway if I keep it around 60. Truck is 2011 F350 dually diesel.
I have an F350 SD Lariat SRW with a 3.55 rear end. I tow a 13.5K 5th wheel and average between 9-11.5 MPG at 65 MPH. Above 65 and the mileage slips off considerably. Not sure if I needed it or not, but I added the Timbren suspension system....which is essentially two industrial bumps stops. I'm very happy with them. At any rate, since the truck is also my daily driver....a dually is just too wide for me. If we decided to full-time...I may get a dually..but for now we are quite happy. BTW, I've gotten as good as 19.5 without the trailer.
I am looking for real world payload/pin weight capacities. It looks to me like the 250 has ~1500 pin weight capacity, so where do the 350 SRW and DRW weigh in once loaded ready for the road?
Another little thing to keep in mind is that with the DRW, rotating tires is a PITA. The local Discount tire here charges $60 to rotate a dually, free for the SRW. When you buy tires for a DRW 4x4, you buy all six, even if only 2 are worn out. Needless to say, most people with DRW won't be rotating every 5,000 miles so you won't get optimum wear from your tires.
2011 F-350 SRW 4x4 LB CC Lariat Ultimate FX4 6.7
2003 Dodge 3500 DRW 4x4 LB CC Laramie 5.9 HO
2001 F-350 DRW 4x4 Lariat 7.3 (sold)
1997 F-250 4x4 LB EC Lariat 7.3 (sold)
2007 Toyota Prius 2x4 NoBed (sips gas)
35' 5'er Toyhauler, 11.5' cabover camper and lottsa Glocks
Just picked up a 2012 350 dually the mileage is great along with the power. Just got the new hitch so haven't towed yet, will test hook-up today.
Traded in an 08 6.4 dually, truck was great. The mileage wasn't my trailer is 14 K I was getting around 6.5 to 8.5 towing.
Both trucks have 3.73 gears with 4wd.
Hope this helps, Wayne
Hello, how many miles were on the 08 dually you traded and did you have any mechanical issues? I ask because I am in the process of buying an 08 F 350 dually with 69,000 miles on it. Only problem was a radiator change at 25,000.
Alex ..... I had No Problems with my Black Pig. The truck was a good one, I did have fuel gel twice but that wasn't the trucks problem. My truck has or had 56 K on it. The truck was loaded too everthing including the Moon roof. I loved the truck but the mileage was terrible.
The new one is unbelievable as I'm getting 11 on a test tow, and 16 to 18 around town. Well we do live in the country. Good luck with the truck.
I had a '06 6.0 350 srw
Now I have a 11 6.7 350 DRW.
I will not tow with a SRW again after this DRW
5th wheel #11k dryweight
Good luck
2011 Crew Cab Lariat Long Bed Dually 6.7
2006 Crew Cab Long Bed King Ranch 6.0
2001 Excursion Limited 7.3 PSD
1999 Crew Cab short bed Lariat 7.3 Diesel (2x)
Montana Mountaineer 5th wheel
WVU Let's Go Mountaineers!!!!!
Rac1664, can you tell me what you like about towing with the DRW vrs the SRW. I hear lot's of opinions....and I'd sure be interested in hearing your first hand account. Thanks!
I had a 2005 f350 drw 6.0 and bought a 2011 f350 srw 6.7. I tow a 14K 5th wheel and the SRW does just fine. It does wonder just a bit more than the dually did but the added power and better brakes on the 6.7 more than make up for that. I dont mind towing my 5th wheel with my new SRW at all.
2005 4x4 f350 lariat dually 6.0
4" superlift, MBRP 409 cool duals, autometer phantom ii gauges, riderite air bags w/on board compressor,amp research auto steps, S&B intake for pulling a 2004 Weekend Warrior SLC3705 5th wheel
Towing with a Dually is so much more Stable in the wind. I'm not saying to go out in a Hurricane. I have towed a 5th wheel with a single rear wheel and a dually. Dually wins !!
Thanks Gents. I think I'll stick with the SRW until I retire and consider dragging the 5th wheel around full-time. I can see where the dually would be more stable in the wind, and it likely adds a margin of safety should you end up with a rear wheel flat...but the added width for my daily driver is just more than I'm willing to tackle at this point. BTW, my 5th wheel is somewhere between 13 and 13.5K--and I love the integrated brake controller in the 2011 6.7. Sure, I have to run it a maximum gain....but the truck and the trailer brakes are matched up perfectly. I don't even know it's back there during normal braking. Very sweet indeed. Thanks again.
Like rampinator I traded a 05 dually 6.0 for an 11 f-350 srw cc and pulled my 26' enclosed car hauler with both and honestly can tell no difference other that the 11 has more power and better brakes. If I was pulling a fifht wheel I would have concidered a dually. Steve
2011 F-350 SRW 4X4 CrewCab Lariat SB,6.7 PSD,Auto,Golden Bronze over Adobe,Adobe Leather,ESOF,Snow Plow Prep,Tow Command,Heated Seats,Lariat Ultimate,3.55 locking,reverse sensor,Navigation,power rear slider,power Sunroof,Adjustable Pedals,Upfitter Switchs, and class V trailer hitch.
