6.7L Power Stroke Engine and DrivetrainDiscussion of the 6.7L Power Stroke diesel engine and drivetrain in the 2011-Up Super Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.7L Power Stroke engine.
Has Ford found a solution to the fuel pump problem yet ? Also the shifting problem ? I have been thinking of trading in my 2006 6.0 with 65,000 miles. No problems with the 6.0 yet. But I'm getting nerves .
06 F350 dually XLT, Captain chairs, 4x2,4.10, 6.0, CC, 8ft bed,Reese Signature Series 18k hitch, 2006 Ceder Creek Fifth Wheel Two Honda 2000 generator's,six 6 volt batteries,3000 watt inverter + a 6500 watt Mountain Master remote start generator and lots of time to enjoy it, "RETIRED"!
I have yet to read about a fuel pump problem that did not sound like it was self inflicted on these 6.7L. I don't know if the '12s or '13s still have shifting issues, I do know that they seem to have the corrections for my '11 printed out in TSBs.
The HPFP problem has affected less than 1/2 of 1% of the trucks out there and as stated, for the most part was caused by error on the part of the driver. Usually DEF or Gas place into the diesel fuel tank. It is a very expensive failure, that is typically not covered by warranty, So it garnered a lot of attention and speculation on the websites. But very few owners have really had to deal with it.
I don't know that we have a true failure rate for HPFP that have just failed on their own, with out an owner operated error. But it is a very small percentage.
My concern is will this problem become more common after the trucks start hitting 100,000 miles. ( or some other high mileage) In the past, I have usually traded off trucks every 100,000 miles, But I'm tempted to keep this past that mileage and hope that I don't run into outrageous repair bills. A $12,000 repair on a used truck worth $25,000 may just put it in the scrap yard. That will be a difficult decision to justify rebuilding a fuel system on truck with lots of miles.
As far as the tranny shifts. I had 3 hard shifts on my truck, mostly during cold weather. The TSB fixed mine and for last 40,000 miles I've not even thought of the tranny. Again most drivers are very happy with their trucks. If you happen to get one that does have some problems with shifting, It seems to be a difficult problem to tract down.
11 F350 CC Lariet SRW LWB Tuxedo Black
B&W turnover ball
I havent read anything about HPFP failures from any member on here with more the 5 posts. I see threads pop up from time to time, but never from someone actually having a HPFP issue. As far as the shifting issues go your guess is as good as mine. I have 21k on my 2011 now and have had maybe 20 total instances of clunky shifts. As far as I know my software is current, but a rough shift every 500 miles doesn't scare me away.
2011 F350 SRW 6.7 Lariat 4X4 CC 3.31ELD
2006 Lincoln LS V8
1971 Mustang Fastback 351
There is no problem with the fuel pumps. The issue it that the pump is very sensitive to fuel contamination... as are all current high pressure fuel systems on all diesels. Some would say, and I don't disagree, that the fuel delivery and filtration system could be better though.
Transmission issues were primarily limited to 2011 models for which there are effective corrective measures. Ford has also fine-tuned the electronic controls and worked out most of the kinks by now. I don't recall having any 2012 trucks in for transmission concerns.
__________________ . Ford Master Diesel Technician Diesel Technician Society Diesel Mentor Directory
Your biggest enemy besides the error of def or gas in place of diesel is water.
If you buy your fuel from high volume locations..try to stick with truck stops and change your fuel filters on time plus drain your fuel water separator monthly you should be ok.
I have a 2008 and it has been just fine.
Issue is the fuel pump (hpfp) gets its lubrication from the fuel. So it is important to get good fuel.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
40' Stoneridge 5th wheel, coming in at 15.4K.
Just seems like the right place to post this about a month ago kept getting this intermittent really loud almost roaring type noise from under my truck finally narrowed it down to the fuel pump. Every stoplight it was loud enough to hear inside the cab with the windows rolled up and the radio on. So actually got it into the dealer while it was still making the noise and they said it was a first for them. They took the truck for a few then brought it back and the noise was gone said they took the filter off then put it back on and the noise had stopped.Just seems that taking a filter off then putting it back on wouldn't really fix anything it did stop but why? I do drain it but never with it running, just got this feeling it is coming back
2012 F250 Lariat 6.7 Golden Bronze 4X4, MBRP Filter Back Duals, Alpine INE-Z928HD Focal Amp and Speakers and a ton of Dyno Mat RetraxPro Clifford Alarm Recon smoked marker/clearance lights HID Headlights/Fog Lights Bilstein 5160 shocks
Protected by H&K
2006 Hummer H2 (traded for diesel hope never to go back to the dark side (gas)
2005 F250SD SB 4X4 6.0 Harley Edition (traded)
2003 7.3 F350 DRW 4X4 (traded)
2001 7.3 F250 4X4 (traded)
There are two main causes for excessive DFCM fuel pump noise:
Air in the fuel system - May be caused by damage to the DFCM lower bowl stops, damage to the lower bowl O-ring, a loose (not fully seated) lower bowl, drain valve not fully closed, low fuel level, or air trapped in the system after performing maintenance or repairs.
Inlet restriction - Is commonly caused by a restricted primary fuel filter. The primary fuel filter may become restricted due to normal filtering operation or fuel gelling when operating in very cold ambient temperatures. Fuel filter life is dependent on the quality of fuel used. Poor fuel quality may require the fuel filters to be replaced more often than the recommended scheduled maintenance interval. Other causes could be restriction in the fuel tank, plugged or kinked fuel lines, etc.
Ford Doc the reason the Tech took off the filter was to check for trash said that it was clean. I live in NC really haven't had any cold weather yet but have already been running anti-gel just in case. It seems to me that when my fuel gets around 1/4 tank or less is when I start hearing the noise, not sure how the fuel pickup works in these could that be the problem or is that out in left field?
Protected by H&K
The less than a 1/4 tank comment is the issue here then. This is a known condition by Ford and it is considered a normal charactaristic of the vehicle. Like it or not it is what it is.
Is it just a noise or is it potentially damage causing?
Ford Doctor thanks for the input, the things one can learn after my most recent purchase of new 2012 F350 6.7. Note to my wife, don't let the fuel gauge get below 1/4 tank (9 gals) or you will hearing noises coming from engine that will be louder then the radio, don't worry Ford said it's normal. WTH is with that might I ask.
2012 F350 XLT 6.7 CC LB Premium Package, Fx4 11,500 GVW Tow and Camper Package
2012 Montana Mountaineer 326 5th Wheel
SOLD and missed very much!
1997 F350 XLT Lariat 7.3 Reg Cab 4X4 Off Road Package
5 spd Manual with South Bend Clutch Upgrade
AFE Stage 2
Diamond Eye 3" Down Pipe 4" Exhaust Cat Delete
TS 6 Pos Chip / Autometer Pyro & Boost
WARN Winch
Original Owner 178,000 Miles
______________________________________
...So actually got it into the dealer while it was still making the noise and they said it was a first for them. They took the truck for a few then brought it back and the noise was gone said they took the filter off then put it back on and the noise had stopped.Just seems that taking a filter off then putting it back on wouldn't really fix anything it did stop but why? I do drain it but never with it running, just got this feeling it is coming back
Hi Steve Campbell and F350ninty7,
If you're concerned, I recommend visiting your local dealerships so they can take a look. Additionally, I'm happy to escalate you to your regional customer service manager. Just send me a PM with your VIN, dealer, mileage, daytime phone number, and full name; I'll get the ball rolling.
