Is the 6.7 going to use post injection? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2011 and Up Ford Super Duties > 6.7L Power Stroke Engine and Drivetrain
Old 01-14-2010, 08:57 AM   #1 (permalink)
Does anyone know if the new 6.7 will use post-injection for the regen cycle as the current 6.4 does? I am hoping Ford will change gears and utilize the in-exhaust fuel injector instead. I am very interested in the new truck/engine, but I am not interested in worrying about oil dillution. That is one thing my 6.0 has going for it!
jason3962 is offline
Old 01-14-2010, 11:12 PM   #2 (permalink)
i have heard from the powerstroke sales guy they are using UREA injection if so another tank to fill with urea only time will tell close to release date
1996 F350 2WD DRW CC Black STG1 160 CC INJECTORS , D66 TURBO FROM BEANS ,3.5" DOWN PIPE 4" MAGNAFLOW EXHAUST, SD HPOP , CPR FUEL SYSTEM ,DIY TYMAR AIR FILTER , DP TUNER WITH F5 , AUTOMETER GAUGES PYRO - BOOST - TRANS TEMP - COOLANT , DIPRICOL HPOP GAUGE .
6.0l SD INTERCOOLER MOD WITH NEW CUSTOM MODDED TANKS AND AEM WATER METH KIT TO HELP LOWER EGT'S ON HILLS , E40D HIGHLY MODDED
2009 FORD F 150 FX4 S /CREW LOADED (BLACK)
2007 SPORTSMAN 500HO STEALTH BLACK
2008 SPORTSMAN 800HO STEALTH BLACK
2009 POLARIS RZR NEUCLEAR ORANGE 2" LIFT, 27"SWAMPLITWES ON ITP RIMS , POLARIS PERFORMANCE EXHAUST KIT (THIS THING IS CRAZZZY I LOVE IT )
2008 COUGAR SRX (KEYSTONE) 30FT HOLIDAY TRAILER
drford is offline
Old 01-15-2010, 06:29 AM   #3 (permalink)
glsurratt's Avatar
From Pickup Trucks: First Look at Ford's New 6.7 Scorpion
The Bosch common-rail fuel system operates at up to 30,000 psi to send fuel to the engine’s 8 piezo injectors -- one per cylinder. Each injector nozzle has 8 holes and can deliver up to 5 injections per combustion cycle. Two pilot injections control noise levels, and a main injection is used for the power-generating combustion event. Two variable post injections are used to produce extra torque and for heating up emissions catalysts that scrub NOx and eliminate soot downstream from the engine. While cruising, only 3 or 4 injections will be needed.
Greg & Jo Ann Surratt
Enjoying Champagne on the King Ranch
2006 King Ranch F-350 CC LB Dually Diesel 4x4
2007 Champagne Edition Nuwa HitchHiker
glsurratt is offline
Old 01-15-2010, 06:11 PM   #4 (permalink)
alexb's Avatar
It does use post injection. It will also monitor for oil dilution and show a warning message in the message center when it gets excessive.
Proud to be a member of Ford Doctors Diesel Technician Society
alexb is offline
Old 01-15-2010, 08:44 PM   #5 (permalink)
...that's interesting.
Old 01-16-2010, 12:55 PM   #6 (permalink)
Banned
While it may seem interesting at the outset, one would have to wonder what the programmed limits are.... Having a warning may give a warm and fuzzy feeling... knowing the trigger point might erase it.
kodaman is offline
Old 01-22-2010, 10:45 PM   #7 (permalink)
They should have used the ninth injector post turbo as GM will do and then we could forget the oil dilution as long as the cylinder injectors don't screw up.
Bob
08 F350 DRW 4x4 Lariat CC 6.4 torqshift wide track front axle 4.10LS
07 Montego Bay 34RLB3 5th wheel
(traded the 04 w/ 56K mi. on 3/25/06; the 06 w/ 45K on 10/1/07)
bnmccoy is offline
Old 01-23-2010, 12:20 AM   #8 (permalink)
4ceFed's Avatar
To the OP, the post injection you are referring to for the regen process has been eliminated. Instead they use an UREA solution injection to the catalyst, the UREA tank has a fill cap next to the fuel cap and capacity is expected to last 7500 miles. If you have your oil changed every 5000 miles, and filling UREA tank is standard, you should not have any problems. It will also be available at fuel stations, I have heard that when the UREA level is low (800 miles to E) a warning message will appear and once empty engine will run in derate mode.
93 SVT Lightning Vortech S/C
94 Mustang GT vert
03 F250 Super Duty 6.0 PSD CC, studded and custom tunes by IDP
4ceFed is offline
Old 01-23-2010, 08:13 AM   #9 (permalink)
glsurratt's Avatar
Not true. The urea system will supplement the DPF system. The injectors are capable of 5 pulses per stroke, with up to two of the pulses being post-injection when needed for active regeneration of the DPF.
Old 01-23-2010, 11:26 AM   #10 (permalink)
alexb's Avatar
That's right. The DPF along with post injection will still be used to control opacity and particulate emissions. The UREA system will be used to control NOx.
alexb is offline
Old 01-24-2010, 12:27 AM   #11 (permalink)
I know that some companies are going away from post injection with their new engines because of the problems with oil dilution. I believe volvo is one of them. They just inject fuel directly into the exhaust stream. Hopefully ford will come around or a aftermarket company will come out with a system like this.
macmaniac1 is offline
Old 01-24-2010, 10:11 AM   #12 (permalink)
Rutcutter's Avatar
My Photos: (6)
Wonder why Ford still wants to use post inj. with all the oil dilution problems?
11' SD CC F350 6.7L FX4
White Platinum Tri-coat
Lariat Ultimate Pkg
IDP Torq2
Warn GenII winch mount
2" Autospring leveling kit
35/12.50/20 Toyo M/T's
Real Rancho shocks w/dual steering stabilzers
6k HID Headlights/Fogs
Adj.High Idle mod
08' SD CC 6.4L 4x4 (Sold)
06' SD CC 6.0L 4x4 (traded)
12' CanAm 1000 XT in Camo
06' Cat 420D 4x4 Backhoe Loader/Cab&Air
http://community.webshots.com/user/hdsilverado
Rutcutter is offline
Old 01-31-2010, 03:33 PM   #13 (permalink)
Because Ford doesn't consider it a problem for us to have our oil diluted with 2.5% diesel fuel. That is the point of their short stick test on the dip stick oil check.
I like everything I read about the new Scorpion but since there is no ninth injector post turbo I'll keep my money till the brave ones report back on oil analysis up to 20,000 miles.
I'm sure Ford will still consider black tail pipes (cracked DPF's) normal too.
The good thing about the urea injection is that it allows less EGR and still meet emissions. Effective EGR requires retarding the timing which is counter productive to fuel efficiency. The urea is good route.
The DPF still has to be regenerated or cleaned so they still have to use fuel to get the DOC to create enough heat. The DPF is to trap soot. So if we have to have the DPF to control the soot I am okay with that but I'm not okay with my fuel being diluted. Adam Gryglak, chief design engineer for the engine says the combustion has been improved and it will not be a problem. Maybe true with the much shorter exhaust route and claimed improved exhaust flow with center V exhaust ports. If that unburned fuel gets atomized in the exhaust and flows right on out maybe it will not collect on the cylinder walls and end up in the oil. Myself, I'll hold off on truck purchase and wait and see what the experience is for the first time buyers.
GM will have the ninth injector on their 2011 Duramax.
Bob
bnmccoy is offline
Old 02-03-2010, 03:26 AM   #14 (permalink)
Banned
The urea injection (along with the selective reduction catalyst - SRC) is to reduce the formation of oxides of nitrogen during periods of high combustion chamber temps... the truck is still going to rely heavily on the EGR valve. This system is quite complex and, since urea is caustic, there will be some "activity" after the truck is shut down.
The post injection that is being referred to is to assist in raising the temperature at the diesel particulate filter in order to "cook off" soot accumulation.
kodaman is offline
Old 02-03-2010, 03:30 AM   #15 (permalink)
Banned
At this point in time, I don't think it's a matter of "wanting" to... if there is a "better way", I imagine they might pay handsomely for the patent rights....
kodaman is offline
