6.7L engines relatively slow to warm up - why? - Diesel Forum - TheDieselStop.com
post #1 of 16 (permalink) Old 11-21-2010, 05:42 PM Thread Starter
Finally got my new F-450 KR which I am absolutely loving. I have a lot of observations about this truck relative to my 99 F-250 with 7.3 but in this post I will confine my topic to how fast the engine warms up after starting when cold out. I do have the rapid heat supplemental heater which works well (dual alternators). Having said that, I wonder why this engine seems to be so much slower to warm up (as evidenced by the temperature guage) compared to the 7.3. I have a couple of theories about this:
1. The thermodynamic efficiency of this engine is greater and more of the heat energy is converted into piston travel than rejected into the cooling system
2. The warmup strategy for the 7.3 employs an exhaust backpressure valve which adds to the warmup
3. Since the 6.7 uses a DPF the timing may not be as retarded on startup in order to reduce particulate emissions
4. The 6.7 has a dual cooling system in order to facilitate the EGR and liquid cooled charge air cooler, and while not more efficient when fully warmed up, it may well have a greater total capacity which impedes the warmup
99.5 PSD CC Lariat 4X4 LS 4R100 SB Banks powerpak
2011 F450 KR
James_F is offline
post #2 of 16 (permalink) Old 11-21-2010, 06:05 PM
guardrail22's Avatar
its cold outside and it takes longer??
good thing you have heated seats
New Truck
2012 F150 SuperCrew Lariat 157" VWE
Traded March 2013
2008 F450 CC Lariat White/Gold, JAD Solutions Lights, 62 Gal Titan, B&W Hitch, Gold Remote Start, TruckTrunk box, Viair 550+2x2.5gal receiver, 2010 NAV and Sync
Traded In Nov 07:
2003 F250 CC LB XLT 4x2 PowerStroke, Captains Chairs, White/Parchment, Torqshift, Heated Mirrors, Trailer hitch
guardrail22 is offline
post #3 of 16 (permalink) Old 11-21-2010, 08:34 PM
nascarj's Avatar
Not sure if you are monitoring real temps or just the gauge on the dash. If it's the gauge, on my 02, the gauges were computer controlled to reflect relative temps. They stayed in the same place across a wide temp range. Apparently we are all too stupid to understand linear movement. The first summer I had my 02, the trans temp gauge never moved. In the winter, it started off all the way down and moved up as the truck warmed. I took it back to the dealer and he printed a bulletin that said the gauge would read "midway" for trans temp from 80^F to 220^F. In the summer, the temp was always above 80^ so the needle stayed in the middle. All the temp gauges read this way.
My 11 seems to have more "real" temp movement, but not sure..
j
02 F250 XLT CC/SB/2WD 7.3 PSD- DP Tuner 6 Position Chip, MBRP 4 in exhaust, AFE Stage II, A-pillar ISS Pro Gauges- Died
08 F250 XLT CC/SB/2WD 6.4 PSD- Bone Stock... For now- Gone
11 F350 Lariat Dually/CC/LB/4WD 6.7 PSD
11 48ft CargoMate enclosed race trailer
04 Crossroads Cruiser 28BH 5er
Fox body Mustang GT- NASA American Iron-Central #76 AND
S197 (2005+) Mustang GT- NASA American Iron-Central #75
nascarj is offline
post #4 of 16 (permalink) Old 11-21-2010, 08:48 PM
#2 is the biggest reason.
Diesels burn so little fuel that there hardly any combustion to create the BTU's to heat the water idling.
EBP did it for the 7.3.
Nothing works so well as driving it.
Pre-drive warm up made sense when oils were far less than they are now and truck transmissions used 90 weight lube.
Also warm-ups made some sense on gassers when they had manual choke and momma wasn't so good at fiddling with choke those first few minutes.
The emissions testing protocol has the engine started and then put under load in 15 or so seconds.
2006 F450 CC Hauler bed 4x2 6.0 L 6.0 auto, Lariat, 4.30 r/a, SCT, 4in exh. 103K New heads to repair diesel in coolant, 136K.
2006 F350 Lariat CC Dually 4X2, 6.0 auto 4.10 LS, SCT, airbags, 4 in. exh. 147K Rebuilt engine to repair damage from burned piston. One head to fix fuel in oil problem.
2002 F350 CC DRW flatbed (originally pickup bedded) rebuilt & upgraded 4R100
35+5 foot double tandem axle flatbed trailer.
36 foot double tandem axle flatbed trailer
36 foot Platinum 6 horse LQ, side load, full width back tack
2003 EB Expedition 164K (no engine repairs, gas burners are the new longevity leaders)
2004 Volvo V70R AWD-high miler in fleet, 241K (no engine repairs)
2007 BMW 550i 6MT 146K, Stuff breaking all the time that would last twice as long on a Kia or Hyundai, sad. Drives great though.
Suzuki Carry KEI truck, 660cc 3 cyl DOHC EFI 4X4 5 speed RHD. Sort of a Smart Car sized pickup. Eats Gators and Mules for lunch.
jimmy is offline
post #5 of 16 (permalink) Old 11-22-2010, 07:30 AM
fixdent's Avatar
Yep, definitely takes longer to warm up. My 2006 6.0 warmed up real toasty after 15 or 20 minuites of idling. I hope mine has good heat in the -35 weather.
Gordon
1967 Mercury Meteor Rideau 500
2003 Dodge Ram 2500 395,000kms (that has not seen the inside of a garage for motor work)
2005 Ford SuperDuty 6.0 125k Kms <<-- gone
2008 Ford F450 6.4 55k Kms Dynamic Wrecker
2011 Ford SuperDuty 6.7 101,000kms
2010 Ford Edge 70,000kms
2006 Ford F650 Rollback 500,000kms (with a 5.9 Cummins that has not seen the inside of a garage)
fixdent is offline
post #6 of 16 (permalink) Old 11-23-2010, 03:15 PM
I noticed it too. Not sure if the 6.7 is any worse but I was driving quite a bit and noticed it still wasn't up to temp either trans or engine...Normal I guess.
2016 F350 Lariat Copperfire Bronze,Black Leather Crew Cab,Short Box SRW. Supplemental Heater,3.55 ELD, Remote Starter. Used for hauling 16ft x 8.5ft. Work Trailer , 8ft. Fisher Plow, Lance 820 truck camper for those days I can get away.
Captcaper is offline
post #7 of 16 (permalink) Old 11-23-2010, 03:48 PM
Dak
It seems to take longer than any of the previous vehicles I've owned. However, the gauges are better - as I watched them compared to the digital readout of the exact temp. (Unless those are faked too)
2011 F350 SRW 4x4, Lariat, LWB, Diesel, Nav., 5th Wheel and Camper Pkg.
Dak is offline
post #8 of 16 (permalink) Old 11-23-2010, 04:31 PM
Rutcutter's Avatar
I may try and rig up the front grill cover to fit my 11' since I havent been able to sell it.
16' SD CC F350 6.7L FX4
White Platinum Tri-coat
Lariat Ultimate Pkg
5th wheel prep
Leveled front
35/12.50/20 Toyo MT's
11' SD CC 6.7L 4x4 (Sold)
08' SD CC 6.4L 4x4 (Sold)
06' SD CC 6.0L 4x4 (traded)
12' CanAm 1000 XT in Camo
12' Cat 430E 4x4 Backhoe Loader/Cab&Air
Rutcutter is offline
post #9 of 16 (permalink) Old 11-23-2010, 07:51 PM
Does this trucks have a auto Idle up like the 6.0 does. My 06 would idle up when it was cold but I don't think this one does.
06 f-250 stock. 2 injectors 1 fuel pump 1 egr valve and 1 FICM.
3 more injectors and 2 dummy plugs in the oil rail
2011 F-250 s/c 4x4 6.7
21xdbullet is offline
post #10 of 16 (permalink) Old 11-25-2010, 07:17 PM
fixdent's Avatar
Mine started to go onto fast idle at about -15C (about 5F). It reves up to 1000 or 1200 rpm.
Gordon
fixdent is offline
post #11 of 16 (permalink) Old 11-26-2010, 02:46 PM
Balla6.7's Avatar
Being in FL its not a big deal, but even in 80*F weather it takes me about 6-8miles before I get my Oil Temp up to 195-199*F. Idling wont do crap, for about 10-15mins of idling Oil Temps are still >150*F
Balla6.7 is offline
post #12 of 16 (permalink) Old 11-26-2010, 03:07 PM
it does have a high idle mode it was like 8 deg the other day it kicks right on as soon as engine is turnd over. Also it does take a long time to warm up idl for 10 mins seems like nothing, have to dive 10 miles at 75 to get warm. One of mine main concens is the truck really seems to get a diesel smell in the cab anyone else have this issue? It is real strong and likes to choke u and give a good headake?
alexstroker is offline
post #13 of 16 (permalink) Old 11-26-2010, 08:15 PM Thread Starter
Should not be getting any diesel odor in the truck, get it checked!
2011 F450 KR
James_F is offline
post #14 of 16 (permalink) Old 11-26-2010, 10:12 PM
Balla6.7's Avatar
I've heard this on some other sites, get it check ASAP!
'11-F350-6.7L-KingRanch-FX4-SRW
Balla6.7 is offline
post #15 of 16 (permalink) Old 11-27-2010, 04:42 PM
kper05's Avatar
I've run SEIC @ 1,400 RPM's many times and I never smell diesel in the cab and never smell it driving (or whatever we want to call this post-DPF diesel smell).
2011 F-250 XLT SC SB 4x4 3.31 ELD 6.7L PSD
kper05 is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > 6.7L Power Stroke Engine and Drivetrain
