7500 mile 2012 towed for an EGT sensor? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2011 and Up Ford Super Duties > 6.7L Power Stroke Engine and Drivetrain
Old 01-07-2013, 06:24 PM   #1 (permalink)
activepat's Avatar
Is it too much to ask for Ford to come up with another idea than total shutdown of a vehicle for a simple fault like an EGT or a transmission issue?
Nothing like driving my $60k+ truck home and calling roadside assistance since the programs leave me stranded in suburbia Boca Raton at 7:00 at night.
Thank the dear Lord above I was not in a snow storm on the side of a mountain in Colorado where I would have froze to death due to the fact that some engineer/ programmer had this brilliant misconception on how to build it "FORD TOUGH". Shut it down and don't restart. Give that man a raise!
Nice job, Kentucky.
activepat is offline   Reply With Quote
Old 01-07-2013, 07:07 PM   #2 (permalink)
senix's Avatar
in the 6.4 that will happen but after 30 mins it should restart. There is also a jumper wire off the passenger side battery that you can use to restart.
Might look into this and see if that is possible
08F250 CC 6.4 PSD
Banks 6 gun/ram air
40' Stoneridge 5th wheel, coming in at 15.4K.
senix is offline   Reply With Quote
Old 01-07-2013, 08:02 PM   #3 (permalink)
Better it shuts down than burn up. IF there is an EGT failure, the DPF/SCR or cat can overheat. Don't blame Ford, blame your EPA and lawyers who over litigate.
Dad always said,"Knowledge is limited but stupidity knows no bounds."
YT90SC is offline   Reply With Quote
Old 01-07-2013, 09:04 PM   #4 (permalink)
slocub's Avatar
Wrong. If a sensor is so critical that a failure requires the engine to shut down, then the sensor should be redundant. If one sensor fails you keep going on the other sensor with a message to replace the bad sensor.
These sensors are not that expensive. These engines should not be shut down because of one bad sensor.
2012 F550 6.7L EarthRoamer Expedition Vehicle
slocub is offline   Reply With Quote
Old 01-07-2013, 09:48 PM   #5 (permalink)
So which redundant sensor do you believe? The one that reads 600 deg or the one that reads 1400 deg?
Old 01-07-2013, 10:15 PM   #6 (permalink)
slocub's Avatar
In the Ford documentation there are numerous plausibility checks going on between sensors. EGT sensors typically fail with a loss of continuity causing a reading to peg. It would require a software plausibility check between redundant sensors. If one reading is within range of other EGT sensors up or down stream it would be accepted throwing out a sensor displaying an extremely high or low reading.
So with redundant sensors the software would go with the plausible reading based on other sensor readings at the time. Not hard. It is being done elsewhere in the engine.
At the end of the day this is a cost decision by Ford. Rather than cost of an extra sensor Ford has decided it is more efficient for them to shut down the engine and give the owner the job of sorting things out.
Old 01-08-2013, 05:06 AM   #7 (permalink)
senix's Avatar
And to add to this..in the 6.4 at least alll the sensors are the same part number. Bet they are in the 6.7 as well.
these sensors should throw a check eng light or the wrench and reduce power at most. A message in the message center indicating reduced power because of a sensor reading in the exhaust system. Not that hard.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
Old 01-09-2013, 09:51 AM   #8 (permalink)
activepat's Avatar
Good news. The EGT sensor did the trick. However now I have to worry about a repeat occurrence with the other sensor. Anybody know about eliminating the system completely?
Better performance and mileage?
Old 01-09-2013, 09:55 AM   #9 (permalink)
Your a little late into the delete phase....the EPA has shut down h&s. From what has been posted any further tuning will be dpf on tuning. You might call around and see if you can find anyone with kits still in stock, get ready to pay for them though. A buddy of mine bought the last two kits around here and he paid over msrp.
2012 F250- 6.7 Powerstroke Ultimate Lariat FX4- Tuxedo Black, Bakflip F1.
06ram610 is offline   Reply With Quote
Old 01-09-2013, 10:33 AM   #10 (permalink)
activepat's Avatar
Thanks for the reply. Is H & S a company that made these parts if i google search? Sorry for ignorance. dpf?
Old 01-09-2013, 10:48 AM   #11 (permalink)
They were the leaders... I believe there are other companies, I haven't researched it much as I have no plans to delete. I believe edge makes tuners, they are dpf on tuners. Unfortunalty between he EPA and manufactures tuning will soon become a thing of the past. We will be stuck with unreliable overly complicated engines. I have bought my last diesel, they are not the reliable high mileage engines they used to be.
Old 01-09-2013, 10:58 AM   #12 (permalink)
Supporting Member
HoustonRider's Avatar
slocub, wheres the pics of your truck?
2013 F350 - still looking for it
2012 F250 6.7 Lariat Ultimate CCSB FX4
2012 F150 Ecoboost FX4 CCSB FX4
2011 F250 6.7 Lariat Ult CCSB FX4 (sold)2009 F250 6.4 KR CCSB 4x4 FX4 (sold) 2011 Raptor 6.2 Crew SVT (sold at 9,000)
HoustonRider is offline   Reply With Quote
Old 01-09-2013, 11:35 AM   #13 (permalink)
slocub's Avatar
Lots of EarthRoamer pics over at EarthRoamer.org.
Old 01-09-2013, 12:07 PM   #14 (permalink)
Tony M 6.7's Avatar
Maybe the aftermarket guys can figure out better states of tune and regen cycles since they will be forced into "tuning" with the emissions controls in place. No reason why we can't have the best of both worlds. Of course, it definitely would be simpler without the DPF and the EGR equipment. Just my 2 cents.
2012 F-350 Crew Cab, Lariat XLT Ultimate, 4X4, Vermillion Red/Black Leather, FX/4, 3.55 axles, E locker, Awesome truck!!
Tony M 6.7 is offline   Reply With Quote
