Charge Air Cooler - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2011 and Up Ford Super Duties > 6.7L Power Stroke Engine and Drivetrain
Old 05-17-2010, 06:33 PM   #1 (permalink)
Charge Air Cooler
In other threads the relationship between air density and air temp have been discussed. The colder the air the densor the air, thus more oxygen to burn more fuel producing more power. In the past the CAC resided out front with no way to control the cooling substance(air). This caused the temp of intake air(cooled substance) to vary widely as it was dependant on ambient air temp. In eastern Montana this could be from approximatly -50 to 115 deg. Intake air had to be monitored so the computer could adjust fuel input over a wide range of temps.
The 6.7 CAC uses controled temp coolant as the cooling substance. This temp is approximatly 113 deg. Intake air temp should now vary much less making it easier for emissions control. I have not decided if this is a better,worse or neutral setup for other reasons. Anybody else?
'06 F250 Crewcab King Ranch 4X4 auto Black 6.0
'06 40' prairie schooner 5thwheel home while working
'02 Eddie Expedition
'91 F250 SuperCab 4X4 Stock IDI 2 tone brown E4OD
'88 F350 Crew SRW (now parts)
'85 F7000 mechanic service, 3208na CAT
'97 Aerostar 4X4 Extended 4.0
'93 Sable 3.8
'92 Taures 3.0 sold
'84 Bronco II 2.8 4 speed 4X4
'84 Ranger 2.8 2X4
'50 F-1 V8 Flathead 4-speed non syncro(bought new)
'76 Honda 250 Multi Sport(enduro)
'76 F250 4x4 standard 360 Highboy
mont91 is offline   Reply With Quote
Old 05-17-2010, 07:02 PM   #2 (permalink)
Probably just fine. Anytime you compress air, regardless of ambient temp, it is going to get hot. So at the very least you want to bring it back down as close to ambient as possible.
In some cases, like turbine engines, higher inlet temps improve combustion...
NavyF350 is offline   Reply With Quote
Old 05-18-2010, 05:04 PM   #3 (permalink)
NickBeek's Avatar
Funny you should mention this. I have a friend on another forum that monitored manifold air temps and did some mileage testing. He found his best results were at around 110 degrees F.
2006 2500 SLT Mineral Grey, 6 speed, 4x4, Thunder Road Package, MBRP Muffler + 6" dual Stacks, Fast Idle Enabled. Silencer Ring MIA, CFM+ intake horn, Smarty POD, SB Con OFe.
Traded:2004 F250CC FX4 XLT Long Bed Torque Shift, $5.00 AIC.
NickBeek is offline   Reply With Quote
