Cold Weather Idle - Diesel Forum - TheDieselStop.com
post #1 of 20 (permalink) Old 11-25-2013, 09:44 AM Thread Starter
duckstlflg's Avatar
Cold Weather Idle
So this morning I go out to start the truck, in 15 degree weather.
The truck fires right up, but the idle goes straight to about 1200 RPMS and stayed there. This was my first cold weather start with the new truck.
Has any one else observed this, just wondering if it is normal or a problem.
duckstlflg is offline
post #2 of 20 (permalink) Old 11-25-2013, 11:24 AM
outlaw2812's Avatar
Mine does the exact same
2013 F-350 srw Crew cab Tuxedo Black
outlaw2812 is offline
post #3 of 20 (permalink) Old 11-25-2013, 02:34 PM
mlsteele's Avatar
Mine does the same
Steele
______________________________________________
2012 F-250 Lariat 6.7L Crew Cab, Ingot Silver
20"wheels, 3.55 EL gear, Dual Alternators, FX4, Upfitter Switches, Bullet Liner, Weather Tech mats, Reacon side mirror smoke lens, SCT Live Wire TS with PIP tunes, 4" Delete Pipe
My Wife took ownership of:
2006 F-250 Lariat 6.0L Crew Cab, Black w/ Chrome package, Chrome bug guard and door latches
18" stock wheels, Nitto Tera Grappler, 4" Turbo Back MBRP, AccuFab Power Elbo, Edge Insight Monitor, Tinted Windows, Rhino Liner, Husky Floor Mats, B&W Turnover, Air Horn, ZooDad mod, Recon's all around, ARP studs, EGR Delete, SCT from IDP, and a heavy foot
Turned 100K miles 12-23-11
-Bullet Proofed 103K
-New Head Gaskets 58K
-New EGR Cooler 29K
mlsteele is offline
post #4 of 20 (permalink) Old 11-25-2013, 11:29 PM
Painted Horse's Avatar
It's normal. But it really does not produce much heat. Watch 5 min idle at 700 rpm and 5 min idle at 1100 rpm and the temps don't change much.
15 F350 CC Lariat SRW LWB Ruby Red, Ultra Predator Wheels with Toyo 295/65R20, BAKflip Fibermax tonneau, Diesel Products LED lights in the rear bumper and 20" light bar in the front bumper, Firestone Airbags and Airllift Wireless compressor.
11 F350 CC Lariat SRW LWB Tuxedo Black Sold at 145,000 milesl
Painted Horse is offline
post #5 of 20 (permalink) Old 11-26-2013, 08:28 PM
Rutcutter's Avatar
Mine doesn't either,gonna use my block heater more this winter...
16' SD CC F350 6.7L FX4
White Platinum Tri-coat
Lariat Ultimate Pkg
5th wheel prep
Leveled front
35/12.50/20 Toyo MT's
11' SD CC 6.7L 4x4 (Sold)
08' SD CC 6.4L 4x4 (Sold)
06' SD CC 6.0L 4x4 (traded)
12' CanAm 1000 XT in Camo
12' Cat 430E 4x4 Backhoe Loader/Cab&Air
Rutcutter is offline
post #6 of 20 (permalink) Old 11-29-2013, 08:40 AM
RAINEY's Avatar
It's normal if the temp is cold enough. I haven't had my Powerstroke in cold enough temps yet. My Duramax waited about 30 seconds or so before kicking in high idle. If it goes straight to high idle upon start I don't think that a great thing since oil hasn't even moved yet.
Jason
2012 F350 Powerstroke Crew Cab SRW
RAINEY is offline
post #7 of 20 (permalink) Old 11-30-2013, 09:09 AM
HoustonRider's Avatar
It's normal. The truck knows it's cold and goes to high idle to assist with warm up.
I have a Ram 6.7 that you can move to high idle by pressing cruise control on then the set button. Moves idle to 1100 RPM.
Sent from AutoGuide.com App
2012 F250 6.7 Lariat Ultimate CCSB FX4
2012 F150 Ecoboost FX4 CCSB FX4
2011 F250 6.7 Lariat Ult CCSB FX4 (sold)
2009 F250 6.4 KR CCSB 4x4 FX4 (sold)
2011 Raptor 6.2 Crew SVT (sold at 9,000)
HoustonRider is offline
post #8 of 20 (permalink) Old 12-08-2013, 01:21 PM
Cold start behavior
It's been colder than usual here in Rapid City lately and it's given me a chance to see what this motor does in the cold. Probably not as cold as some of you have seen but I found it interesting. Sitting all day at work, I started the truck in -5f temp with the oil temp also at -5f and it started right up no issue other than a slight diesel smell in the cab until I warmed up and started driving. The next day heading in to work it was -15f outside but the truck was plugged in and the oil temp at startup was +10f. Again started right up but this time I got the cold weather message "engine warming please wait 30 seconds".
Two questions: Does the PCM use OAT to determine starting strategy instead of ECT or EOT;where is this cut off -10f? I figured a plugged in engine wouldn't ask me to wait but a sub-zero oil temp start would. I couldn't find in the 6.7 bible.
Also, is the slight diesel odor in the cab normal on these 6.7s when it is really cold? Just cylinder wash? Looking for some similar experiences.
Either way. I plug her in to a timer when it's cold if I'm home and otherwise let it idle for 2-4 minutes to warm the engine at least a bit.
13 F-350 King Ranch, Ruby Red, 6.7 PSD, FX4, CCSB, 3.55, 20s
AFLAX21 is offline
post #9 of 20 (permalink) Old 12-08-2013, 01:50 PM
I'm probably old school, but it's always bugged me how the new vehicles, whether car/truck, gas/diesel, seemed to fly wide open when it's blue cold.
I'd much prefer a reasonable delay to allow the oil to start flowing before they rev up.
2001 Lariat, F250, 7.3, 6-speed, 3:73, Ford AIS, MBRP 4" turbo back, ATS ported housing, 205 t-stat, Infinity DX w/DP Tuner 80hp tow, coolant filter, Hutched & Harpooned, EGT & Boost gauge. Fuel Mavericks with 285/18, 86k miles(Jan-2017) Bought brand new April 2001.
aclasshog is offline
post #10 of 20 (permalink) Old 12-08-2013, 02:31 PM
rforsythe's Avatar
I have to assume engineers have thought of that too. There will always be residual oil in passages and around the top end components, and these engines build oil pressure very quickly - the 6.0's won't even start without high pressure oil being present, not sure if the 6.7's have that as well.
Either way, it won't be metal on metal or anything like that.
2013 F350 Lariat 6.7L, CC LWB SRW, Ruby Red with all the trimmings.
Recovering former 6.0L owner (2005 Lariat).
rforsythe is offline
post #11 of 20 (permalink) Old 12-08-2013, 03:08 PM
Depending on temp, the 6.7, 6.4 and the 6.0 will not allow any fuel pedal input until a certain temp or idle time is allowed for.
jamesrxx951 is offline
post #12 of 20 (permalink) Old 12-08-2013, 04:02 PM
Dak
Good thing he never had an older Turbo RX-7. Those things redlined when started - all the way to around 11,000 rpm or so. (I forget exactly where the redline is, but it's motorcycle high) And of course you had to fill up with oil, before you filled up with gas in those too.
I gotta believe that the engineers thought of cold starting as well. I've only been in the teens in my truck a couple of times where the fast idle kicked in. Because of threads here, I don't idle it for long before we go as conventional wisdom now says that is a waste of fuel. Typically it idles for around a minute or so as we all get in and fasten our seatbelts.
2011 F350 SRW 4x4, Lariat, LWB, Diesel, Nav., 5th Wheel and Camper Pkg.
Dak is offline
post #13 of 20 (permalink) Old 12-09-2013, 11:13 AM
I live in Alberta and we have just had the coldest weather in along time. -34 AND WITH WIND CHILL -49. My diesel truck I noticed started up revving high 1500 and stayed that way for a long time. Now that I have read it here I see it is normal.
I am also wondering about the remote starter Ford has put on these trucks. I wonder if the glow plugs are being warmed up enough before it starts the truck (I have noticed there is not much of a delay after pushing the start button)in this cold or warm weather.
oohboy is offline
post #14 of 20 (permalink) Old 12-09-2013, 02:54 PM
gearhead1011's Avatar
My Photos: (10)
That's normal on the glow plugs, they will heat to over 2,000* F in 2 seconds. In the temps we have around here you really have to pay attention when you turn the key on if you want to see the GP light.
2012 F250 XLT
Sterling Grey
6.7 CCSB 4X4
gearhead1011 is offline
post #15 of 20 (permalink) Old 12-09-2013, 03:02 PM
If I understand you correct, your saying even though it is -30c or colder, it is normal for remote to just start the truck. My friend has a dodge and he has to wait a good minute before the glow-plug light goes out. I don't want to damage my plugs.
oohboy is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > 6.7L Power Stroke Engine and Drivetrain
