DEF fluid experation - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 10-19-2012, 08:07 PM Thread Starter
kip
I was talking to a ford dealer about the increased use of DEF fluid and diesel fuel since the NOX update and he told me to check the experation date on the DEF cause that could cause increase use of fluid. I use the Blue DEF brand and could not find any date on the box so is this BS or what ?
2011 F350 CREWCAB LB 4X4 6.7 DIESEL AUTO 3.55 AXLES
kip is offline
post #2 of 9 (permalink) Old 10-19-2012, 10:40 PM
Yes. DEF has a very limited shelf life.
http://www.cumminsfiltration.com/pdf...es/MB10033.pdf
Dad always said,"Knowledge is limited but stupidity knows no bounds."
YT90SC is offline
post #3 of 9 (permalink) Old 10-24-2012, 08:34 PM
Adventure Rider's Avatar
Good stuff to know - thanks for the link
2012 F250 XLT 4x4 CC SB FX4 6.7PSD 3.55ELD Tuxedo Black
Adventure Rider is offline
post #4 of 9 (permalink) Old 10-25-2012, 11:53 AM
Ok guys heres the scoop on def expiration dates.
According the "Blue Def" manufactures website the def fluid has a 2year shelve life.
It's best to store between 12 deg F and 86 deg F. Also if the fluid freeze's it will not hurt the strength upon thawing.
So there ya go fellas.
2011 f350 4x4 cc,Lwb
mopwr is offline
post #5 of 9 (permalink) Old 10-25-2012, 02:54 PM
Tony M 6.7's Avatar
Good to know mopwr. Thanks for posting.
2012 F-350 Crew Cab, Lariat XLT Ultimate, 4X4, Vermillion Red/Black Leather, FX/4, 3.55 axles, E locker, Awesome truck!!
Tony M 6.7 is offline
post #6 of 9 (permalink) Old 10-26-2012, 09:58 PM
Kip i don't think the dealer guy was tryin to BS you but he might have been talk'in out his -ss....thats all(as far as expiration date vs consumption).
As to using more def fluid....i could see that.The more regens you have the more def you'll use....kinda goes hand and hand.
mopwr is offline
post #7 of 9 (permalink) Old 10-27-2012, 12:36 AM
Painted Horse's Avatar
DEF is used all time, Not just during regens. It is basically sprayed into the SCR at 1.5% to 2% ratio of the diesel fuel burned.
15 F350 CC Lariat SRW LWB Ruby Red, Ultra Predator Wheels with Toyo 295/65R20, BAKflip Fibermax tonneau, Diesel Products LED lights in the rear bumper and 20" light bar in the front bumper, Firestone Airbags and Airllift Wireless compressor.
11 F350 CC Lariat SRW LWB Tuxedo Black Sold at 145,000 milesl
Painted Horse is offline
post #8 of 9 (permalink) Old 10-27-2012, 12:37 AM
Yes it expers. You need to check exper date closely. May make the truck sick like eating expered meet.
1997 F350CC, 4x4, PSD Tipper pro kleenex open filter. Roggen 6" lift kit with 26" ratflex 12" offset tires. Downpipe cut and welded to adapt 3" into a 12" outlet. 12" muffler cut and adapted to 2", then a special turbo manifold from a volkswagon modified to flank out to 3" to the tail pipe. Interior from a Corvair modified by cutting 6" off the padding. Snize and snide 32gallon aux tank mounted in rear seat, rear seat relocated to bed. Bed shortened to 4ft.
RonKZ650 is offline
post #9 of 9 (permalink) Old 10-28-2012, 04:36 PM
Yes it does expire......2 years from the date on the package.
That shelf life could also be shortened if it's stored in direct sunlight or in temps above 86 deg F for long periods.
For those that are interested there is a website ypu can go to for answers to your questions.
Goto ....WWW.discoverdef.com....then to Faq's
mopwr is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > 6.7L Power Stroke Engine and Drivetrain
