Digital shift indicator - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2011 and Up Ford Super Duties > 6.7L Power Stroke Engine and Drivetrain
Old 11-19-2012, 10:11 PM   #1 (permalink)
Who here has his Digital shift indicator in the dash come on as soon as heputs it in drive with out hitting the + or - on the shifter?
Speed2 is offline   Reply With Quote
Old 11-19-2012, 10:27 PM   #2 (permalink)
dslbrnr's Avatar
Mine comes on and shows 1-6, is that what your talking about?
2012 F350 CC/SB 6.7 4X4 Lariat, 3:31 Gears
dslbrnr is offline   Reply With Quote
Old 11-19-2012, 10:33 PM   #3 (permalink)
kyle_1997's Avatar
On my 2011 F250 I had to hit the + - on the shifter once to turn it on, but always was on after that. On my new 2012 F450 it was already on, hasn't turned off yet.
-Kyle
US ARMY (Support our Troops!)
Present:
o 2012 F450 Crew Cab Lariat, Autumn Red
Past:
o 2011 F250 Crew Cab Lariat, Golden Bronze/Tan
o 2008 F250 Crew Cab Lariat
o 2006 F250 Crew Cab Lariat, Black/Tan, 6" Procomp Lift, 35" Procomp Xtreme AT, 18" Helo Maxx 8, 3.73 gears, 4" MPRB Turbo Back, AirRaid Intake, Edge Attitude/Monitor. **(STOLEN from my El Paso, TX driveway 14 OCT 2008)**
o 2001 F250 Crew Cab Lariat, Red
kyle_1997 is offline   Reply With Quote
Old 11-19-2012, 11:24 PM   #4 (permalink)
After 12b33 flash It doesn't turn on any more. I have to hit + or - every time.
Wondering if its the flash that caused that?
Old 11-20-2012, 06:34 AM   #5 (permalink)
Hdslider's Avatar
Take it back to dealer. There have been a few the tech didnt follow procedures. Have them or another dealer reflash it. It should be fine
2011 F-350 Superduty 6.7. CC,LB, SRW 3.31 ELD.Vermillion Red.Bakflip HD,Spray in bedliner. Tint all windows.Edge Insite CTS. DDM Tuning,Hi/Low HID'S (H13,55W.Bull Bar. red grill lettering/stainless tailgate letters.AMI chrome locking fuel door.Plazma light bar.
2011 F-350 Superduty 6.7. CC.LB SRW Oxford white. (FORD BUY BACK)!!!
2009 F-250 Superduty 6.4. CC.LB SRW Trade in.
2010 Ford Focus. All the bells and whistles. Red Wifey's econo box
1994 F-150.XLT.5.8 litre 351. E4ODE.Extended cab LB. 198,000 miles.Don't use a drop of oil.
Hdslider is offline   Reply With Quote
Old 11-20-2012, 07:16 AM   #6 (permalink)
Painted Horse's Avatar
It should stay in what ever position you left it when you turned the truck off.
Make sure you are not bumping the button when you shift to park and then shut down. It should still be displayed when you restart the truck.
When they reflashed mine for the 400/800 reflash. My display was not visable. I took it back in. Tech said computers said the flash went thru. But I insisted they redo it, since I had no gear display. After they reflashed it, The gear display appeared and has worked fine since. So if it's not working properly, just have them reflash it.
11 F350 CC Lariet SRW LWB Tuxedo Black
B&W turnover ball
http://www.fuelly.com/sig-us/59436.png
Painted Horse is offline   Reply With Quote
Old 11-20-2012, 02:19 PM   #7 (permalink)
Actually the 400/800 flash set it so it would remain the way it was when the truck was shut down. Customers complained about having to reset it every time they restarted the truck, so they set it to rmember the last setting. You may have to turn it on after a pcm reflash, but it should remember the way you left it.
BH
Bounty_Hunter is offline   Reply With Quote
Old 11-20-2012, 05:09 PM   #8 (permalink)
Actually prior to the 400/800 the display would terminate every time you changed the transmission. i.e. Go from Drive to Reverse and the display was gone. It was more than just turning the truck off.
B&W turnover ball
Old 11-20-2012, 06:44 PM   #9 (permalink)
Originally Posted by Bounty_Hunter View Post
Actually the 400/800 flash set it so it would remain the way it was when the truck was shut down. Customers complained about having to reset it every time they restarted the truck, so they set it to rmember the last setting. You may have to turn it on after a pcm reflash, but it should remember the way you left it. BH
Ok good, so I am not imagining things here. My truck never had 400/800 flash. It's a 2011, came from the factory 400/800 and YES it did display the Digital shift indicator with out having to hit the +- every time. I'll take it back and see if there's a way to fix this. We will see if HDslider is correct.
Thanks Guys
Old 12-02-2012, 09:18 AM   #10 (permalink)
Update
All I got is, you have to hit the + - every time. They don't agree that the flash has anything to do with it. They will look at it but it would be out of my pocket.
Old 12-02-2012, 09:59 AM   #11 (permalink)
Hdslider's Avatar
Speed 2 how many miles on your truck. And no you should not have to hit +or- each time. You start the truck.
Old 12-02-2012, 11:14 PM   #12 (permalink)
16000
Old 12-03-2012, 12:05 PM   #13 (permalink)
Hdslider's Avatar
Buddy go find another dealer.as the one your dealing with has there head up there rectum. You have bumper to bumper 3years 36, 000 miles.
Old 12-10-2012, 11:25 AM   #14 (permalink)
It's done. They had some trucks in the lot, Showed them. Black and white.
In the New Year it will get fixed. Of course they are Baffled and the look on their faces tells me they have no idea where to begin. Also my factory reset
doesn't fully work any more either. Although the Dash remembers my settings regardless what screen i choose. I cannot factory reset my wiper control. If i chose no wipe and hit reset it stays there. If i chose wipe and hit reset it stays there. I do realize that the reset is for everything in the dash but using the wiper control seemed an easy way to check it out.
Old 12-10-2012, 01:59 PM   #15 (permalink)
Hdslider's Avatar
Speed. Im glad they understand wow he really has a problem. Dont undertstand why till after new year.I sure wish u a quick great repair.
