EGR Cooler - Diesel Forum - TheDieselStop.com
post #1 of 37 (permalink) Old 11-19-2012, 07:55 PM Thread Starter
EGR Cooler
I was wondering if anyone else here had had or heard of cooler issues on the 6.7? Check engine light came on, truck to dealer, and tech says EGR cooler is plugged. They have new cooler ordered. They also said they did send info to Ford Eng because its the first one at that dealer they have seen with this problem. The build date is 4/10 and I bought it in May 2010, the truck has 40516 miles on it. Hopefully it is just a fluke, because stuff can break. Will shall see.
Woodsrydr is offline
post #2 of 37 (permalink) Old 11-22-2012, 08:02 PM
i got my 2011 used with 21000 miles the oasis report said mine was replaced also,so far the new one is doing fine , mine was also an early build hopefully it was just a bad batch of EGR coolers
6.7 FORD is offline
post #3 of 37 (permalink) Old 11-24-2012, 03:48 PM
i have only replaced 2 sense these trucks came out. both trucks were cab and chassis models. both were boom trucks. which means they idle for long periods of time to run the pto to run the boom. both were pluged solid with soot. the pick up truck egr housing is aluminum. the cab and chassis model is cast iron. i realy dought that has anything to do with failure but i really think its just a fluke. i do not think these are going to have egr problems like the 6.0.
FordDieselTech101 is offline
post #4 of 37 (permalink) Old 02-06-2013, 02:02 PM
My service engine light came on yesterday. Went to dealer this morning. Code was for EGR valve and Ford Engineering told them to replace the valve and check the cooler. Truck has 5400+ miles on it so far. Hope this is not the start of something else. Sure would not to have to trade in an almost new truck for a DMax.
Update 2/8/13: Dealer was told by ford to replace the cooler and send it to them. Cooler was replaced and I will be picking up the truck this morning. I will be asking if there is something that I did or can do to not have whatever happened to take place in the future. Will add more when I return from the dealer.
2012 F250 6.7L SC SRW 4x4
Fulltilt bedcover by extang.com
Curt 20k hitch
2010 Dutchman Voltage V3200 Toy Hauler 5th wheel
1994 Honda GL1500
2000 Yamaha Venture
Last edited by lightfootrw47; 02-08-2013 at 08:52 AM. Reason: Update to original posting.
lightfootrw47 is offline
post #5 of 37 (permalink) Old 02-07-2013, 12:00 PM
rforsythe's Avatar
Given that these would have a new cooler design and don't use silicate-based coolant in general like the 6.0's, I wouldn't expect to see the failures happen anywhere near as much. Faulty parts do occur from time to time, but the different coolant alone is probably enough to avoid epidemic failures like before.
rforsythe is offline
post #6 of 37 (permalink) Old 02-07-2013, 05:18 PM
I've seen a couple of plugged coolers on the powerstroke sites.
2012 F250- 6.7 Powerstroke Ultimate Lariat FX4- Tuxedo Black, Bakflip F1.
06ram610 is offline
post #7 of 37 (permalink) Old 02-07-2013, 05:44 PM
rforsythe's Avatar
Did they say what caused it?
A couple is still better than every third truck a la 2004-2007, but I'm curious now. Since the coolant (largely considered the cause of the 6.0 cooler sludge) is different now, what would trigger a 6.7L cooler plugging up? Was there some other contaminant present?
post #8 of 37 (permalink) Old 02-07-2013, 08:52 PM
I don't know...check out powerstroke.org. They didn't give any reason, just stated ford covered it Under warranty. It seems like it has gotten worse since winter hit, could have something to do with extended idling.
06ram610 is offline
post #9 of 37 (permalink) Old 02-08-2013, 07:49 PM
I am curious if those experiencing EGR valve and/or EGR Cooler failure are also using a diesel fuel additive on a regular basis?
TNX
Bob
12 F-350 CC Fx4 6.7 3.55E LWB Tblack K-Ranch Edge Insight CTS; RollBAK G2
07 Montego Bay 34RLB3 5th wheel
(traded the 04 w/ 56K mi. on 3/25/06; the 06 w/ 45K on 10/1/07; the 08 F350 DRW CC Fx4 w/67K mi on 2/15/12)
bnmccoy is offline
post #10 of 37 (permalink) Old 02-09-2013, 07:08 PM
I have a 9/10 build and have had cooler replaced. CEL came on and dealer said cooler bad, drive until part arrived. The CEL went off and then back on after a long trip. Replaced about 4 months ago and no problem since.
2011, F250, 4X4 Crew Cab, Short Bed, Lariat, Silver/Grey,6.7ltr, 20"tires, Electronic locking axle, off-road package, rapid htr,nav sys, clearance lights, upfitter switches, bed liner, Lariat package. EXTRAS: 35x12.5x20 tires, Leer 100XL cap, Titan 52 gal tank, Firestone ride rite air bags
Truck History:
2005 F250 SD, CC, SB, diesel
2003 F250 SD, CC, LB, diesel
1999 F250 SD, CC, SB, diesel
1997 F250 Light duty, extended cab, SB
1997 F150 extended cab, SB (Lemon)
1992 F250 long bed, diesel
1985 F250 long bed, diesel
1982 F250 long bed
1974 F100 long bed
1956 F100
OldFlick is offline
post #11 of 37 (permalink) Old 02-10-2013, 07:36 AM
Just had mine done on 2/7. Check engine light came on went to the dealer they told me the cooler has to be ordered. I have 42k on the truck built date 4/2010 never added any type of additive to the fuel.
Before the check engine light came it felt like the truck was losing power.
Now with the new cooler installed seems to have more power.
The tech who did the replacement ask me if i do a lot of idling.This is the first real problem i had and hope no more in the future.
This is an awesome truck.
2011 F-250 4x4 Crew Cab Lariat 172" WB
Loaded w/Western Wide Out snow plow.
sg2005 is offline
post #12 of 37 (permalink) Old 02-10-2013, 06:40 PM
Dan in Sunny FL's Avatar
Did you idle a lot?
6.7 4x4
Tuxedo Black
Dan in Sunny FL is offline
post #13 of 37 (permalink) Old 02-10-2013, 09:40 PM
Didn't idle much.The tech told me to start to add additive to the fuel.
So not sure what to do at this point.
I had many Ford Diesels and never has to add any thing to the fuel.
sg2005 is offline
post #14 of 37 (permalink) Old 02-11-2013, 08:25 AM
If I am going to be sitting in one spot idling for and period of time (waiting on the wife to come out of Wal-Mart for example) I turn on the SEIC. I don't know if it help, but it does seem to eliminate the dieseling on that first hard throttle pulling out into traffic after an extended idle. I also seem to have fewer regen cycles doing this.
2011 F350 Lariat DRW 6.7L
25' PJ Flatbed Equipment Trailer
2005 XLT F250 6.0L(Wife's truck)
2005 Bobcat T300
gtstang462002 is offline
post #15 of 37 (permalink) Old 02-13-2013, 12:24 PM
EGR Cooler/Check Engine Light
I had the same problem. Build date 05/10, miles 46000. Took to dealer, first they told me the EGE Cooler had to be replaced, but later said all that was needed was to update for the computer. When I asked what the update was the service consultant told me the computer was reflashed. That direction came from Ford to solve the problem, so he says. The problem with all this is on my paper work from the dealer shows "NO PROBLEM FOUND" in caps. I still don't know what the dealer has done to my truck nor do I really know what was done by Ford to make the check engine light go off. I will contact the service manager and update when I find more out. Also was told to replace my fuel filter, because during the multi point inspection "FOUND fuel filter to appear old" in the inspection report. Well at this dealer I just had both fuel filters replaced at 44,000 miles. Or did I. This all sounds bad. I live in Central Florida, are there any good dealers out their.
JFord 2011 is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > 6.7L Power Stroke Engine and Drivetrain
