flood damaged 2012 f250 6.7 - Page 3 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2011 and Up Ford Super Duties > 6.7L Power Stroke Engine and Drivetrain
Old 02-10-2013, 11:49 PM   #31 (permalink)
flood diesel update
haven't had alot of time to work on it,so far i have removed upper intake and removed the glow plugs to push water out of cylinders,i unhooked fuel lines,i also had to take the starter of it was stuck,i put it back on and spun the engine,i am going to order a instrument cluster and bcm junction box tomorrow,next step will be to pull tank and blow out lines.just thought i would post an update on whats going on,i honestly dont think it is going to be as bad as some have said
12superduty is offline   Reply With Quote
Old 02-11-2013, 07:38 AM   #32 (permalink)
Good luck man and keep us updated. Im very interested to see how this plays out.
8mpg is offline   Reply With Quote
Old 02-11-2013, 11:49 AM   #33 (permalink)
OT
OT's Avatar
12..Any way you can verify if "new electronic instrument cluster" is actually simple swap out or is re programming computer required? Good luck on your project.
03 F250 XLT SC/SB 4X4 6L (stock) TqS. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline   Reply With Quote
Old 02-11-2013, 06:36 PM   #34 (permalink)
I am almost certain the cluster will have to be programmed to the truck.last time i swapped one from an 02 to 03 and it had to be programmed.i have a friend that works for the local ford dealer and he is able to do this for me outside the dealership.it really helps out on cost,cause you no how it is when you take something to dealer for repair.i had to bite the bullet and order cluster from ford it cost me $520.couldn't find a used one anywhere with the monitor made in it.
Old 02-13-2013, 05:23 AM   #35 (permalink)
how could there be water on top of cylinders but not in the oil ? just asking ? ! thanks
'12 mercedes s350 bluetec, yes it s a diesel ! !
'12 gmc sierra slt cc, lb, duramax, carbon blk outside, blk leather inside.
'08 mb sl550, my little red its not a corvette
'77 450SL benz in the family since new.
'91 350sdl turbo diesel benz
'10 MAZDA 6i, DAUGHTERS RIDE
'90 560sel benz. what a pos.
hapaschold is offline   Reply With Quote
Old 02-13-2013, 07:36 AM   #36 (permalink)
The crankcase is fairly well sealed in order to comply with emission requirements. If the intake and exhaust fill up with water it will end up on top of the pistons. as well as in the intake, turbo, and so on.
2011 F350 Lariat DRW 6.7L
25' PJ Flatbed Equipment Trailer
2005 XLT F250 6.0L(Wife's truck)
2005 Bobcat T300
gtstang462002 is offline   Reply With Quote
Old 02-13-2013, 08:35 AM   #37 (permalink)
IS the interior already stripped and set up to dry?
I think it would be very wise to crank it over and expel water and then take out the MAP/Boost sensor on the top of the black air inlet crossover that leads to both inlet "manifolds" that are integral with valve covers. Use this opening to fog WD-40 or even something that is a heavier oil and crank engine over to get cylinder walls coated. If it is even a couple of days before it runs after you get water out, rust will form on cylinder walls. Oiling the cylinder walls will help a lot with that.
2006 F450 CC Hauler bed 4x2 6.0 L Pstroke/Torqshift, Lariat, 4.30 r/a.
2006 F350 Lariat CC Dually 4X2, 6.0 TQShift 4.10 LS, STOCK.
36 foot double tandem axle flatbed trailer.
36 foot Sooner 6 horse large dressing/ mid tack.
15 horses with good balance from being hauled behind a P'stroke.
jimmy is offline   Reply With Quote
Old 02-13-2013, 05:18 PM   #38 (permalink)
interior has been taken out and is dried completely.i appreciate the advice on removing that sensor.i will do that.i am waiting for my cluster.i will let ya'll know when i have some more news.
Old 02-17-2013, 06:00 PM   #39 (permalink)
Cobrahauler's Avatar
Keep the updates flowing!! Great project, I have a friend locally who's being doing extensive repairs and rebuilds on the 6.4s, buying them on Copart, properly repairing them, and selling them. Doing quite well at it.
'11 Platinum white 6.7, two tone 350 Lariat CC SRW. Short bed FX4. TracRac rack system. I can only hope this truck is as good as the 02 was.
02 CC 4X4 Lariat K&N,4" Turbo back, Autometers on A pillar, DP Tuner chip, 20s w/ Nitto Terra Grapplers. Never to the dealer for anything. Traded in on the '11 350.
07 Mustang GT
67 Mustang 289 Coupe
Backdraft Cobra #808 Track car 408CI 500rwhp
07 Jeep Unlimited, 4"lift on 35s
Cobrahauler is offline   Reply With Quote
Old 02-17-2013, 11:21 PM   #40 (permalink)
well i had time to pull the fuel tank and the urea tank.lots of water in both.drained both cleaned everything really good ready to put em back in.also pulled the fuel filter holder of the frame and cleaned it as well.still waiting on my cluster to come in.i sure hope it gets here this week.i am getting pretty close to seeing what happens when i try to crank it.i did purchase a factory radio of ebay plugged it up and played with no problems.i will let yall know when i have anymore news.
Old 02-18-2013, 08:09 AM   #41 (permalink)
Are you taking pictures of this whole thing? Once you get it running I'd love to see some write-up with pics on how you took one of these computerized beasts from drowned to driving. I have no doubt you'll make it work, I just really want to see how far into it you have to get.
rforsythe is offline   Reply With Quote
Old 02-18-2013, 08:51 PM   #42 (permalink)
scjmc's Avatar
Fresh water is not always terminal... My company truck was flooded and engine hydrolocked. They took the plugs out and blew the water out by cranking starter. That was 3 or so years ago and it has been fine. I have seen many outboard motors go down in salt water and be revived.
The truck is new enough that maybe all of the connectors stayed dry like they were suposed to. Who knows...
2011 F350 SRW 6.7 Lariat 4X4 CC 3.31ELD
2006 Lincoln LS V8
1971 Mustang Fastback 351
scjmc is offline   Reply With Quote
Old 02-19-2013, 08:43 PM   #43 (permalink)
That looks like a sweet ride, hopefully you can get it up and going without too many problems or major expenditures. I actually look forward to seeing your updates on it.
ordered 10/7/2003: built on 11/10/2003: picked it up 11/21/2003: 2004 f-350 6.0l psd, black lariat with two tone tan on the bottom, srw, cc, lb, 4x4, fx4, auto, w/ everything except for dual alts, aic, pto option, sunroof. supposed to get heated seats and clearance lights, but somehow got left off w/o us paying though. the lights might be a summer project!!! the truck is great.
56,200k miles on it (close to it at least)
husky liners for front and rear
rhino lined bed
30k gooseneck hitch installed
jimmi jammers for the doors
vent visors for cc, bug guard up front
ford stainless grille
dppi catback exhaust
snowcrash is offline   Reply With Quote
Old 02-20-2013, 08:54 PM   #44 (permalink)
I finally got my cluster and bcm.put the cluster and bcm.the bcm will have to be programmed so i decided to put the old bcm back in and to my suprise everything went to working in the cluster.i still have an issue with the ignition though.my cluster monitor says i have a system start fault.after researching the problem i have concluded it may be the pats transceiver.going to do some voltage tests on it tomorrow.still gotta long road ahead but i am getting there.i will post again when i find out more.
Old 02-24-2013, 10:28 AM   #45 (permalink)
flood diesel update
got my starter problem fixed.my buddy reprogrammed the keys and it now everything electrical in the cluster appears to be working.he also retrieved the miles from the pcm.it has 10k miles on it.i now have ordered a new trans filter external and internal.i am going to change fluid and filters in trans before attempting to crank.hope to be ready to try and crank it by the end of the week.i will let ya'll know how i come out.
