Ford engine brake - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 03-07-2012, 03:54 PM Thread Starter
Ford engine brake
Does the 2012 F350 sb srw desiel engine have a engine turbo brake like gm or dodge. I'm a flat land heading to Utah and Colorado and think this is a deal breaker in my new truck purchase.
Bd55
bad55 is offline
post #2 of 10 (permalink) Old 03-07-2012, 04:14 PM
spedkid94's Avatar
Yes the 6.7l has an exhaust brake.
2011 F-250 XLT CC Blue
Toyo M/T on Fuel Hostage 20", AMP Steps,
Extang Solid Fold, Recon LED Brake Lights,
Recon Projection Headlights, AFE Exhaust,
Katzkin Leather, Smittybilt M1 Grill
Bilstein 5160 Shocks, 20" Rigid LED Light,
Firestone Airbags
spedkid94 is offline
post #3 of 10 (permalink) Old 03-07-2012, 04:25 PM
luke0204's Avatar
The 6.7L has an exhaust brake in tow/haul mode...overall it works great for me, have had no issues keeping my rig under control empty or loaded.
I did have a 6.7L Cummins with a stick and exhaust brake...I hate to admit but that is the ultimate combo if you want to slow down. The exhaust brakes with automatic transmissions are not nearly as effective on slow down since they will not hold gears like a manual to let the exhaust brake slow the vehicle. My Cummins worked just like a big rig and sounded like one too.
2017 F250 CCSB, 4x4, 6.7L, 3.55 E-Locker, XLT Premium, Max Tow
Past Fords:
2011 F350 CCSB, 4x4, 6.7L, 3.31 E-Locker, MBRP 5" DPF Back, Innovative Torq 2
2011 F-250 CCSB, 4x4, 6.7L, 3.31 E-Locker, MBRP 5" DPF Back
2009 F-250 CCSB, 4x4, 6.4L,Torqshift, Spartan
2005 F-250 CCSB, 4x4, Torqshift, 4" Cat Back
2004 F-250 CCSB Fx4, 6spd, Bully Dog Intake, Banks 4" turbo back, Edge Juice
2002 F-250 SCSB, 6spd, AFE Intake, ATS Turbo Back Duals, B&D 60hp chip
luke0204 is online now
post #4 of 10 (permalink) Old 03-07-2012, 06:11 PM Thread Starter
Thanks guys. I guess a new ford it is.
bad55 is offline
post #5 of 10 (permalink) Old 03-07-2012, 09:14 PM
Painted Horse's Avatar
The trick to the Ford Exhaust brake is to get Into the right BEFORE you start downhill.
The exhaust brake needs RPMs in the high 2000 to lower 3000 rpms to be effective. Going downhill in a gear at 1800 rpm will not produce much back pressure. For example 2nd gear will hold a pretty good load at 45 mph But 3rd gear won't hold much at 50 mph. Just slow to appropriate speed and use the +/- button to down shift to the correct gear.
I frequently come down Parleys Canyon ( I-80) and Daniels Canyon ( US40) in Utah, Both have 7% grades, pulling a 13,000 lb GN horse trailer, I can come down those grades and never touch my brake pedal. The exhaust brake holds the load just fine.
15 F350 CC Lariat SRW LWB Ruby Red, Ultra Predator Wheels with Toyo 295/65R20, BAKflip Fibermax tonneau, Diesel Products LED lights in the rear bumper and 20" light bar in the front bumper, Firestone Airbags and Airllift Wireless compressor.
11 F350 CC Lariat SRW LWB Tuxedo Black Sold at 145,000 milesl
Painted Horse is offline
post #6 of 10 (permalink) Old 03-08-2012, 03:56 PM
Painted Horse, what gear are you in on that 7% grade?
I pull a fifth wheel trailer (#17000), most years I buy a new Ford, and have always experienced like you no need for truck brakes on a 6% grade.
This 2011 has the weakest grade braking system of any Ford I have run. I just ran down the Camp Verde 10 mile 6% grade in Arizona, third gear between 3500 to 4000 rpm, needed the truck brake 5 times. This is just one example, has happened to me many times.
This issue is a big deal with me, between needing air bags and this grade braking issue, can't understand what Ford is thinking.
I have always been a head, I really don't want to think about the dark side, sooooo hope Ford gets there arms around these issues.
2015 F-350 drw, diesel, 4X4, lariet
Cessna is offline
post #7 of 10 (permalink) Old 03-08-2012, 07:30 PM
I'm pulling a 13,000lb trailer and your 4,000 lbs extra probably makes the difference. 2nd gear for 45 mph and 3rd gear for 65 mph
I had a B&D Exhaust Brake on my 2006 6.0L and this new Ford is every bit as strong in braking IF I get it slowed down and into the right gear at the top of the grade.
post #8 of 10 (permalink) Old 03-09-2012, 09:33 PM Thread Starter
So for going down long grades take it out of auto put it in third gear and keep RPms below 4000. Is this the best wat to go down hills?
bad55 is offline
post #9 of 10 (permalink) Old 03-11-2012, 12:25 PM
Jassman's Avatar
thats the key..to have it in the correct gear. Unfortuneatly, the Ford set up is not as good as the Cummins, nor the Duramax. The Cummins is by far the loudest of the group and you think it is doing the best job at slowing down your load vs the Duramax's slightly more sophisticated system which is slightly better and quieter getting the job done. FORD NEEDS TO GET THIS PERFECTED. Everything else on the Fords are better than the competetion except this. Jeff
2015 F350 LWB CC 3.55 Platinum on order
2012 F150 FX4 w appearance package
2011 F350 LWB CC 3.55's GPS Lariat. my truck
2010 F150 FX4 5.4 3.73's
2008 F350 LWB CC 6.4 dually. 3.73's
2007 F350 LWB CC 6.0 Dually, 4:10, ID SCT tunes Xtreme race, Xtreme street, and tow w/agressive brake, MBRP Turbo back cool duals AFE Mega 2 ..
Jassman is offline
post #10 of 10 (permalink) Old 03-11-2012, 01:24 PM
You can leave it in Drive and just press the - button to remove the option for 6-5-4 gear. I often just slow down to the right speed and press the cruise button and let the tranny find the gear. I've never bothered to shift the lever to M and manage the gears manually.
It's definitely not a perfect solution. And maybe for your 16,000 lbs it not strong enough. But i've learned to make use of it with my 13,000 lbs horse trailer. Just learn what speeds/gears work the best for your load. I've found that comming down Daniels Canyon ( head of canyon has some 8%) that I can't expect my truck to hold back the load at 65 mph. So I slow to 50mph as I crest the summit and get into the right gear and it will hold me under 60 mph. If I leave the cruise set at 65 as I crest the summit, I'll soon be doing 75 mph unless I apply brakes. So slow down to a 5 mph less than the speed you want to take corners at and set the cruise.
I've come down Daniels Canyon, Parley Canyon and off Logan Canyon into Bear Lake and never touched my brakes and stayed at speeds suggested by the yellow corner signs..
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > 6.7L Power Stroke Engine and Drivetrain
