Gear Indicator on Dash is gone - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 04-13-2012, 04:01 PM Thread Starter
lincster's Avatar
My Photos: (29)
I go to fill up my truck today, gear indicator on the dash is there like it has been. Fill up, get back in to drive off and it isn't there.
Is there a selection in the menu screen to turn this on/off that I don't know about? I'm sure it is coincidental with me filling up, but why is it gone?
I thought there was another thread about this, but I couldn't find it.
2012 F350 4X4 Dually, FX4, Crew Cab, Ultimate Lariat Package, Oxford White, Black Leather towing a 2006 LE3905 Weekend Warrior
2002 F250 CC, 4X4 - Sold
2004 F350 CC, FX4, loaded - Sold
2006 F350 CC, DRW, FX4 - Sold
lincster is offline
post #2 of 10 (permalink) Old 04-13-2012, 04:36 PM
Hit the plus or minus on the shifter it turn it on or off.
dave67 is offline
post #3 of 10 (permalink) Old 04-13-2012, 10:01 PM
scjmc's Avatar
Every once in a while mine disapears. I am not sure why but like Dave67 mentioned just hit the + or - on the shifter and it comes back. I swear its after my wife drives it, but she says that she doesnt mess with anything...
2011 F350 SRW 6.7 Lariat 4X4 CC 3.31ELD
2006 Lincoln LS V8
1971 Mustang Fastback 351
scjmc is offline
post #4 of 10 (permalink) Old 04-13-2012, 11:28 PM Thread Starter
lincster's Avatar
My Photos: (29)
Got it. Tried that and it worked. Thanks guys.
lincster is offline
post #5 of 10 (permalink) Old 04-15-2012, 07:12 AM
RM2011F250XLT's Avatar
Me too...
Same Fix. 250 miles so far no other problems
RM2011F250XLT is offline
post #6 of 10 (permalink) Old 04-17-2012, 08:27 PM
Stilly's Avatar
I am thinking the + enables the display of the gear indicator and the - disables the gear indicator.
John
2017, F-250, 6.2, 4X4, FX4, CC, Lariat
Previous Super Duty's
2015, F-350, SRW, 6.2, 4X4, FX4, CC, King Ranch
2012, F-350, SRW, 6.7, 4X4, FX4, SC, Lariat
2008, F-350, SRW, 6.4, 4X4, CC, King Ranch
2008, F-250, 5.4, 4X4, SC, Lariat
2003, F-350, SRW, 7.3, 4X4, FX4, CC, Lariat
Stilly is offline
post #7 of 10 (permalink) Old 06-01-2014, 08:55 AM
Just found this thread. Saved my from insanity as I tried to figure out where my light went occasionally, and then what I had done to get it back. Here I was thinking I had a short somewhere as I fumbled around with shifter and the gear lights returned. LOL
2014 F350 Lariat DRW Diesel
countrytraveler is offline
post #8 of 10 (permalink) Old 06-01-2014, 10:38 AM
Five Star DEF's Avatar
Learned this lesson when shifting manually without selecting "M" first with the transmission lever. Interestingly, the + and - rocker on the shift lever will also shift the transmission manually without moving the transmission lever into M first. The gear indicator goes blank when pressing + while in 6 and returns when pressing - .
I use the manual shift feature often to hold in 5 when driving curvy roads. The Tow Haul button holds shift points longer and provides aggressive downshifts when braking. Very useful up and down grades, but took some getting used to.
Erich
Erich Weinberg and Kathryn Whiting
Five Star DEF is offline
post #9 of 10 (permalink) Old 06-01-2014, 10:57 AM
Usually what happens is you inadvertently press the +/- button, not even realising you did it.
Ltngdrvr is offline
post #10 of 10 (permalink) Old 06-01-2014, 02:52 PM
Erich
I think you will find if you check your manual, you are not "shifting" the transmission with that button when you are in drive, but are instead 'removing' higher level gears from the transmission's automatic selection. If you sit at idle in drive and press "-" once, you convert the transmission into a 5 speed. Press it again, and its a 4 speed. You'll see the display change. If you are driving and in 6th gear, pressing the "-" will 'remove' 6th gear from the display, and the trans will of course downshift into it's now highest gear, 5th. Press "-" again, and you'll downshift into 4th because you just "removed" 5th gear. Pressing the "+" button adds the gears back for automatic selection. A really neat feature!
Ray
2013 6.7 PS SuperCrew
FoxFanRay is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > 6.7L Power Stroke Engine and Drivetrain
