6.7L Power Stroke Engine and DrivetrainDiscussion of the 6.7L Power Stroke diesel engine and drivetrain in the 2011-Up Super Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.7L Power Stroke engine.
I was hoping for the 400 HP bragging right....but I will "suffer" with 390!
Wanna bet Chevy takes the 400HP mark?
11 F350 SRW PSD CC 4X4 Long Bed Lariat Ult
2011 Forest River XLR Toy Hauler 39 Feet, 14K lbs.
06 PSD CC 4X4 Shorty Lariat Loaded (sold)
Burried in the fine print of the Ford release is the little gem that the super-reliable Garrett turbos that Ford/International diesels have had for years will not be part of the new engine. The stock Garrett turbos were great - reliable and durable - unless you hot-rodded the engine and then allowed more than about 25 PSI boost.
Instead, in the Ford 6.7 diesel, you get a Honeywell turbo. I hope it's as good as the old Garretts. With 390 stock horses, there shouldn't be any need for more power for 99.97 percent of pickup owners. So I suspect the tuning gurus will have to find another way to make a living when the 7.3Ls and 6.0Ls get old and replaced by newer iron.
Originally Posted by Ford Motor Company
• Honeywell’s VNT™ (variable nozzle turbine) DualBoost turbocharger features an industry-first dual-sided compressor wheel that works in a single housing. The unit is uniquely center-mounted on a pedestal low in the back of the valley for improved NVH. This turbocharger design allows the single unit to deliver the benefits of a twin-turbocharger system in a smaller, more efficient package, combining the advantages of a small turbocharger (faster response) and a large turbocharger (ability to compress and force more air into the engine for more power) in one unit.
My 2006 6.0 liter (bone stock and not run hard), lost it's Garrett turbo at 50K miles. That does not sit well with me.
Bring on the Honeywell in my new 2011!
I just looked into the honeywell turbochargers honeywell actually makes Garret. Here is a link to their site Welcome to TurboByGarrett.com heres another link to info on VNT turbo charger by them. http://www.honeywell.com/sites/porta...works&theme=P1 It specifically says garret when you start reading the article. Just an FYI so people are worried about switching from garret.
2001 F350 Lariet CC dually 4x4 7.3L Powerstroke w/4:10's Two tone black and gold. Mods so far
AFE STGE2 Intake/ITP KCM S.S. HPX Line/Foil delete/ 6 inch bull hauler stacks/dipricol guages(trans temp,boost,EGT)/ Ported turbo shroud NON-ATS/ DP-tuner F5 (No-start,Stock,1500 high idle,40 tow,60 tow, 80E,120 race, 140)
"SOLD" 1985 F350 Crewcab dually with banks
wastegated turbo and gearvendors under/overdrive. 3.54 gears
TRUCK PICS http://good-times.webshots.com/album/561388510jqoIof
Someone on here that works for Ford said their official parts catalog has it listed at 400HP, so maybe these number will actually go up once it's launched.
Why would they de-tune the gasser especially when the Super Duties are heavier than the Rapter?
Let's put these powerful numbers in perspective.
For the gassers, the outgoing 2010 Super Duty's standard 5.4-liter gas V-8 is rated at 300 hp and 365 pounds-feet, and the optional 6.8-liter V-10 is rated at 362 hp and 457 pounds-feet. So the new 6.2-liter V-8 has more horsepower than either of the old engines and just misses splitting the difference in torque between the 5.4-liter and 6.8-liter, with two fewer cylinders than the massive 6.8-liter.
We can also compare the 6.2-liter V-8 in the Super Duty against its application in the 2010 Ford F-150 SVT Raptor. The 6.2-liter V-8 in the Raptor is rated at a larger 411 hp and 434 pounds-feet.
The power numbers are larger in the light-duty pickup for two reasons, according to Chris Brewer, Super Duty chief engineer.
"The main reason is that when the truck goes over 8,500 pounds [gross vehicle weight rating], the SAE [horsepower and torque] rating method changes," Brewer said. "We can't get the same horsepower and torque out of it [like we can in the F-150].”
The 6.2-liter V-8 in the Super Duty also uses a different camshaft from the light-duty version, which, some may recall, is the same approach Ford uses to make 500 hp in the FR Raptor XT version of the 6.2-liter V-8.
Thanks Randy I'd rather be riding my motorcycle thinking about God, than in church thinking about my motorcycle. ~unknown~
2008 Harley Softail Custom 105th Aniv Limited Edition
2006 Harley F-250 Black w/Blue Flames
2006 Harley F-350 Tor Red w/Black Flames SOLD
2005 Harley F-250 True Blue w/Med Blue Flames SOLD
2004 Harley F-250 Black & DSG 2/tone 6" Lift SOLD 1.3 million miles OTR and still Truckin!!
If you can read this, thank a teacher. If it's in English, thank a soldier.
That couldn't be further from the truth. Do you visit boards other than this?
You
You
I was waiting to see if there would be a reply.. There will always be a group that wants more power than stock.
I hope this new engine and trans will hold up to the extra power that is waiting to be found.
2011 F450 K/R ALL Stock and staying that way
I think they detuned it after the catalog was released. Notice where the HP/Torque is. The #s are within 100 rpms of what the last 7.3 was rated at. Lower rpms and more power/torque.
__________________ 2000 F350 SRW Supercab 7.3 PSD
4" MBRP Exhaust with Donaldson M085171 Muffler,
SCT X3 w/DP-Tuner 60T-80T-80E ,
Transgo Equipped 4R100, Autometer Guages,
Donaldson/Motorcraft Air Induction System,
Ford AIC, Northstar 8.5 Adventurer,
Timbren Overloads, Code L Front Springs,
Bilstein Shocks, BFG Commercial TA Rubber,
Hella 700FF Driving Lights
