Just threw a P2032 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2011 and Up Ford Super Duties > 6.7L Power Stroke Engine and Drivetrain
Old 11-25-2012, 11:35 AM   #1 (permalink)
Just threw a P2032
So EGT Sensor Low Voltage. How concerned should I be? Can I drive it to the dealer? I have not had the last round of Recall stuff done so I need to bring it in anyway. Anyone else throw this code?
fastcarsspeed is offline   Reply With Quote
Old 12-05-2012, 03:34 PM   #2 (permalink)
The sensor referenced below appears to be between the DOC and the SCR. Turbo -> DOC -> SCR -> DPF. This sensor is between the DOC and SCR just prior to the urea injector.
Exhaust Gas Temperature Sensor Circuit Low Bank 1 Sensor 2
Description: The powertrain control module (PCM) monitors the exhaust gas temperature (EGT) sensor for a low voltage concern. The test fails when the sensor voltage is less than 0.10 volt for more than 15 seconds.
Possible Causes:
EGT12 signal circuit short to SIGRTN
EGT12 signal circuit short to ground
Damaged EGT12 sensor
Diagnostic Aids The presence of this DTC may indicate that the vehicle is operating in derate mode and may experience a loss of power.
An EGT12_V PID value less than 0.10 volt indicates a concern.
RyanP2317 is offline   Reply With Quote
